e-i-k-e
Hat sich bedankt: 6 Mal
Beitrag von e-i-k-e »
Ich glaub es nicht, bekomme Daten! 8-)
14.10. 23:29:21 |------------   Stop   daly_bms.php    ----------------------------
14.10. 23:29:56    -
T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480 MxCh= 1
D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=01 MxPS=64 #Cfgs=  1
P:  Vendor=1d6b ProdID=0002 Rev=05.10
S:  Manufacturer=Linux 5.10.63-v7+ dwc_otg_hcd
S:  Product=DWC OTG Controller
S:  SerialNumber=3f980000.usb
C:  #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=0mA
I:  If#=0x0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
T:  Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  2 Spd=480 MxCh= 5
D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=02 MxPS=64 #Cfgs=  1
P:  Vendor=0424 ProdID=9514 Rev=02.00
C:  #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=2mA
I:  If#=0x0 Alt= 1 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=02 Driver=hub
T:  Bus=01 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#=  3 Spd=480 MxCh= 0
D:  Ver= 2.00 Cls=ff(vend.) Sub=00 Prot=01 MxPS=64 #Cfgs=  1
P:  Vendor=0424 ProdID=ec00 Rev=02.00
I:  If#=0x0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=ff Driver=smsc95xx
T:  Bus=01 Lev=02 Prnt=02 Port=02 Cnt=02 Dev#=  4 Spd=12  MxCh= 0
D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs=  1
P:  Vendor=0403 ProdID=6001 Rev=06.00
S:  Manufacturer=FTDI
S:  Product=FT232R USB UART
S:  SerialNumber=A10KMT5Q
C:  #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=90mA
I:  If#=0x0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio
14.10. 23:29:59    -Daten:
array (
  21 => 'None 00.0: 11300 Partition',
  '' => '[Created at block.434]',
  'Unique ID' => 'l7UW.SE1wIdpsiiC',
  'Parent ID' => 'HAKk.Fxp0d3BezAE',
  'SysFS ID' => '/class/block/mmcblk0/mmcblk0p1',
  'Model' => '"Partition"',
  'Device File' => '/dev/mmcblk0p1',
  'Device Files' => '/dev/mmcblk0p1, /dev/disk/by-label/boot, /dev/disk/by-path/platform-3f202000.mmc-part1, /dev/disk/by-uuid/0C61-73F5, /dev/disk/by-id/mmc-SC16G_0xf097cc0d-part1, /dev/disk/by-partuuid/8978ce14-01',
  'Attached to' => '#20 (Disk)',
array (
  22 => 'None 00.0: 11300 Partition',
  'Unique ID' => 'CJka.SE1wIdpsiiC',
  'SysFS ID' => '/class/block/mmcblk0/mmcblk0p2',
  'Device File' => '/dev/mmcblk0p2',
  'Device Files' => '/dev/mmcblk0p2, /dev/disk/by-partuuid/8978ce14-02, /dev/disk/by-path/platform-3f202000.mmc-part2, /dev/disk/by-label/rootfs, /dev/disk/by-id/mmc-SC16G_0xf097cc0d-part2, /dev/disk/by-uuid/43f2d0bb-83be-464f-94d0-9a751f376c64',
array (
  25 => 'USB 00.0: 0700 Serial controller',
  '' => '[Created at usb.122]',
  'Unique ID' => 'dwDZ.vpwG5J6bhz8',
  'Parent ID' => 'ADDn.IKhPgutgmvF',
  'SysFS ID' => '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0',
  'SysFS BusID' => '1-1.3:1.0',
  'Hardware Class' => 'unknown',
  'Model' => '"Future Technology Devices International FT232 Serial (UART) IC"',
  'Hotplug' => 'USB',
  'Device' => 'usb 0x6001 "FT232 Serial (UART) IC"',
