Ich habe es jetzt mal mit QEmu versucht.
Aktuelles solaranzeigeimage runtergeladen.
Dann bei
https://github.com/dhruvvyas90/qemu-rpi-kernel Kernel und versatile runtergeladen.
Dann
qemu-system-arm \
 -kernel ./kernel/kernel-qemu-5.4.51-buster \
 -dtb ./kernel/versatile-pb-buster-5.4.51.dtb \
 -cpu arm1176 \
 -m 256 \
 -M versatilepb \
 -serial stdio \
 -net nic \
 -net user,hostfwd=tcp::9022-:22,hostfwd=tcp::9001-:8001,hostfwd=tcp::9433-:433  \
 -append "rw console=ttyAMA0 root=/dev/sda2 rootfstype=ext4 loglevel=8 rootwait fsck.repair=yes memtest=1" \
 -drive file=Solaranzeige_V4.7.1.img,format=raw
ausgeführt.
Dann erscheint diese Ausgabe:
vpb_sic_write: Bad register offset 0x2c
Booting Linux on physical CPU 0x0
Linux version 5.4.51 (mxgxw@mxgxw-msi) (gcc version 10.1.0 (GCC)) #1 Sat Aug 8 23:28:32 +03 2020
CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
CPU: VIPT aliasing data cache, unknown instruction cache
OF: fdt: Machine model: ARM Versatile PB
Memory policy: Data cache writeback
On node 0 totalpages: 65536
  Normal zone: 576 pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 65536 pages, LIFO batch:15
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists, mobility grouping on.  Total pages: 64960
Kernel command line: rw console=ttyAMA0 root=/dev/sda2 rootfstype=ext4 loglevel=8 rootwait fsck.repair=yes memtest=1
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
mem auto-init: stack:off, heap alloc:off, heap free:off
Memory: 248260K/262144K available (6169K kernel code, 220K rwdata, 4336K rodata, 204K init, 147K bss, 13884K reserved, 0K cma-reserved)
NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
VIC @(ptrval): id 0x00041190, vendor 0x41
FPGA IRQ chip 0 "intc" @ (ptrval), 20 irqs, parent IRQ: 47
random: get_random_bytes called from start_kernel+0x248/0x458 with crng_init=0
clocksource: arm,sp804: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
Failed to initialize '/amba/timer@101e3000': -22
sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
Console: colour dummy device 80x30
Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
Disabling memory control group subsystem
CPU: Testing write buffer coherency: ok
Setting up static identity map for 0x8220 - 0x827c
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 256 (order: -1, 3072 bytes, linear)
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
OF: amba_device_add() failed (-19) for /amba/smc@10100000
OF: amba_device_add() failed (-19) for /amba/mpmc@10110000
OF: amba_device_add() failed (-19) for /amba/sctl@101e0000
OF: amba_device_add() failed (-19) for /amba/watchdog@101e1000
OF: amba_device_add() failed (-19) for /amba/sci@101f0000
OF: amba_device_add() failed (-19) for /amba/spi@101f4000
OF: amba_device_add() failed (-19) for /amba/fpga/sci@a000
Serial: AMBA PL011 UART driver
101f1000.uart: ttyAMA0 at MMIO 0x101f1000 (irq = 28, base_baud = 0) is a PL011 rev1
printk: console [ttyAMA0] enabled
101f2000.uart: ttyAMA1 at MMIO 0x101f2000 (irq = 29, base_baud = 0) is a PL011 rev1
101f3000.uart: ttyAMA2 at MMIO 0x101f3000 (irq = 30, base_baud = 0) is a PL011 rev1
10009000.uart: ttyAMA3 at MMIO 0x10009000 (irq = 54, base_baud = 0) is a PL011 rev1
vgaarb: loaded
SCSI subsystem initialized
libata version 3.00 loaded.
clocksource: Switched to clocksource arm,sp804
NET: Registered protocol family 2
tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
TCP established hash table entries: 2048 (order: 1, 8192 bytes, linear)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes, linear)
TCP: Hash tables configured (established 2048 bind 2048)
UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 32
NetWinder Floating Point Emulator V0.97 (double precision)
workingset: timestamp_bits=14 max_order=16 bucket_order=2
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
romfs: ROMFS MTD (C) 2007 Red Hat, Inc.
