Seite 1 von 1
Sonnenbatterie Ältere Bauart
Verfasst: So 10. Apr 2022, 09:42
von AndyOne
Hallo, ich habe versucht eine ältere Sonnebatterie Eco4,5 aus 2015 ans laufen zu bringen, schaffe das aber nicht.
Jetzt benötige ich etwas Hilfe, denn über den Browser kann ich Werte bekommen.
Grüße Andy
über die url http://192.168.178.57:3480/data_request ... ormat=json
bekomme ich folgende Anzeige:
{ "full": 1, "version": "*1.7.2335*", "model": "Sercomm NA301", "zwave_heal": 1, "temperature": "C", "skin": "sonnenbaterie", "serial_number": "46158733", "fwd1": "sonnen-us-oem-relay12.mios.com", "fwd2": "sonnen-us-oem-relay11.mios.com", "mode": 1, "sections": [ { "name": "My Home", "id": 1 } ], "rooms": [ { "name": "Sonnenbatterie", "id": 1, "section": 1 } ], "scenes": [ ], "devices": [ { "name": "BHKW 1", "altid": "CHP-1", "id": 26, "category": 0, "subcategory": -1, "room": 1, "parent": 19, "watts": "0", "chppeakpower": "0" }, { "name": "Eigenverbrauchsrelais 1", "altid": "OwnConsumptionRelay-1", "id": 24, "category": 0, "subcategory": -1, "room": 1, "parent": 19, "automode": "0", "duration": "30", "threshold": "1500", "status": "0" }, { "name": "Gesamtverbauch 1", "altid": "TotalConsumption-1", "id": 23, "category": 0, "subcategory": -1, "room": 1, "parent": 19, "watts": "415.7", "wattsl1": "213.7", "wattsl2": "107.0", "wattsl3": "95.0", "maxwattsl1": "216", "maxwattsl2": "112", "maxwattsl3": "97", "iscountercumulated": "0" }, { "name": "Luftentfeuchter", "altid": "4", "id": 18, "category": 3, "subcategory": 1, "room": 0, "parent": 1, "status": "0", "watts": "0.0", "kwh": "87.0200", "pulse": "2228224", "commFailure": "0", "state": -1, "comment": "" }, { "name": "Photovoltaik 1", "altid": "Photovoltaics-1", "id": 20, "category": 0, "subcategory": -1, "room": 1, "parent": 19, "watts": "639.6", "maxfeedin": "100", "pvpeakpower": "4.59" },
{ "name": "Sonnenbatterie #19514", "altid": "", "id": 19, "category": 0, "subcategory": -1, "room": 1, "parent": 0, "watts": "0", "wattsdischarge": "0.0", "wattscharge": "226.0", "soc": "44.0", "operationmode": "13", "temperature": "19.86555", "chargingcontactor": "-1", "consumptioncontactor": "FALSE", "nocharging": "FALSE", "capacity": "0041", "chargingpowermanual": "2475", "chargingbuffer": "0", "switchingthresholdgrid": "-1", "switchingthresholdbattery": "-1", "serialnumber": "19514", "versionplc": "5.00 (435)", "nominalvoltage": "44.8", "priority": "1", "lowerlimitsoc": "22", "location": "DE-86462", "lastoperationmodechange": "1649573809", "lastvaliddata": "1649573809", "operatingmode": "13", "autosocket1": "0", "autosocket2": "0", "autosocket3": "0" },
 { "name": "Waermepumpe 1", "altid": "Heatpump-1", "id": 25, "category": 0, "subcategory": -1, "room": 1, "parent": 19, "isheatpumpgrid": "FALSE", "isheatpumpbattery": "FALSE", "isheatpumpinstalled": "0" } ], "categories": [ { "name": "On\/Off Switch", "id": 3 } ], "ir": 0, "irtx": "", "loadtime": 1649575026, "dataversion": 575026078, "state": 1, "comment": "Sonnenbatterie #19514[19]: Running Lua Startup" }
Das sind doch Werte drin, allerdings bekomme ich die nicht in die Anzeige.
Die 2.user.config.php habe ich folgendermaßen editiert:
$WR_IP = "192.168.178.57";
$WR_Port = "3480";
$WR_Adresse = "1";
Die sonnen_batterie.php habe ich editiert, damit die die richtige url verwendet wird:
$'URL = "data_request?id=sdata&output_format=json";
Das Log sieht so aus:
10.04. 09:37:11 * -Daten zur lokalen InfluxDB [ solaranzeige ] gesendet.
10.04. 09:37:11 -Multi-Regler-Ausgang. -2
10.04. 09:37:11 -OK. Datenübertragung erfolgreich.
10.04. 09:37:11 |---------------- Stop fronius_symo_serie.php ---------------
10.04. 09:37:11 -Verarbeitung von: '2.user.config.php' Regler: 25
10.04. 09:37:11 |---------------- Start sonnen_batterie.php ------------------
10.04. 09:37:11 * -Daten zur lokalen InfluxDB [ solaranzeige2 ] gesendet.
