#Axpert Commands and examples
#Q1		# Undocumented command: LocalInverterStatus (seconds from absorb), ParaExistInfo (seconds from end of Float), SccOkFlag, AllowSccOnFlag, ChargeAverageCurrent, SCC PWM Temperature, Inverter Temperature, Battery Temperature, Transformer Temperature, GPDAT, FanLockStatus, FanPWMDuty, FanPWM, SCCChargePowerWatts, ParaWarning, SYNFreq, InverterChargeStatus
#QPI            # Device protocol ID inquiry
#QID            # The device serial number inquiry
#QVFW           # Main CPU Firmware version inquiry
#QVFW2          # Another CPU Firmware version inquiry
#QFLAG          # Device flag status inquiry
#QPIGS          # Device general status parameters inquiry
                # GridVoltage, GridFrequency, OutputVoltage, OutputFrequency, OutputApparentPower, OutputActivePower, OutputLoadPercent, BusVoltage, BatteryVoltage, BatteryChargingCurrent, BatteryCapacity, InverterHeatSinkTemperature, PV-InputCurrentForBattery, PV-InputVoltage, BatteryVoltageFromSCC, BatteryDischargeCurrent, DeviceStatus,
#QMOD           # Device mode inquiry P: PowerOnMode, S: StandbyMode, L: LineMode, B: BatteryMode, F: FaultMode, H: PowerSavingMode
#QPIWS          # Device warning status inquiry: Reserved, InverterFault, BusOver, BusUnder, BusSoftFail, LineFail, OPVShort, InverterVoltageTooLow, InverterVoltageTooHIGH, OverTemperature, FanLocked, BatteryVoltageHigh, BatteryLowAlarm, Reserved, ButteryUnderShutdown, Reserved, OverLoad, EEPROMFault, InverterSoftFail, SelfTestFail, OPDCVoltageOver, BatOpen, CurrentSensorFail, BatteryShort, PowerLimit, PVVoltageHigh, MPPTOverloadFault, MPPTOverloadWarning, BatteryTooLowToCharge, Reserved, Reserved
#QDI            # The default setting value information
#QMCHGCR        # Enquiry selectable value about max charging current
#QMUCHGCR       # Enquiry selectable value about max utility charging current
#QBOOT          # Enquiry DSP has bootstrap or not
#QOPM           # Enquiry output mode
#QPIRI          # Device rating information inquiry - nefunguje
#QPGS0          # Parallel information inquiry
                # TheParallelNumber, SerialNumber, WorkMode, FaultCode, GridVoltage, GridFrequency, OutputVoltage, OutputFrequency, OutputAparentPower, OutputActivePower, LoadPercentage, BatteryVoltage, BatteryChargingCurrent, BatteryCapacity, PV-InputVoltage, TotalChargingCurrent, Total-AC-OutputApparentPower, Total-AC-OutputActivePower, Total-AC-OutputPercentage, InverterStatus, OutputMode, ChargerSourcePriority, MaxChargeCurrent, MaxChargerRange, Max-AC-ChargerCurrent, PV-InputCurrentForBattery, BatteryDischargeCurrent
#QBV		# Compensated Voltage, SoC
#PEXXX          # Setting some status enable
#PDXXX          # Setting some status disable
#PF             # Setting control parameter to default value
#FXX            # Setting device output rating frequency
#POP02          # set to SBU
#POP01          # set to Solar First
#POP00          # Set to UTILITY
#PBCVXX_X       # Set battery re-charge voltage
#PBDVXX_X       # Set battery re-discharge voltage
#PCP00          # Setting device charger priority: Utility First
#PCP01          # Setting device charger priority: Solar First
#PCP02          # Setting device charger priority: Solar and Utility
#PGRXX          # Setting device grid working range
#PBTXX          # Setting battery type
#PSDVXX_X       # Setting battery cut-off voltage
#PCVVXX_X       # Setting battery C.V. charging voltage
#PBFTXX_X       # Setting battery float charging voltage
#PPVOCKCX       # Setting PV OK condition
#PSPBX          # Setting solar power balance
#MCHGC0XX       # Setting max charging Current          M XX
#MUCHGC002      # Setting utility max charging current  0 02
#MUCHGC010      # Setting utility max charging current  0 10
#MUCHGC020      # Setting utility max charging current  0 20
#MUCHGC030      # Setting utility max charging current  0 30
#POPMMX         # Set output mode       M 0:single, 1: parrallel, 2: PH1, 3: PH2, 4: PH3
#notworking
#PPCP000        # Setting parallel device charger priority: UtilityFirst - notworking
#PPCP001        # Setting parallel device charger priority: SolarFirst - notworking
#PPCP002        # Setting parallel device charger priority: OnlySolarCharging - notworking
