Datenbankfelder MPPSolar 5048MK und GK sowie Baugleiche [Regler 26]
Moderatoren: Ulrich, TeamO
Gesperrt
Hat sich bedankt: 4 Mal
Danksagung erhalten: 69 Mal
Info
Firmware
Produkt
Datum
Netz
Spannung Volt
Frequenz Hertz
AC
Spannung Volt
Frequenz Hertz
Scheinleistung VA
Wirkleistung VA
Ausgangslast %
Batterie
Spannung Volt
Spannung_WR Volt
Ladestrom Ampere
Kapazitaet %
Entladestrom Ampere
PV
Strom Ampere
Leistung Watt
Spannung Volt
Service
Temperatur °C
Ladestatus 1,2
Fehlermeldung Text
Device_Status 1,2,3,4,5,6,7,8,9,10
Modus
P = Power on mode
S = Standby mode
L = Line Mode
B = Battery mode
F = Fault mode
H = Power saving Mode
D = Shutdown Mode
C = Charge Mode
Y = Bypass mode
E = ECO mode
Warnungen 000010000101 usw.
a0,a1,a2,a3,usw.
a0 ist links das 1. Bit und a31 rechts
das letzte Bit.
bit Warning Description
a0 Reserved
a1 Inverter fault Fault
a2 Bus Over Fault
a3 Bus Under Fault
a4 Bus Soft Fail Fault
a5 LINE_FAIL Warning
a6 OPVShort Warning
a7 Inverter voltage too low Fault
a8 Inverter voltage too high Fault
a9 Over temperature Compile with a1,
if a1=1,fault,
otherwise warning
a10 Fan locked Compile with a1, if
a1=1,fault,
otherwise warning
a11 Battery voltage high Compile with
a1, if a1=1,fault,
otherwise warning
a12 Battery low alarm Warning
a13 Reserved(Overcharge)
a14 Battery under shutdown Warning
a15 Reserved((Battery derating)
Warning
a16 Over load Compile with a1, if
a1=1,fault,
otherwise warning
a17 Eeprom fault Warning
a18 Inverter Over Current Fault
a19 Inverter Soft Fail Fault
a20 Self Test Fail Fault
a21 OP DC Voltage Over Fault
a22 Bat Open Fault
a23 Current Sensor Fail Fault
a24 Battery Short Fault
a25 Power limit Warning
a26 PV voltage high Warning
a28 MPPT overload warning Warning
a29 Battery too low to charge Warning
a30 Reserved
a31 Reservedbit Warning Description
a0 PV loss Warning
a2 Bus Over Fault
a3 Bus Under Fault
a6 OPVShort Fault
a9 Over temperature
Compile with a1, if a1=1,fault,
otherwise warning
a10 Fan locked
otherwise warning
otherwise warning
a13 Reserved
a15 Battery derating Warning
a16 Over load
otherwise warning
a22 Battery Open Fault
a24 Battery Short Fault(For PIP-MK) 9
a25 Power limit Warning(For PIP-MK)
a26 PV voltage high Warning/Fault (For
PIP-MK)
a27 MPPT overload fault Fault (For
PIP-MK)
Warning(For PIP-MK)
Warning(For PIP-MK)
a30 DC/DC Over Current Fault (For
PIP-MK))
a31 D Fault code
a32 D Fault code
a33 Low PV energy Warning
a34 High AC input during BUS soft
start Warning
a35 Battery equalization Warning
Summen
Wh_Heute Wh
Statistik
Bezeichnung WhTag
Datum Datum
DieseWoche_TS Zeitstempel
DieserMonat_TS Zeitstempel
DiesesJahr_TS Zeitstempel
Gestern_TS Zeitstempel
Heute_TS Zeitstempel
Jahr Zahl
LetzteWoche_TS Zeitstempel
LetzterMonat_TS Zeitstempel
LetztesJahr_TS Zeitstempel
Monat Zahl
Stunde Zahl
TagImJahr Zahl
TagImMonat Zahl
Woche Zahl
Wochentag Text
Gesperrt
