28.06. 22:17:08 -Verarbeitung von: '2.user.config.php' Regler: 31
28.06. 22:17:08 |-------------------- Start shelly.php ------------------
28.06. 22:17:08 -Shelly Typ: SHEM-3
28.06. 22:17:08 -Gesamtleistung: 8.66 Watt
28.06. 22:17:09 -InfluxDB => [ WP Heatpump_State=0,Pump_Flow=0.13,Force_DHW_State=0,Quiet_Mode_Schedule=0,Operating_Mode_State=3,Main_Inlet_Temp=29,Main_Outlet_Temp=29,Main_Target_Temp=24,Compressor_Freq=0,DHW_Target_Temp=51,DHW_Temp=50,Operations_Hours=9615,Operations_Counter=6128,Main_Schedule_State=0,Outside_Temp=16,Heat_Energy_Production=0,Heat_Energy_Consumption=0,Powerful_Mode_Time=0,Quiet_Mode_Level=0,Holiday_Mode_State=0,ThreeWay_Valve_State=0,Outside_Pipe_Temp=16,DHW_Heat_Delta=-5,Heat_Delta=5,Cool_Delta=5,DHW_Holiday_Shift_Temp=-15,Defrosting_State=0,Z1_Heat_Request_Temp=0,Z1_Cool_Request_Temp=0,Z1_Heat_Curve_Target_High_Temp=33,Z1_Heat_Curve_Target_Low_Temp=24,Z1_Heat_Curve_Outside_High_Temp=15,Z1_Heat_Curve_Outside_Low_Temp=-15,Room_Thermostat_Temp=27,Z1_Water_Temp=-78,Cool_Energy_Production=0,Cool_Energy_Consumption=0,DHW_Energy_Production=0,DHW_Energy_Consumption=0,Z1_Water_Target_Temp=24,Error="No error",Room_Holiday_Shift_Temp=-15,Main_Hex_Outlet_Temp=29,Discharge_Temp=25,Inside_Pipe_Temp=29,Defrost_Temp=17,Eva_Outlet_Temp=18,Bypass_Outlet_Temp=18,Ipm_Temp=20,Z1_Temp=29,DHW_Heater_State=0,Room_Heater_State=0,Internal_Heater_State=0,External_Heater_State=0,Fan1_Motor_Speed=0,Fan2_Motor_Speed=0,High_Pressure=12.2,Pump_Speed=0,Low_Pressure=0,Compressor_Current=0.0,Force_Heater_State=0,Sterilization_State=0,Sterilization_Temp=65,Sterilization_Max_Time=10,Z1_Cool_Curve_Target_High_Temp=15,Z1_Cool_Curve_Target_Low_Temp=10,Z1_Cool_Curve_Outside_High_Temp=30,Z1_Cool_Curve_Outside_Low_Temp=20,Heating_Mode=0,Heating_Off_Outdoor_Temp=18,Heater_On_Outdoor_Temp=0,Heat_To_Cool_Temp=15,Cool_To_Heat_Temp=10,Cooling_Mode=0,Z2_Heat_Curve_Target_High_Temp=55,Z2_Heat_Curve_Target_Low_Temp=35,Z2_Heat_Curve_Outside_High_Temp=15,Z2_Heat_Curve_Outside_Low_Temp=-5,Room_Heater_Operations_Hours=0,DHW_Heater_Operations_Hours=0,Heat_Pump_Model="255",Pump_Duty=0,Zones_State=0,Max_Pump_Duty=244,Heater_Delay_Time=-1,Heater_Start_Delta=-128,Heater_Stop_Delta=-128,Buffer_Installed=0,DHW_Installed=1,Pump_Flowrate_Mode=-1,=0,=0,=0,=0,=0,=0,=0,=0 1687983430
Service RelaisstatText="aus" 1687983430
AC NetzBezug=4,PVBezug=4.66 1687983430
Summen TagesLeistung=1440.6443333333 1687983430
AC Spannung_R=231.89,Spannung_S=238.86,Spannung_T=235.75,Strom_R=0.29,Strom_S=0.3,Strom_T=0.44,Leistung_VerbrauchGesamt_R=593191.1,Leistung_VerbrauchGesamt_S=633594.6,Leistung_VerbrauchGesamt_T=863405.8,Leistung_EinspeisungGesamt_R=30.4,Leistung_EinspeisungGesamt_S=1523.8,Leistung_EinspeisungGesamt_T=0.7,PowerFactor_R=-0,PowerFactor_S=-0.01,PowerFactor_T=0.08,Wirkleistung_R=0,Wirkleistung_S=0,Wirkleistung_T=8.66,Gesamtleistung=8.66 1687983430
Service Relaisstatus=0,Ueberlastung=0 1687983430
Summen Wh_Heute=1397.83,Wh_Gesamt_Verbrauch=2090191.5,Wh_Gesamt_Einspeisung=1554.9 1687983430
28.06. 22:17:09 -Daten nicht zur lokalen InfluxDB gesendet! info: array (
'url' => 'http://localhost/write?db=shelly3em&precision=s',
'http_code' => 400,
'header_size' => 1322,
'request_size' => 2921,
'filetime' => -1,
'ssl_verify_result' => 0,
'redirect_count' => 0,
'total_time' => 0.02016,
'namelookup_time' => 0.000204,
'connect_time' => 0.000265,
'pretransfer_time' => 0.000301,
'size_upload' => 2766.0,
'size_download' => 2121.0,
'speed_download' => 106050.0,
'speed_upload' => 138300.0,
'download_content_length' => -1.0,
'upload_content_length' => 2766.0,
'starttransfer_time' => 0.020107,
'redirect_time' => 0.0,
'redirect_url' => '',
'primary_ip' => '127.0.0.1',
'certinfo' =>
array (
'primary_port' => 8086,
'local_ip' => '127.0.0.1',
'local_port' => 42790,
'http_version' => 2,
'protocol' => 1,
'ssl_verifyresult' => 0,
'scheme' => 'HTTP',
'appconnect_time_us' => 0,
'connect_time_us' => 265,
'namelookup_time_us' => 204,
'pretransfer_time_us' => 301,
'redirect_time_us' => 0,
'starttransfer_time_us' => 20107,
'total_time_us' => 20160,