  'Revision' => '"6.00"',
  'Serial ID' => '"A10KMT5Q"',
  'Driver' => '"ftdi_sio"',
  'Driver Modules' => '"usbserial", "ftdi_sio"',
  'Device File' => '/dev/ttyUSB0',
  'Device Files' => '/dev/ttyUSB0, /dev/serial/by-path/platform-3f980000.usb-usb-0:1.3:1.0-port0, /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A10KMT5Q-if00-port0',
  'Device Number' => 'char 188:0',
  'Tags' => 'mouse, modem',
  'Speed' => '12 Mbps',
  'Module Alias' => '"usb:v0403p6001d0600dc00dsc00dp00icFFiscFFipFFin00"',
  'Driver Info #0' => '',
  'Driver Status' => 'ftdi_sio is active',
  'Driver Activation Cmd' => '"modprobe ftdi_sio"',
  'Attached to' => '#28 (Hub)',
array (
  26 => 'USB 00.0: 10a00 Hub',
  'Unique ID' => 'k4bc.D6ER+lJeRh3',
  'Parent ID' => '3t9U.TAOITtdfnIE',
  'SysFS ID' => '/devices/platform/soc/3f980000.usb/usb1/1-0:1.0',
  'SysFS BusID' => '1-0:1.0',
  'Hardware Class' => 'hub',
  'Model' => '"Linux Foundation 2.0 root hub"',
  'Hotplug' => 'USB',
  'Device' => 'usb 0x0002 "2.0 root hub"',
  'Revision' => '"5.10"',
  'Serial ID' => '"3f980000.usb"',
  'Driver' => '"hub"',
  'Speed' => '480 Mbps',
  'Module Alias' => '"usb:v1D6Bp0002d0510dc09dsc00dp01ic09isc00ip00in00"',
  'Attached to' => '#1 (USB Controller)',
array (
  27 => 'USB 00.0: 0200 Ethernet controller',
  'Unique ID' => 'lfzD.Sed3PcmdZ23',
  'SysFS ID' => '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1:1.0',
  'SysFS BusID' => '1-1.1:1.0',
  'Hardware Class' => 'network',
  'Model' => '"Standard Microsystems SMSC9512/9514 Fast Ethernet Adapter"',
  'Hotplug' => 'USB',
  'Vendor' => 'usb 0x0424 "Standard Microsystems Corp."',
  'Device' => 'usb 0xec00 "SMSC9512/9514 Fast Ethernet Adapter"',
  'Revision' => '"2.00"',
  'Driver' => '"smsc95xx"',
  'Driver Modules' => '"smsc95xx"',
  'Device File' => 'enxb827eb255ad9',
  'HW Address' => 'b8:27:eb:25:5a:d9',
  'Permanent HW Address' => 'b8:27:eb:25:5a:d9',
  'Link detected' => 'no',
  'Module Alias' => '"usb:v0424pEC00d0200dcFFdsc00dp01icFFisc00ipFFin00"',
array (
  28 => 'USB 00.0: 10a00 Hub',
  'Unique ID' => 'ADDn.IKhPgutgmvF',
  'Parent ID' => 'k4bc.D6ER+lJeRh3',
  'SysFS ID' => '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1:1.0',
  'SysFS BusID' => '1-1:1.0',
  'Model' => '"Standard Microsystems SMC9514 Hub"',
  'Hotplug' => 'USB',
  'Device' => 'usb 0x9514 "SMC9514 Hub"',
  'Module Alias' => '"usb:v0424p9514d0200dc09dsc00dp02ic09isc00ip02in00"',
  'Attached to' => '#26 (Hub)',
14.10. 23:29:59    -USB Devices:
array (
  1 =>
  array (
    'Device' => '0x6001',
    'File' => '/dev/ttyUSB0',
    'Driver' => 'ftdi_sio',
  2 =>
  array (
    'Device' => '0xec00',
    'File' => 'enxb827eb255ad9',
    'Model' => 'Standard Microsystems SMSC9512/9514 Fast Ethernet Adapter',
    'Driver Modules' => 'smsc95xx',
    'Driver' => 'smsc95xx',
  3 =>
  array (
    'Device' => '0x9514',
14.10. 23:29:59    -Regler: 57
14.10. 23:29:59    -Regler erkannt: /dev/ttyUSB0
14.10. 23:29:59    -Device: /dev/ttyUSB0 wird in die user.config.php eingetragen.
