chmod +x /usr/lib/influxdb/scripts/influxd-systemd-start.sh
Das Problem ist, dass in der influx 1.8.7 eine zusätzliche Bash-Start-Datei benötigt wird, die nicht die korrekten Rechte zum Ausführen hat.
influxdb.service - InfluxDB is an open-source, distributed, time series database
Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2021-08-01 10:53:56 CEST; 1min 4s ago
Docs: https://docs.influxdata.com/influxdb/
Process: 470 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
Main PID: 488 (influxd)
Tasks: 14 (limit: 3258)
CGroup: /system.slice/influxdb.service
└─488 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
Aug 01 10:54:54 Solaranzeige influxd-systemd-start.sh[470]: ts=2021-08-01T08:54:54.715731Z lvl=info msg="Opened file" log_id=0VhEZEdG000 engine=tsm1 service=filestore path=/var/lib/influxdb/dat
Aug 01 10:54:54 Solaranzeige influxd-systemd-start.sh[470]: ts=2021-08-01T08:54:54.715831Z lvl=info msg="Opened file" log_id=0VhEZEdG000 engine=tsm1 service=filestore path=/var/lib/influxdb/dat
Aug 01 10:54:54 Solaranzeige influxd-systemd-start.sh[470]: ts=2021-08-01T08:54:54.717420Z lvl=info msg="Opened file" log_id=0VhEZEdG000 engine=tsm1 service=filestore path=/var/lib/influxdb/dat
Aug 01 10:54:54 Solaranzeige influxd-systemd-start.sh[470]: ts=2021-08-01T08:54:54.717846Z lvl=info msg="Opened file" log_id=0VhEZEdG000 engine=tsm1 service=filestore path=/var/lib/influxdb/dat
Aug 01 10:54:54 Solaranzeige influxd-systemd-start.sh[470]: ts=2021-08-01T08:54:54.790588Z lvl=info msg="Write failed" log_id=0VhEZEdG000 service=write shard=441 error="[shard 441] open /var/li
Aug 01 10:54:54 Solaranzeige influxd-systemd-start.sh[470]: ts=2021-08-01T08:54:54.790698Z lvl=info msg="failed to store statistics" log_id=0VhEZEdG000 service=monitor error="[shard 441] open /
Aug 01 10:54:57 Solaranzeige influxd-systemd-start.sh[470]: ts=2021-08-01T08:54:57.278959Z lvl=info msg="Write failed" log_id=0VhEZEdG000 service=write shard=434 error="[shard 434] open /var/li
Aug 01 10:54:57 Solaranzeige influxd-systemd-start.sh[470]: [httpd] ::1 - - [01/Aug/2021:10:54:57 +0200] "POST /write?db=solaranzeige&precision=s HTTP/1.1 " 500 106 "-" "-" 2582fe8b-f2a6-11eb-8
Aug 01 10:54:57 Solaranzeige influxd-systemd-start.sh[470]: ts=2021-08-01T08:54:57.279409Z lvl=error msg="[500] - \"[shard 434] open /var/lib/influxdb/wal/solaranzeige/autogen/434/_00016.wal: p
Hallo Ulrich, es scheint danach noch ein "Permission" Problem zu geben. Der Dienst startet sauber, aber das Schreiben in die DB ist offenbar nicht möglich.Ulrich hat geschrieben: ↑So 1. Aug 2021, 10:45Könnt ihr bitte einmal auf der Konsole folgendes eingeben:
Danach sollte der Fehler behoben sein.Code: Alles auswählen
Active: active (running) since Sun 2021-08-01 11:01:29 CEST; 5h 9min ago
Process: 479 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
Main PID: 483 (influxd)
Tasks: 15 (limit: 3258)
└─483 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
