Hilfe bei Wlan Steckdosen mit Tasmota / MQTT
Die Verbindung zum Smart Home und Internet der Dinge (IoT)
the_mfred
Hat sich bedankt: 9 Mal
Beitrag von the_mfred »
ich habe 2 WLan Steckdosen mit Tasmota FW. Diese habe ich per MQTT zur Solaranzeige verbunden. Daten kommen auch an:
 $ mosquitto_sub -h localhost -v -t +/#
sonoff/tele/LWT Offline
Sonoff/tele/LWT Offline
tele/delock/LWT Online
tele/delock2/LWT Offline
tele/delock3/LWT Online
tele/delock/STATE {"Time":"2022-04-05T20:57:54","Uptime":"4T05:35:41","UptimeSec":365741,"Vcc":3.533,"Heap":22,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":36,"MqttCount":48,"POWER":"ON","Wifi":{"AP":1,"SSId":"SSID","BSSId":"40:B0:76:36:9E:39","Channel":11,"RSSI":74,"Signal":-63,"LinkCount":9,"Downtime":"0T01:49:28"}}
tele/delock/SENSOR {"Time":"2022-04-05T20:57:54","ENERGY":{"TotalStartTime":"2022-03-29T19:41:02","Total":9.428,"Yesterday":1.204,"Today":1.067,"Period":3,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":223,"Current":0.000}}
tele/delock3/STATE {"Time":"2022-04-05T20:57:56","Uptime":"0T00:20:49","UptimeSec":1249,"Vcc":3.510,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":6,"POWER":"ON","Wifi":{"AP":1,"SSId":"SSID","BSSId":"40:B0:76:36:9E:39","Channel":11,"RSSI":66,"Signal":-67,"LinkCount":5,"Downtime":"0T00:02:48"}}
tele/delock3/SENSOR {"Time":"2022-04-05T20:57:56","ENERGY":{"TotalStartTime":"2022-03-30T19:33:57","Total":2.982,"Yesterday":0.616,"Today":0.635,"Period":0,"Power":1,"ApparentPower":19,"ReactivePower":19,"Factor":0.06,"Voltage":224,"Current":0.085}}
Nur jetzt weiß ich nicht mehr wie es weitergeht.
Mein allgemeiner MQTT in der user.config.php
$MQTT = true;
$MQTTBroker = "localhost";
$MQTTPort = 1883;
$MQTTBenutzer = "";
$MQTTKennwort = "";
$MQTTSSL = false;
$MQTTKeepAlive = 60;
$MQTTGeraet = "box1";
$MQTTAuswahl = "";
Danach habe ich verschiedenes ausprobiert. Einerseits:
$Topic = "delock";
(Topic Name von Tasmota)
dann passiert aber nichts bzw wüsste ich nicht, wie ich die Daten in Grafana abrufen kann.
Was ich auch noch getestet habe war ein:
$MQTTTopic[2] = "solaranzeige/anzeige/delock/#"
$MQTTTopic[3] = "solaranzeige/anzeige/delock3/#"
nur stoppt dann sofort die Verarbeitung und es kommt kein output mehr in das solaranzeige.log File.
Muss ich noch etwas zusätzlich beachten? Aus der MQTT Doku werde ich nicht schlauer.
Übersicht der Dokumentationen (weil ich sie nie selbst schnell finde wenn ich sie benötige :)
Danksagung erhalten: 923 Mal
Re: Hilfe bei Wlan Steckdosen mit Tasmota / MQTT
Wie man ein Sonoff Gerät mit TASMOTA Firmware anbindet, steht hier ganz genau beschrieben:
https://solaranzeige.de/phpBB3/download ... hboard.pdf
the_mfred
Tut mir leid, aber da finde ich keine brauchbaren Zusatzinfos.
Das Topic ist gesetzt und gleich dem Topic in Tasmota. Das habe ich alles gemacht. Gleich geschrieben ist es auch.
Aber wie geht's weiter? Wie erstelle ich nun zB eine Timeline mit dem Stromverbrauch?
Einfach das richtige Dashboard aufrufen, dann sollte die Timeline zu sehen sein. Welche WLAN-Steckdose hast du denn in Betrieb? Wird sie von der Solaranzeige unterstützt?
Schaue auch einmal in die LOG Datei, was da steht:
/var/www/log/solaranzeige.log
the_mfred
Hi, im Logfile steht nichts was mir hilft:
07.04. 10:24:02 |----------------   Start  huawei_LAN.php  -----------------------------
07.04. 10:24:07 >  -Gerätetyp: SUN2000-10KTL-M1  Modell ID: 429
07.04. 10:24:11 >  -Alarm 1 Bits: 0000000000000000
07.04. 10:24:34    -MQTT Daten zum [ localhost ] senden.
07.04. 10:24:34 *  -Daten zur lokalen InfluxDB [ solaranzeige ] gesendet.
07.04. 10:24:34    -Multi-Regler-Ausgang. -23
07.04. 10:24:34    -OK. Datenübertragung erfolgreich.
07.04. 10:24:34 |----------------   Stop   huawei_LAN.php    ---------------------------
07.04. 10:24:35 MQT-MQTT Daten zum Broker gesendet: localhost Port: 1883
An Dashboards finde ich lediglich das Sonoff POW, die Statements dort greifen aber nur AC ab, was die Daten des WR sind. zB:
SELECT mean("Leistung") FROM "AC" WHERE $timeFilter GROUP BY time($__interval) fill(linear)
Das Dashboard musst du dir selber erstellen, nach deinen eigenen Wünschen.
Schaue einmal bitte direkt in die Datenbank, dort findest du alle Werte, die gespeichert werden und die du in deinem Dashboard nutzen kannst..
Zurück zu „MQTT und der Rest der Welt“