14.10. 23:29:59    -Zeile gefunden. USB Device kann ausgetauscht werden. Index: 584   $USBRegler         = "/dev/ttyUSB0";
14.10. 23:29:59    -Zeile gefunden. USB Device kann ausgetauscht werden. Index: 585   // $USBWechselrichter = "/dev/ttyUSB1";  // wird nicht mehr gebraucht.
14.10. 23:29:59    -Zeile gefunden. Raspberry Modell kann eingetragen werden. Index: 604   $Platine = "Raspberry Pi 3 Model B Rev 1.2";
14.10. 23:30:01 MQT-Pipe exestiert nicht. Nur Info, kein Fehler...Exit.
14.10. 23:30:02 |------------   Start  daly_bms.php    ----------------------------
14.10. 23:30:02    -USB Port: /dev/ttyUSB0
14.10. 23:30:06    -MQTT Daten zum [ 192.168.3.100 ] senden.
14.10. 23:30:06    -Pipe wird neu erstellt.
14.10. 23:30:06    -bms1/WattstundenGesamtHeute 0 rc: 31
14.10. 23:30:06    -bms1/zentralerTimestamp 1634247011 rc: 36
14.10. 23:30:06    -bms1/Batteriespannung 49.9 rc: 28
14.10. 23:30:06    -bms1/Spannung_Entladen 0 rc: 26
14.10. 23:30:06    -bms1/Ampere 0 rc: 15
14.10. 23:30:06    -bms1/SOC 17.1 rc: 15
14.10. 23:30:06    -bms1/Entladestrom 0 rc: 21
14.10. 23:30:06    -bms1/Ladestrom 0 rc: 18
14.10. 23:30:06    -bms1/Max_Spannung 3.124 rc: 25
14.10. 23:30:06    -bms1/Max_Spannung_ZellenNr 16 rc: 31
14.10. 23:30:06    -bms1/Min_Spannung 3.122 rc: 25
14.10. 23:30:06    -bms1/Min_Spannung_ZellenNr 1 rc: 30
14.10. 23:30:06    -bms1/Max_Temperatur 15 rc: 24
14.10. 23:30:06    -bms1/MaxTemp_ZellenNr 1 rc: 25
14.10. 23:30:06    -bms1/Min_Temperatur 15 rc: 24
14.10. 23:30:06    -bms1/MinTemp_ZellenNr 1 rc: 25
14.10. 23:30:06    -bms1/Ladung-Entladung 0 rc: 25
14.10. 23:30:06    -bms1/Ladung_MOS_Status 1 rc: 26
14.10. 23:30:06    -bms1/Entladung_MOS_Status 1 rc: 29
14.10. 23:30:06    -bms1/BMS_Zyklen 65 rc: 20
14.10. 23:30:06    -bms1/Ah_Rest 18.81 rc: 20
14.10. 23:30:06    -bms1/Zellenanzahl 16 rc: 22
14.10. 23:30:06    -bms1/Anz_TempSensoren 1 rc: 25
14.10. 23:30:06    -bms1/Entladestatus 0 rc: 22
14.10. 23:30:06    -bms1/Ladestatus 0 rc: 19
14.10. 23:30:06    -bms1/Lade/Entlade_Zyklen 5 rc: 28
14.10. 23:30:06    -bms1/FrameNr 1 rc: 16
14.10. 23:30:06    -bms1/Spannung_Zelle1 3.122 rc: 28
14.10. 23:30:06    -bms1/Spannung_Zelle2 3.122 rc: 28
14.10. 23:30:06    -bms1/Spannung_Zelle3 3.123 rc: 28
14.10. 23:30:06    -bms1/Spannung_Zelle4 3.122 rc: 28
14.10. 23:30:06    -bms1/Spannung_Zelle5 3.123 rc: 28
14.10. 23:30:06    -bms1/Spannung_Zelle6 3.124 rc: 28
14.10. 23:30:06    -bms1/Spannung_Zelle7 3.123 rc: 28
14.10. 23:30:06    -bms1/Spannung_Zelle8 3.123 rc: 28
14.10. 23:30:06    -bms1/Spannung_Zelle9 3.123 rc: 28
14.10. 23:30:06    -bms1/Spannung_Zelle10 3.124 rc: 29
