Steuerbefehle Steca Solarix PLI 5000-48, Effekta AX Serie, Voltronic Axpert Serie, MPPSolar PIP Serie und Baugleiche
Verfasst: Di 27. Aug 2019, 17:32
Ich fand hier ein Axpert Inverter control Skript. Darin sind viele (alle?) Steuerbefehle die vielleicht brauchbar sein können:
#Axpert Commands and examples
#Q1 # Undocumented command: LocalInverterStatus (seconds from absorb), ParaExistInfo (seconds from end of Float), SccOkFlag, AllowSccOnFlag, ChargeAverageCurrent, SCC PWM Temperature, Inverter Temperature, Battery Temperature, Transformer Temperature, GPDAT, FanLockStatus, FanPWMDuty, FanPWM, SCCChargePowerWatts, ParaWarning, SYNFreq, InverterChargeStatus
#QPI # Device protocol ID inquiry
#QID # The device serial number inquiry
#QVFW # Main CPU Firmware version inquiry
#QVFW2 # Another CPU Firmware version inquiry
#QFLAG # Device flag status inquiry
#QPIGS # Device general status parameters inquiry
# GridVoltage, GridFrequency, OutputVoltage, OutputFrequency, OutputApparentPower, OutputActivePower, OutputLoadPercent, BusVoltage, BatteryVoltage, BatteryChargingCurrent, BatteryCapacity, InverterHeatSinkTemperature, PV-InputCurrentForBattery, PV-InputVoltage, BatteryVoltageFromSCC, BatteryDischargeCurrent, DeviceStatus,
#QMOD # Device mode inquiry P: PowerOnMode, S: StandbyMode, L: LineMode, B: BatteryMode, F: FaultMode, H: PowerSavingMode
#QPIWS # Device warning status inquiry: Reserved, InverterFault, BusOver, BusUnder, BusSoftFail, LineFail, OPVShort, InverterVoltageTooLow, InverterVoltageTooHIGH, OverTemperature, FanLocked, BatteryVoltageHigh, BatteryLowAlarm, Reserved, ButteryUnderShutdown, Reserved, OverLoad, EEPROMFault, InverterSoftFail, SelfTestFail, OPDCVoltageOver, BatOpen, CurrentSensorFail, BatteryShort, PowerLimit, PVVoltageHigh, MPPTOverloadFault, MPPTOverloadWarning, BatteryTooLowToCharge, Reserved, Reserved
#QDI # The default setting value information
#QMCHGCR # Enquiry selectable value about max charging current
#QMUCHGCR # Enquiry selectable value about max utility charging current
#QBOOT # Enquiry DSP has bootstrap or not
#QOPM # Enquiry output mode
#QPIRI # Device rating information inquiry - nefunguje
#QPGS0 # Parallel information inquiry
# TheParallelNumber, SerialNumber, WorkMode, FaultCode, GridVoltage, GridFrequency, OutputVoltage, OutputFrequency, OutputAparentPower, OutputActivePower, LoadPercentage, BatteryVoltage, BatteryChargingCurrent, BatteryCapacity, PV-InputVoltage, TotalChargingCurrent, Total-AC-OutputApparentPower, Total-AC-OutputActivePower, Total-AC-OutputPercentage, InverterStatus, OutputMode, ChargerSourcePriority, MaxChargeCurrent, MaxChargerRange, Max-AC-ChargerCurrent, PV-InputCurrentForBattery, BatteryDischargeCurrent
#QBV # Compensated Voltage, SoC
#PEXXX # Setting some status enable
#PDXXX # Setting some status disable
#PF # Setting control parameter to default value
#FXX # Setting device output rating frequency
#POP02 # set to SBU
#POP01 # set to Solar First
#POP00 # Set to UTILITY
#PBCVXX_X # Set battery re-charge voltage
#PBDVXX_X # Set battery re-discharge voltage
#PCP00 # Setting device charger priority: Utility First
#PCP01 # Setting device charger priority: Solar First
#PCP02 # Setting device charger priority: Solar and Utility
#PGRXX # Setting device grid working range
#PBTXX # Setting battery type
#PSDVXX_X # Setting battery cut-off voltage
#PCVVXX_X # Setting battery C.V. charging voltage
#PBFTXX_X # Setting battery float charging voltage
#PPVOCKCX # Setting PV OK condition
#PSPBX # Setting solar power balance
#MCHGC0XX # Setting max charging Current M XX
#MUCHGC002 # Setting utility max charging current 0 02
#MUCHGC010 # Setting utility max charging current 0 10
#MUCHGC020 # Setting utility max charging current 0 20
#MUCHGC030 # Setting utility max charging current 0 30
#POPMMX # Set output mode M 0:single, 1: parrallel, 2: PH1, 3: PH2, 4: PH3
#notworking
#PPCP000 # Setting parallel device charger priority: UtilityFirst - notworking
#PPCP001 # Setting parallel device charger priority: SolarFirst - notworking
#PPCP002 # Setting parallel device charger priority: OnlySolarCharging - notworking