9p: Installing v9fs 9p2000 file system support
Block layer SCSI Wortzensur (bsg) driver version 0.4 loaded (major 252)
io scheduler mq-deadline registered
io scheduler kyber registered
pl061_gpio 101e4000.gpio: PL061 GPIO chip registered
pl061_gpio 101e5000.gpio: PL061 GPIO chip registered
pl061_gpio 101e6000.gpio: PL061 GPIO chip registered
pl061_gpio 101e7000.gpio: PL061 GPIO chip registered
versatile-pci 10001000.pci: host bridge /amba/pci@10001000 ranges:
versatile-pci 10001000.pci:       IO 0x0043000000..0x004300ffff -> 0x0000000000
versatile-pci 10001000.pci:      MEM 0x0050000000..0x005fffffff -> 0x0050000000
versatile-pci 10001000.pci:      MEM 0x0060000000..0x006fffffff -> 0x0060000000
versatile-pci 10001000.pci: PCI core found (slot 11)
versatile-pci 10001000.pci: PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [bus 00-ff]
pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
pci_bus 0000:00: root bus resource [mem 0x50000000-0x5fffffff]
pci_bus 0000:00: root bus resource [mem 0x60000000-0x6fffffff pref]
pci 0000:00:0c.0: [1000:0012] type 00 class 0x010000
pci 0000:00:0c.0: reg 0x10: [io  0x0000-0x00ff]
pci 0000:00:0c.0: reg 0x14: [mem 0x00000000-0x000003ff]
pci 0000:00:0c.0: reg 0x18: [mem 0x00000000-0x00001fff]
PCI: bus0: Fast back to back transfers disabled
pci 0000:00:0c.0: BAR 2: assigned [mem 0x50000000-0x50001fff]
pci 0000:00:0c.0: BAR 1: assigned [mem 0x50002000-0x500023ff]
pci 0000:00:0c.0: BAR 0: assigned [io  0x1000-0x10ff]
versatile-tft-panel 10000000.sysreg:display@0: no panel detected
drm-clcd-pl111 10120000.display: set up callbacks for Versatile PL110
drm-clcd-pl111 10120000.display: found bridge on endpoint 1
drm-clcd-pl111 10120000.display: Using non-panel bridge
[drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[drm] No driver support for vblank timestamp query.
[drm] Initialized pl111 1.0.0 20170317 for 10120000.display on minor 0
drm-clcd-pl111 10120000.display: enable Versatile CLCD connectors
Console: switching to colour frame buffer device 100x37
drm-clcd-pl111 10120000.display: fb0: pl111drmfb frame buffer device
brd: module loaded
loop: module loaded
sym53c8xx 0000:00:0c.0: enabling device (0100 -> 0103)
sym0: <895a> rev 0x0 at pci 0000:00:0c.0 irq 66
sym0: No NVRAM, ID 7, Fast-40, ??, parity checking
CACHE TEST FAILED: timeout.
sym0: CACHE INCORRECTLY CONFIGURED.
sym0: giving up ...
------------[ cut here ]------------
WARNING: CPU: 0 PID: 1 at kernel/dma/mapping.c:337 dma_free_attrs+0xb8/0xc8
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.51 #1
Hardware name: ARM-Versatile (Device Tree Support)
[<c001c84c>] (unwind_backtrace) from [<c0018738>] (show_stack+0x10/0x14)
[<c0018738>] (show_stack) from [<c0025588>] (__warn+0xa8/0xd0)
[<c0025588>] (__warn) from [<c0025624>] (warn_slowpath_fmt+0x74/0xa4)
[<c0025624>] (warn_slowpath_fmt) from [<c0066128>] (dma_free_attrs+0xb8/0xc8)
[<c0066128>] (dma_free_attrs) from [<c03c3548>] (___free_dma_mem_cluster+0x68/0x98)
[<c03c3548>] (___free_dma_mem_cluster) from [<c03c3940>] (__sym_mfree_dma+0x40/0xd0)
[<c03c3940>] (__sym_mfree_dma) from [<c03c31d4>] (sym_hcb_free+0x48/0x1a0)
[<c03c31d4>] (sym_hcb_free) from [<c03bcdb4>] (sym_free_resources+0x50/0x70)
[<c03bcdb4>] (sym_free_resources) from [<c03bb94c>] (sym2_probe+0x608/0x8b8)
[<c03bb94c>] (sym2_probe) from [<c02ce538>] (pci_device_probe+0xa4/0x12c)
[<c02ce538>] (pci_device_probe) from [<c0382ec0>] (really_probe+0xdc/0x404)
[<c0382ec0>] (really_probe) from [<c0383448>] (driver_probe_device+0x5c/0x16c)
[<c0383448>] (driver_probe_device) from [<c03837e0>] (device_driver_attach+0xa8/0xb0)
[<c03837e0>] (device_driver_attach) from [<c0383860>] (__driver_attach+0x78/0x10c)
[<c0383860>] (__driver_attach) from [<c0380ef8>] (bus_for_each_dev+0x74/0xbc)
[<c0380ef8>] (bus_for_each_dev) from [<c038223c>] (bus_add_driver+0xec/0x1d4)
[<c038223c>] (bus_add_driver) from [<c03840f0>] (driver_register+0x88/0x118)
[<c03840f0>] (driver_register) from [<c0a8c9bc>] (sym2_init+0xd4/0x12c)
[<c0a8c9bc>] (sym2_init) from [<c000ad24>] (do_one_initcall+0x4c/0x1cc)
[<c000ad24>] (do_one_initcall) from [<c0a75e70>] (kernel_init_freeable+0xfc/0x1bc)
[<c0a75e70>] (kernel_init_freeable) from [<c0609b0c>] (kernel_init+0x8/0xe8)