14.10. 23:30:06    -bms1/Spannung_Zelle11 3.124 rc: 29
14.10. 23:30:06    -bms1/Spannung_Zelle12 3.124 rc: 29
14.10. 23:30:06    -bms1/Spannung_Zelle13 3.124 rc: 29
14.10. 23:30:06    -bms1/Spannung_Zelle14 3.124 rc: 29
14.10. 23:30:06    -bms1/Spannung_Zelle15 3.124 rc: 29
14.10. 23:30:06    -bms1/Spannung_Zelle16 3.125 rc: 29
14.10. 23:30:06    -bms1/Spannung_Zelle17 3.124 rc: 29
14.10. 23:30:06    -bms1/Spannung_Zelle18 3.124 rc: 29
14.10. 23:30:06    -bms1/Temperatur1 15 rc: 21
14.10. 23:30:06    -bms1/Temperatur2 13 rc: 21
14.10. 23:30:06    -bms1/Temperatur3 -28 rc: 22
14.10. 23:30:06    -bms1/Temperatur4 12 rc: 21
14.10. 23:30:06    -bms1/Temperatur5 -28 rc: 22
14.10. 23:30:06    -bms1/Temperatur6 12 rc: 21
14.10. 23:30:06    -bms1/Temperatur7 82 rc: 21
14.10. 23:30:06    -bms1/FehlerCode 0000400000000000 rc: 34
14.10. 23:30:06    -bms1/Regler 57 rc: 16
14.10. 23:30:06    -bms1/Objekt Garage rc: 20
14.10. 23:30:06    -bms1/Firmware 1.0 rc: 19
14.10. 23:30:06    -Alle 10 Minuten werden die Statistikdaten übertragen.
14.10. 23:30:06    -Curl Fehler[1]! Daten nicht zur lokalen InfluxDB solaranzeige gesendet! Curl ErrNo. 7
14.10. 23:30:06    -Lokale InfluxDB Fehler -> nochmal versuchen.
14.10. 23:30:06    -Curl Fehler[2]! Daten nicht zur lokalen InfluxDB solaranzeige gesendet! Curl ErrNo. 7
14.10. 23:30:06    -InfluxDB Fehler -> nochmal versuchen.
14.10. 23:31:08    -OK. Datenübertragung erfolgreich.
14.10. 23:31:08 |------------   Stop   daly_bms.php    ----------------------------
14.10. 23:31:08 |------------   Start  daly_bms.php    ----------------------------
14.10. 23:31:08    -USB Port: /dev/ttyUSB0
14.10. 23:31:12    -MQTT Daten zum [ 192.168.3.100 ] senden.
14.10. 23:31:12    -bms1/WattstundenGesamtHeute 0 rc: 31
14.10. 23:31:12    -bms1/zentralerTimestamp 1634247078 rc: 36
14.10. 23:31:12    -bms1/Batteriespannung 49.9 rc: 28
14.10. 23:31:12    -bms1/Spannung_Entladen 0 rc: 26
14.10. 23:31:12    -bms1/Ampere 0 rc: 15
14.10. 23:31:12    -bms1/SOC 17.1 rc: 15
14.10. 23:31:12    -bms1/Entladestrom 0 rc: 21
14.10. 23:31:12    -bms1/Ladestrom 0 rc: 18
14.10. 23:31:12    -bms1/Max_Spannung 3.124 rc: 25
14.10. 23:31:12    -bms1/Max_Spannung_ZellenNr 16 rc: 31
14.10. 23:31:12    -bms1/Min_Spannung 3.122 rc: 25
14.10. 23:31:12    -bms1/Min_Spannung_ZellenNr 1 rc: 30
14.10. 23:31:12    -bms1/Max_Temperatur 15 rc: 24
14.10. 23:31:12    -bms1/MaxTemp_ZellenNr 1 rc: 25
14.10. 23:31:12    -bms1/Min_Temperatur 15 rc: 24
14.10. 23:31:12    -bms1/MinTemp_ZellenNr 1 rc: 25
14.10. 23:31:12    -bms1/Ladung-Entladung 0 rc: 25
14.10. 23:31:12    -bms1/Ladung_MOS_Status 1 rc: 26
