Der Log sieht so aus...
02.05. 00:46:01 |------------------------- Start goodwe_wr.php ---------------------
02.05. 00:46:01 -Zentraler Timestamp: 1619909161
02.05. 00:46:01 o -Hardware Version:
02.05. 00:46:01 + -WR_ID: f7
02.05. 00:46:01 XX -USB Port kann nicht geöffnet werden. [1]
02.05. 00:46:01 XX -Exit....
02.05. 00:46:01 |------------------------- Stop goodwe_wr.php ---------------------
02.05. 00:47:06 -
P: Vendor=1d6b ProdID=0002 Rev=05.10
S: Manufacturer=Linux 5.10.17-v7l+ xhci-hcd
S: Product=xHCI Host Controller
S: SerialNumber=0000:01:00.0
I: If#=0x0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 4
D: Ver= 2.10 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=2109 ProdID=3431 Rev=04.21
S: Product=USB2.0 Hub
C: #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=100mA
T: Bus=01 Lev=02 Prnt=02 Port=03 Cnt=01 Dev#= 3 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=0403 ProdID=6001 Rev=06.00
S: Manufacturer=FTDI
S: Product=USB to RS-422/485 Adapter
S: SerialNumber=A744R2T3
C: #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=90mA
I: If#=0x0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=5000 MxCh= 4
D: Ver= 3.00 Cls=09(hub ) Sub=00 Prot=03 MxPS= 9 #Cfgs= 1
P: Vendor=1d6b ProdID=0003 Rev=05.10
02.05. 00:47:05 |------------------------- Start goodwe_wr.php ---------------------
02.05. 00:47:06 -Zentraler Timestamp: 1619909225
02.05. 00:47:06 o -Hardware Version:
02.05. 00:47:06 + -WR_ID: f7
02.05. 00:47:07 -Daten:
array (
24 => 'None 00.0: 11300 Partition',
'' => '[Created at block.434]',
'Unique ID' => 'l7UW.SE1wIdpsiiC',
'Parent ID' => 'HAKk.Fxp0d3BezAE',
'SysFS ID' => '/class/block/mmcblk0/mmcblk0p1',
'Model' => '"Partition"',
'Device File' => '/dev/mmcblk0p1',
'Device Files' => '/dev/mmcblk0p1, /dev/disk/by-label/boot, /dev/disk/by-path/platform-fe340000.emmc2-part1, /dev/disk/by-uuid/0C61-73F5, /dev/disk/by-partuuid/8978ce14-01, /dev/disk/by-id/mmc-SD16G_0x00271395-part1',
'Attached to' => '#2 (USB Controller)',
array (
29 => 'USB 00.0: 0700 Serial controller',
'' => '[Created at usb.122]',
'Unique ID' => '33sj.mGV0VCeOGp9',
'Parent ID' => 'ADDn.mUqILwxEtWB',
'SysFS ID' => '/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0',
'SysFS BusID' => '1-1.4:1.0',
'Model' => '"Future Technology Devices International FT232 Serial (UART) IC"',
'Hotplug' => 'USB',
'Device' => 'usb 0x6001 "FT232 Serial (UART) IC"',
'Revision' => '"6.00"',
'Serial ID' => '"A744R2T3"',
'Driver' => '"ftdi_sio"',
'Driver Modules' => '"usbserial", "ftdi_sio"',
'Device File' => '/dev/ttyUSB0',
'Device Files' => '/dev/ttyUSB0, /dev/serial/by-id/usb-FTDI_USB_to_RS-422_485_Adapter_A744R2T3-if00-port0, /dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-port0',
'Device Number' => 'char 188:0',
'Tags' => 'mouse, modem',
'Speed' => '12 Mbps',
'Module Alias' => '"usb:v0403p6001d0600dc00dsc00dp00icFFiscFFipFFin00"',
'Driver Info #0' => '',
'Driver Status' => 'ftdi_sio is active',
'Driver Activation Cmd' => '"modprobe ftdi_sio"',
'Attached to' => '#30 (Hub)',
array (
30 => 'USB 00.0: 10a00 Hub',
'Unique ID' => 'ADDn.mUqILwxEtWB',
'Parent ID' => 'k4bc.kNaPe9SZft4',
'SysFS ID' => '/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1:1.0',
'SysFS BusID' => '1-1:1.0',
'Hardware Class' => 'hub',
'Model' => '"VIA Hub"',
'Hotplug' => 'USB',
'Vendor' => 'usb 0x2109 "VIA Labs, Inc."',
'Device' => 'usb 0x3431 "Hub"',
'Revision' => '"4.21"',
'Driver' => '"hub"',
'Speed' => '480 Mbps',
'Module Alias' => '"usb:v2109p3431d0421dc09dsc00dp01ic09isc00ip00in00"',
'Attached to' => '#28 (Hub)',
array (
31 => 'USB 00.0: 10a00 Hub',
'Unique ID' => 'pBe4.djic47EFb5E',
'Parent ID' => 'VCu0.m2lGPNk7Xc4',
'SysFS ID' => '/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb2/2-0:1.0',
'SysFS BusID' => '2-0:1.0',
'Model' => '"Linux Foundation 3.0 root hub"',
'Hotplug' => 'USB',
'Vendor' => 'usb 0x1d6b "Linux Foundation"',
'Device' => 'usb 0x0003 "3.0 root hub"',
'Revision' => '"5.10"',
'Serial ID' => '"0000:01:00.0"',
'Module Alias' => '"usb:v1D6Bp0003d0510dc09dsc00dp03ic09isc00ip00in00"',
02.05. 00:47:07 -USB Devices:
array (
1 =>
array (
'Device' => '0x6001',
'File' => '/dev/ttyUSB0',
'Driver' => 'ftdi_sio',
2 =>
array (
'Device' => '0x0003',
02.05. 00:47:07 -Regler: 52
02.05. 00:47:07 -Regler erkannt: /dev/ttyUSB0
02.05. 00:47:07 -Device: /dev/ttyUSB0 wird in die user.config.php geschrieben.