10.04. 09:37:11 -Multi-Regler-Ausgang. 7
10.04. 09:37:18 -OK. Datenübertragung erfolgreich.
10.04. 09:37:18 -WattstundenGesamtHeute: 0
10.04. 09:37:18 |---------------- Stop sonnen_batterie.php ------------------
10.04. 09:37:18 -Multi Regler Auslesen [Stop].
Re: Sonnenbatterie Ältere Bauart
Verfasst: So 10. Apr 2022, 09:51
von Ulrich
Schaue doch einmal direkt in die Influx Datenbanken "solaranzeige" und "solaranzeige2". Wenn dort die Daten vorhanden sind, liegt es an den Einstellungen im Grafana.
Verfasst: So 10. Apr 2022, 14:05
von AndyOne
Hab ich gemacht.
Zeitstempel stehen drin, aber keine Daten, alles 0.
Ich kann nicht programmieren, denke aber dass die Variablen in der sonnen_batterie.php nicht mit denen übereinstimmen, die ich per Browser oben ausgelesen habe. Diese geschweiften Klammern sind wohl alle "Geräte" in der SB, wie werden die Variablen in der php Datei angesprochen? Und wie bekomme ich neue Werte in die Datenbank, z.B. Temperatur?
Verfasst: So 10. Apr 2022, 16:01
von Ulrich
Hallo AndyOne,
die Datenpunkte stimmen überhaupt nicht mit der aktuellen Sonnenbatterie überein. Diese Version müsste ganz neu implementiert werden. Da es aber ein Exot ist, macht die Arbeit keinen Sinn. Sorry. Da kann die nur ein PHP Programmierer halfen, der sich die viele Mühe macht, das Gerät auszulesen.
Verfasst: Fr 15. Apr 2022, 15:33
von AndyOne
ja das verstehe ich schon.
Habe mich etwas damit beschäftigt und bekomme nun ein paar Werte ausgelesen. Die Werte sind allerdings zeitlich mehrere Stunden alt, warum das so ist verstehe ich auch noch nicht, liegt aber vermutlich eher an der Sonnenbatterie selbst.
Was ich aber nicht verstehe und hier brauche ich etwas Hilfe wenn es einfach möglich ist. In der php Datei habe ich die Variablen der Werte oder sind es Parameter durch "Mxx" ersetzt. Jetzt erhalte ich manche Werte in die DB geschrieben, aber nicht alle. Z.B. Batterieladung "M01" und Entladung "M02" werden nicht ausgelesen, obwohl ich durch einen manuellen Browseraufruf hier Werte bekomme.
$aktuelleDaten ["Batterieladung"]=$Daten ["M01"];
$aktuelleDaten["Entladung"]=$Daten["M02"];
$aktuelleDaten["Verbrauch"]=$Daten["M04"];
Woran kann das liegen?
Für andere Variablen in der php, gibt es gar kein entsprechendes Feld in der DB.
Andy
Verfasst: Fr 15. Apr 2022, 16:38
von Ulrich
Die Umsetzung der Variablen in die Werte, die abgespeichert werden findest du in der Datei /var/www/html/phpinc/funktionen.inc.php
Dort findest du auch die Routine, die die Werte dann in die Datenbank schreibt.
Verfasst: So 31. Jul 2022, 10:12
von lumulu79@gmail.com
@AndyOne Ich habe eine Eco7
hast du es bei dir hinbekommen?
Verfasst: Mo 12. Sep 2022, 14:35
von wodyfox
Hallo @AndyOne. Würde mich auch interessieren ob und wie Du das hinbekommen hast.
Ich habe eine eco 6 und da wird ein anderer port verwendet. Über den Browser kann man die Mxx variablen abfragen, aber lange nicht alle.
Bei mir geht das mit dem Befehl: http://192.168.178.21:7979/rest/devices/battery.
Erst mit den späteren Modellen eco 10(?) hat sich die Abfrage (port) geändert.
Sonnen ist da sehr schwierig. Ich habe von denen keine Antwort auf meine Anfragen bekommen. Leider habe ich vom programmieren auch marginalste Kenntnisse, Java gar nichts.
Wäre schön, wenn man auch für die älteren Sonnen Batterien ertwas machen könnte.
Alternativ habe ich auch noch den SolarLog 1200 den ich über LAN abfragen kann. Der SL frägt aber nur 1/2 bis 3/4 Stunde später ab. Damit nicht zum Laden mit dem Go-e charger zu gebrauchen. Meine Wechselrichter Solutronic werden auch nicht unterstützt, aber die Daten liegen ja in der Sonnenbatterie und auch im SolarLog vor, daher nicht schlimm.
Alles schade für meine Konstellation. Im iobroker bekomme ich Werte, aber mit Grafana und visualisierung habe ich wieder kein Ahnung, wie das geht. Daher kam ich auf diese Super Website. Aber leider.....
Vielen dank und liebe Grüße
Peter