14.10. 23:31:12    -bms1/Entladung_MOS_Status 1 rc: 29
14.10. 23:31:12    -bms1/BMS_Zyklen 121 rc: 21
14.10. 23:31:12    -bms1/Ah_Rest 18.81 rc: 20
14.10. 23:31:12    -bms1/Zellenanzahl 16 rc: 22
14.10. 23:31:12    -bms1/Anz_TempSensoren 1 rc: 25
14.10. 23:31:12    -bms1/Entladestatus 0 rc: 22
14.10. 23:31:12    -bms1/Ladestatus 0 rc: 19
14.10. 23:31:12    -bms1/Lade/Entlade_Zyklen 5 rc: 28
14.10. 23:31:12    -bms1/FrameNr 1 rc: 16
14.10. 23:31:12    -bms1/Spannung_Zelle1 3.122 rc: 28
14.10. 23:31:12    -bms1/Spannung_Zelle2 3.122 rc: 28
14.10. 23:31:12    -bms1/Spannung_Zelle3 3.123 rc: 28
14.10. 23:31:12    -bms1/Spannung_Zelle4 3.123 rc: 28
14.10. 23:31:12    -bms1/Spannung_Zelle5 3.123 rc: 28
14.10. 23:31:12    -bms1/Spannung_Zelle6 3.123 rc: 28
14.10. 23:31:12    -bms1/Spannung_Zelle7 3.123 rc: 28
14.10. 23:31:12    -bms1/Spannung_Zelle8 3.123 rc: 28
14.10. 23:31:12    -bms1/Spannung_Zelle9 3.123 rc: 28
14.10. 23:31:12    -bms1/Spannung_Zelle10 3.123 rc: 29
14.10. 23:31:12    -bms1/Spannung_Zelle11 3.124 rc: 29
14.10. 23:31:12    -bms1/Spannung_Zelle12 3.124 rc: 29
14.10. 23:31:12    -bms1/Spannung_Zelle13 3.124 rc: 29
14.10. 23:31:12    -bms1/Spannung_Zelle14 3.124 rc: 29
14.10. 23:31:12    -bms1/Spannung_Zelle15 3.124 rc: 29
14.10. 23:31:12    -bms1/Spannung_Zelle16 3.125 rc: 29
14.10. 23:31:12    -bms1/Spannung_Zelle17 3.124 rc: 29
14.10. 23:31:12    -bms1/Spannung_Zelle18 3.124 rc: 29
14.10. 23:31:12    -bms1/Temperatur1 15 rc: 21
14.10. 23:31:12    -bms1/Temperatur2 13 rc: 21
14.10. 23:31:12    -bms1/Temperatur3 -28 rc: 22
14.10. 23:31:12    -bms1/Temperatur4 12 rc: 21
14.10. 23:31:12    -bms1/Temperatur5 -28 rc: 22
14.10. 23:31:12    -bms1/Temperatur6 12 rc: 21
14.10. 23:31:12    -bms1/Temperatur7 82 rc: 21
14.10. 23:31:12    -bms1/FehlerCode 0000400000000000 rc: 34
14.10. 23:31:12    -bms1/Regler 57 rc: 16
14.10. 23:31:12    -bms1/Objekt Garage rc: 20
14.10. 23:31:12    -bms1/Firmware 1.0 rc: 19
14.10. 23:31:13 *  -Daten zur lokalen InfluxDB [ solaranzeige ] gesendet.
14.10. 23:31:14 MQT-MQTT Daten zum Broker gesendet: 192.168.3.100 Port: 1886
14.10. 23:32:04    -OK. Datenübertragung erfolgreich.
14.10. 23:32:04 |------------   Stop   daly_bms.php    ----------------------------
daly_bms.php
(16.65 KiB) 478-mal heruntergeladen
funktionen.inc.php
(291.41 KiB) 466-mal heruntergeladen
MichaelBerlin
Beitrag von MichaelBerlin »
Die funktionen.inc.php wird immer beim ausführen von Setup in die Originalversion geändert.
Und beim Daly muss der Parameter für den sleep modus auf maximum gesetzt werden.
Laut einem enrl. Forum 15300 für 4S Daly und 65535 für 16S Daly.