02.05. 00:47:07 -Zeile gefunden. Device kann ausgetauscht werden. Index: 561 $USBRegler = "/dev/ttyUSB0";
02.05. 00:47:07 -Zeile gefunden. Device kann ausgetauscht werden. Index: 562 $USBWechselrichter = "/dev/ttyUSB1";
02.05. 00:47:07 -Zeile gefunden. Platine kann ausgetauscht werden. Index: 581 $Platine = "Raspberry unbekannt";
02.05. 00:50:14 -Auslesen des Gerätes beendet.
02.05. 00:50:14 -Array
[zentralerTimestamp] => 1619909235
[Seriennummer] =>
[VPV] =>
[Firmware] =>
[Modell] =>
[PV1_Spannung] => 0
[PV1_Strom] => 0
[PV2_Mode] => 0
[PV3_Spannung] => 0
[Batterie_Spannung] => 0
[BMS_Status] => 0
[Batterie_Temperatur] => 0
[SOC] => 0
[Batterie_Mode] => 0
[Meter_Status] => 0
[Netzspannung] => 0
[Netzstrom] => 0
[Einspeisung_Bezug] => 0
[Netzfrequenz] => 0
[Netzmode] => 0
[AC_Spannung] => 0
[AC_Strom] => 0
[Verbrauch] => 0
[WR_Mode] => 0
[WR_Temperatur] => 0
[Einspeisung_total] => 0
[EinspeisungHeute] => 0
[BezugHeute] => 0
[WattstundenGesamtHeute] => 0
[PV_Leistung_total] => 0
[PV1_Leistung] => 0
[PV2_Leistung] => 0
[PV3_Leistung] => 0
[Batterie_Leistung] => 0
[MeterType] => 0
[AC_Spannung_R] => 0
[AC_Spannung_S] => 0
[AC_Spannung_T] => 0
[AC_Leistung_R] => 0
[AC_Leistung_S] => 0
[AC_Leistung_T] => 0
[AC_Leistung] => 0
[PV_Leistung] => 0
[Regler] => 52
[Objekt] =>
[Produkt] => Goodwe
02.05. 00:50:14 -Alle 10 Minuten werden die Statistikdaten übertragen.
02.05. 00:50:15 * -Daten zur lokalen InfluxDB [ solaranzeige ] gesendet.
02.05. 00:50:15 -Schleife 1 Ausgang...
02.05. 00:50:15 -OK. Datenübertragung erfolgreich.
02.05. 00:50:15 |------------------------- Stop goodwe_wr.php ---------------------
02.05. 00:50:47 |------------------- Start wetterdaten.php --------------------
02.05. 00:50:47 o---Wetterdaten ausgeschaltet.
02.05. 00:50:47 |------------------- Stop wetterdaten.php ---------------------
02.05. 00:51:01 |------------------------- Start goodwe_wr.php ---------------------
02.05. 00:51:01 -Zentraler Timestamp: 1619909461
02.05. 00:51:01 o -Hardware Version: 4B
02.05. 00:51:01 + -WR_ID: f7
02.05. 00:52:19 -Auslesen des Gerätes beendet.
02.05. 00:52:19 -Array
[zentralerTimestamp] => 1619909471
[Seriennummer] =>
[VPV] =>
[Firmware] =>
[Modell] =>
[PV1_Spannung] => 0
[PV1_Strom] => 0
[PV1_Mode] => 0
[PV2_Spannung] => 0
[PV2_Strom] => 0
[PV2_Mode] => 0
[PV3_Spannung] => 0
[BMS_Status] => 0
[SOC] => 0
[Meter_Status] => 0
[Netzspannung] => 0
[Netzstrom] => 0
[Netzfrequenz] => 0
[Netzmode] => 0
[AC_Spannung] => 0
[AC_Strom] => 0
[Verbrauch] => 0
[WR_Mode] => 0
[BezugHeute] => 0
[PV1_Leistung] => 0
[PV2_Leistung] => 0
[PV3_Leistung] => 0
[MeterType] => 0
[AC_Leistung] => 0
[PV_Leistung] => 0
[Regler] => 52
[Objekt] =>
[Produkt] => Goodwe
der letzte Teil mit den Werten wiederholt sich dann zyklisch...