Aug 01 16:10:12 Solaranzeige influxd-systemd-start.sh[479]: [httpd] ::1 - - [01/Aug/2021:16:10:02 +0200] "POST /write?db=solaranzeige&precision=s HTTP/1.1 " 500 2
Aug 01 16:10:12 Solaranzeige influxd-systemd-start.sh[479]: ts=2021-08-01T14:10:12.332277Z lvl=error msg="[500] - \"timeout\"" log_id=0VhEzpO0000 service=httpd
Aug 01 16:10:17 Solaranzeige influxd-systemd-start.sh[479]: [httpd] ::1 - - [01/Aug/2021:16:10:07 +0200] "POST /write?db=solaranzeige&precision=s HTTP/1.1 " 500 2
Aug 01 16:10:17 Solaranzeige influxd-systemd-start.sh[479]: ts=2021-08-01T14:10:17.333153Z lvl=error msg="[500] - \"timeout\"" log_id=0VhEzpO0000 service=httpd
Aug 01 16:10:22 Solaranzeige influxd-systemd-start.sh[479]: [httpd] ::1 - - [01/Aug/2021:16:10:12 +0200] "POST /write?db=solaranzeige&precision=s HTTP/1.1 " 500 2
Aug 01 16:10:22 Solaranzeige influxd-systemd-start.sh[479]: ts=2021-08-01T14:10:22.337388Z lvl=error msg="[500] - \"timeout\"" log_id=0VhEzpO0000 service=httpd
Aug 01 16:10:30 Solaranzeige influxd-systemd-start.sh[479]: [httpd] ::1 - - [01/Aug/2021:16:10:20 +0200] "POST /write?db=solaranzeige&precision=s HTTP/1.1 " 500 2
Aug 01 16:10:30 Solaranzeige influxd-systemd-start.sh[479]: ts=2021-08-01T14:10:30.338697Z lvl=error msg="[500] - \"timeout\"" log_id=0VhEzpO0000 service=httpd
Aug 01 16:10:47 Solaranzeige influxd-systemd-start.sh[479]: [httpd] ::1 - - [01/Aug/2021:16:10:37 +0200] "POST /write?db=solaranzeige&precision=s HTTP/1.1 " 500 2
Aug 01 16:10:47 Solaranzeige influxd-systemd-start.sh[479]: ts=2021-08-01T14:10:47.637708Z lvl=error msg="[500] - \"timeout\"" log_id=0VhEzpO0000 service=httpd
Hattest du den Service auch mitmasterflai hat geschrieben: ↑So 1. Aug 2021, 13:26Hallo Ulrich, es scheint danach noch ein "Permission" Problem zu geben. Der Dienst startet sauber, aber das Schreiben in die DB ist offenbar nicht möglich.Ulrich hat geschrieben: ↑So 1. Aug 2021, 10:45Könnt ihr bitte einmal auf der Konsole folgendes eingeben:
sudo systemctl start influxdb
Ja, hatte ich gemacht. Auch ein Reboot brachte keinen Erfolg.stdt hat geschrieben: ↑So 1. Aug 2021, 20:34Hattest du den Service auch mitmasterflai hat geschrieben: ↑So 1. Aug 2021, 13:26Hallo Ulrich, es scheint danach noch ein "Permission" Problem zu geben. Der Dienst startet sauber, aber das Schreiben in die DB ist offenbar nicht möglich.Ulrich hat geschrieben: ↑So 1. Aug 2021, 10:45Könnt ihr bitte einmal auf der Konsole folgendes eingeben:
Das Problem ist, dass in der influx 1.8.7 eine zusätzliche Bash-Start-Datei benötigt wird, die nicht die korrekten Rechte zum Ausführen hat.wieder gestartet?Code: Alles auswählen
sudo systemctl stop influxdb # Sollte ohnehin nicht laufen
sudo systemctl disable influxdb
sudo systemctl daemon-reload
sudo apt autoremove influxdb
sudo apt-get install influxdb
sudo chmod +x /usr/lib/influxdb/scripts/influxd-systemd-start.sh
sudo systemctl unmask influxdb.service
sudo systemctl enable influxdb.service
Mitglieder in diesem Forum: Google [Bot] und 0 Gäste