Wenn das Daly in den Sleepmodus geht bekommt Solaranzeige keine Daten mehr und die Ausgabe stockt bei Befehl 90.
14.10. 23:12:01 |------------   Start  daly_bms.php    ----------------------------
14.10. 23:12:01    -USB Port: /dev/ttyUSB0
14.10. 23:12:05 *  -Daten zur lokalen InfluxDB [ solaranzeige ] gesendet.
14.10. 23:12:05    -Multi-Regler-Ausgang. 3
14.10. 23:12:08    -OK. Datenübertragung erfolgreich.
14.10. 23:12:08 |------------   Stop   daly_bms.php    ----------------------------
14.10. 23:13:02 |------------   Start  daly_bms.php    ----------------------------
14.10. 23:13:02    -USB Port: /dev/ttyUSB0
14.10. 23:13:06 *  -Daten zur lokalen InfluxDB [ solaranzeige ] gesendet.
14.10. 23:13:06    -Multi-Regler-Ausgang. 3
14.10. 23:13:09    -OK. Datenübertragung erfolgreich.
14.10. 23:13:09 |------------   Stop   daly_bms.php    ----------------------------
                                     Daly geht in den Sleep Modus
14.10. 23:14:01 |------------   Start  daly_bms.php    ----------------------------
14.10. 23:14:01    -USB Port: /dev/ttyUSB0
14.10. 23:14:03 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:14:05 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:14:07 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:14:09 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:14:11 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:14:13 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:14:15 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:14:17 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:14:19 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:14:21 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:14:21 !! -Keine gültigen Daten empfangen.
14.10. 23:14:21 |------------   Stop   daly_bms.php    ----------------------------
14.10. 23:15:01 |------------   Start  daly_bms.php    ----------------------------
14.10. 23:15:01    -USB Port: /dev/ttyUSB0
14.10. 23:15:03 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:15:05 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:15:07 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:15:09 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:15:11 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:15:13 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:15:15 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:15:17 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:15:19 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:15:21 !! -Datenfehler 90, nochmal... a54090080000000000000000
14.10. 23:15:21 !! -Keine gültigen Daten empfangen.
14.10. 23:15:21 |------------   Stop   daly_bms.php    ----------------------------
e-i-k-e
das mit der funktionen.inc.php weiß ich nicht, kann gut sein das es so ist. Heißt also, dass dies nur durch Ulrich - durch eine Update angepasst werden kann?
Auf meiner Testumgebung scheint es nun zu laufen. :)
Und ich kann bestätigen, dass der originale Daly RS485 Adapter für diese Anwendung funktioniert!
MichaelBerlin
Bei mir läuft der originale UART zu USB Adapter von den Chinesen mitgelieferte.
LG Michael
simon.s
Hat sich bedankt: 3 Mal
Danksagung erhalten: 6 Mal
Beitrag von simon.s »
Super daß es jetzt läuft!
Den Sleep-modus kenne ich nicht, hatte noch nie das Problem daß das Teil eingeschlafen wäre......
Weiters arbeite ich mit WinSCP, kann so direkt von meinem PC per ssh auf die Daten zugreifen (Notepad++), angemeldet über root. Somit keine
Probleme mit den Rechten. (am PI Testgerät).
So Jetzt noch zu Grafana, dort muß ich die Abfrage der einzellnen Zellspannungen zb
SELECT field "Z3V"
nach
SELECT field "Spannung Zelle 3"
ändern. ist das bei euch auch so?
Edit:
habe gerade nochmals einen Test gemacht, die Adresse "80" funktioniert bei mir definitiv nicht!
Wird mit dem Fehler "15.10. 09:06:11 !! -Datenfehler, nochmal... a58095080000000000000000" quitiert.
8-) Ich wohne da wo Ihr Urlaub macht 8-)
Axpert Max 8k + 16S DalyBMS
Beitrag von solarfanenrico »
e-i-k-e hat geschrieben:
Fr 15. Okt 2021, 00:43
Hallo e-l-k-e,
ich kann bestätigen, daß bei einem solaranzeigen_update auch die /phpinc/funktionen.inc.php überschrieben wird.