[<c0609b0c>] (kernel_init) from [<c00090e8>] (ret_from_fork+0x14/0x2c)
Exception stack(0xcf825fb0 to 0xcf825ff8)
5fa0:                                     00000000 00000000 00000000 00000000
5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
---[ end trace 921884272c1232ed ]---
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Tainted: G        W         5.4.51 #1
[<c03c3940>] (__sym_mfree_dma) from [<c03c31f4>] (sym_hcb_free+0x68/0x1a0)
[<c03c31f4>] (sym_hcb_free) from [<c03bcdb4>] (sym_free_resources+0x50/0x70)
---[ end trace 921884272c1232ee ]---
Modules linked in:
[<c03c3940>] (__sym_mfree_dma) from [<c03c3210>] (sym_hcb_free+0x84/0x1a0)
[<c03c3210>] (sym_hcb_free) from [<c03bcdb4>] (sym_free_resources+0x50/0x70)
---[ end trace 921884272c1232ef ]---
Modules linked in:
[<c03c3940>] (__sym_mfree_dma) from [<c03c322c>] (sym_hcb_free+0xa0/0x1a0)
[<c03c322c>] (sym_hcb_free) from [<c03bcdb4>] (sym_free_resources+0x50/0x70)
---[ end trace 921884272c1232f0 ]---
Modules linked in:
[<c03c3940>] (__sym_mfree_dma) from [<c03bb94c>] (sym2_probe+0x608/0x8b8)
---[ end trace 921884272c1232f1 ]---
physmap-flash 34000000.flash: versatile/realview flash protection
physmap-flash 34000000.flash: physmap platform flash device: [mem 0x34000000-0x37ffffff]
34000000.flash: Found 1 x32 devices at 0x0 in 32-bit bank. Manufacturer ID 0x000000 Chip ID 0x000000
Intel/Sharp Extended Query Table at 0x0031
Using buffer write method
erase region 0: offset=0x0,size=0x40000,blocks=256
tun: Universal TUN/TAP device driver, 1.6
smc91x.c: v1.1, sep 22 2004 by Nicolas Pitre <nico@fluxnic.net>
smc91x 10010000.net eth0: SMC91C11xFD (rev 1) at (ptrval) IRQ 41
smc91x 10010000.net eth0: Ethernet addr: 52:54:00:12:34:56
rtc-ds1307 0-0068: registered as rtc0
versatile reboot driver registered
device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
mmci-pl18x fpga:05: /aliases ID not available
mmci-pl18x fpga:05: mmc0: PL181 manf 41 rev0 at 0x10005000 irq 59,60 (pio)
mmci-pl18x fpga:05: DMA channels RX none, TX none
mmci-pl18x fpga:0b: /aliases ID not available
mmci-pl18x fpga:0b: mmc1: PL181 manf 41 rev0 at 0x1000b000 irq 49,50 (pio)
mmci-pl18x fpga:0b: DMA channels RX none, TX none
leds-syscon 10000000.core-module:led@08.0: registered LED versatile:0
leds-syscon 10000000.core-module:led@08.1: registered LED versatile:1
leds-syscon 10000000.core-module:led@08.2: registered LED versatile:2
leds-syscon 10000000.core-module:led@08.3: registered LED versatile:3
leds-syscon 10000000.core-module:led@08.4: registered LED versatile:4
leds-syscon 10000000.core-module:led@08.5: registered LED versatile:5
leds-syscon 10000000.core-module:led@08.6: registered LED versatile:6
leds-syscon 10000000.core-module:led@08.7: registered LED versatile:7
ledtrig-cpu: registered to indicate activity on CPUs
IPVS: Registered protocols (TCP, UDP, SCTP, AH, ESP)
IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
IPVS: ipvs loaded.
IPVS: [rr] scheduler registered.
IPVS: [wrr] scheduler registered.
IPVS: [lc] scheduler registered.
IPVS: [wlc] scheduler registered.
IPVS: [fo] scheduler registered.
IPVS: [ovf] scheduler registered.
IPVS: [lblc] scheduler registered.
IPVS: [lblcr] scheduler registered.
IPVS: [dh] scheduler registered.
IPVS: [sh] scheduler registered.
IPVS: [mh] scheduler registered.
IPVS: [sed] scheduler registered.
IPVS: [nq] scheduler registered.
ipip: IPv4 and MPLS over IPv4 tunneling driver
ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
input: AT Raw Set 2 keyboard as /devices/platform/amba/amba:fpga/10006000.kmi/serio0/input/input0
random: fast init done
bpfilter: Loaded bpfilter_umh pid 34
NET: Registered protocol family 17
Bridge firewalling registered
8021q: 802.1Q VLAN Support v1.8
9pnet: Installing 9P2000 support
rtc-ds1307 0-0068: setting system clock to 2021-02-28T17:34:20 UTC (1614533660)
uart-pl011 101f1000.uart: no DMA platform data
input: ImExPS/2 Wortzensur Explorer Mouse as /devices/platform/amba/amba:fpga/10007000.kmi/serio1/input/input2
Waiting for root device /dev/sda2...
random: crng init done
Leider ist Port 9443 auf dem Host nicht erreichbar. Was mache ich falsch?
Host ist ein Ubuntu.