Auszug aus update.log
01.10. 14:39:05 Update wird durchgeführt.
01.10. 14:39:06 o-> Datei /phpinc/funktionen.inc.php wird kopiert.
01.10. 14:39:07 o-> Datei /etc/motd wird kopiert.
01.10. 14:39:07 o-> Datei go-e_wallbox.php wird kopiert.
01.10. 14:39:07 o-> Datei steca_solarregler.php wird kopiert.
01.10. 14:39:07 o-> Datei simple_evse.php wird kopiert.
01.10. 14:39:07 o-> Datei delta_wechselrichter.php wird kopiert.
01.10. 14:39:07 o-> Datei fehler.php wird kopiert.
01.10. 14:39:07 o-> Datei kostal_plenticore.php wird kopiert.
01.10. 14:39:08 o-> Datei joulie_16_bms.php wird kopiert.
01.10. 14:39:08 o-> Datei SDM230_meter.php wird kopiert.
01.10. 14:39:08 o-> Datei webasto_wb.php wird kopiert.
01.10. 14:39:08 o-> Datei webui.php wird kopiert.
01.10. 14:39:08 o-> Datei hrdi_laderegler.php wird kopiert.
01.10. 14:39:08 o-> Datei keba_wallbox.php wird kopiert.
01.10. 14:39:08 o-> Datei wallbox.steuerung.ini.neu wird kopiert.
01.10. 14:39:09 o-> Datei alpha_ess.php wird kopiert.
01.10. 14:39:09 o-> Datei infini_p16.php wird kopiert.
01.10. 14:39:09 o-> Datei rover_renogy.php wird kopiert.
01.10. 14:39:09 o-> Datei sma_energy.php wird kopiert.
01.10. 14:39:09 o-> Datei pv18_vhm_serie.php wird kopiert.
01.10. 14:39:09 o-> Datei infini_v_serie.php wird kopiert.
01.10. 14:39:09 o-> Datei tracer_regler.php wird kopiert.
01.10. 14:39:10 o-> Datei victron_solarregler.php wird kopiert.
01.10. 14:39:10 o-> Datei mqtt_senden.php wird kopiert.
01.10. 14:39:10 o-> Datei solaredge_smartmeter.php wird kopiert.
01.10. 14:39:10 o-> Datei phocos_any_grid.php wird kopiert.
01.10. 14:39:10 o-> Datei ax_wechselrichter.php wird kopiert.
01.10. 14:39:10 o-> Datei sonoff_mqtt.php wird kopiert.
01.10. 14:39:10 o-> Datei goodwe_ET.php wird kopiert.
01.10. 14:39:11 o-> Datei qpi_p30.php wird kopiert.
01.10. 14:39:11 o-> Datei openWB.php wird kopiert.
01.10. 14:39:11 o-> Datei regler_auslesen.php wird kopiert.
01.10. 14:39:11 o-> Datei cFos_wb.php wird kopiert.
Falls Ulrich die, in diesem Thread geänderten Dinge, übernimmt ist es kein Problem. Bis dahin ist es besser, sich seine Version zu sichern, damit man es später wieder nutzen kann. Sonst geht die Suche von vorn los.
Hat sich bedankt: 167 Mal
Danksagung erhalten: 822 Mal
Wenn jemand das Problem erkannt und gelöst hat, bitte per eMail melden. Danke.
e-i-k-e
simon.s hat geschrieben:
Fr 15. Okt 2021, 08:43
SELECT field "Z3V"
nach
Edit:
Also ich verwende die fertige Daly Vorlage für Grafana und musste nichts anpassen.
simon.s
Ulrich hat geschrieben:
Fr 15. Okt 2021, 20:15
Mein Vorschlag wäre wir testen dies zuvor noch ca 10 Tage, und teilen Ulrich die Änderungen dann mit.
Was haltet ihr davon?
Gibts ein Daly??? habe nur das Joulie-16 BMS im petto. werd ein Update brauchen :lol:
e-i-k-e
Ja das finde ich gut!
Es gibt tatsächlich eine Vorlage, ich glaub in Grafana unter sonstiges. ;) Ich verwende die aktuelle Version.
