ich hatte die Logs vom Zeitraum der Abstürze dummerweise schon gelöscht.
Soeben nochmals weggeputzt und den Raspi neu gestartet.
30.07. 14:15:14 -
P: Vendor=1d6b ProdID=0002 Rev=05.10
S: Manufacturer=Linux 5.10.27-v7l+ xhci-hcd
S: Product=xHCI Host Controller
S: SerialNumber=0000:01:00.0
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 4
D: Ver= 2.10 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=2109 ProdID=3431 Rev=04.21
S: Product=USB2.0 Hub
C: #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=100mA
T: Bus=01 Lev=02 Prnt=02 Port=03 Cnt=01 Dev#= 3 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=0403 ProdID=6001 Rev=06.00
S: Manufacturer=FTDI
S: Product=FT232R USB UART
S: SerialNumber=AB0L4CEE
C: #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=90mA
I: If#=0x0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=5000 MxCh= 4
D: Ver= 3.00 Cls=09(hub ) Sub=00 Prot=03 MxPS= 9 #Cfgs= 1
P: Vendor=1d6b ProdID=0003 Rev=05.10
T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=5000 MxCh= 0
D: Ver= 3.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 9 #Cfgs= 1
P: Vendor=0781 ProdID=5581 Rev=01.00
S: Manufacturer=SanDisk
S: Product=Ultra
S: SerialNumber=4C530001241022122520
C: #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=896mA
I: If#=0x0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
30.07. 14:15:15 -Daten:
array (
15 => 'SCSI 00.0: 10600 Disk',
'' => '[Created at block.245]',
'Unique ID' => 'FKGF.AoaB4YF+ZbB',
'Parent ID' => 'VCu0.m2lGPNk7Xc4',
'SysFS ID' => '/class/block/sda',
'SysFS BusID' => '0:0:0:0',
'SysFS Device Link' => '/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb2/2-1/2-1:1.0/host0/target0:0:0/0:0:0:0',
'Hardware Class' => 'disk',
'Model' => '"SanDisk Ultra"',
'Vendor' => 'usb 0x0781 "SanDisk"',
'Device' => 'usb 0x5581 "Ultra"',
'Revision' => '"1.00"',
'Serial ID' => '"4C530001241022122520"',
'Driver' => '"usb-storage", "sd"',
'Driver Modules' => '"usb_storage"',
'Device File' => '/dev/sda (/dev/sg0)',
'Device Files' => '/dev/sda, /dev/disk/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1:1.0-scsi-0:0:0:0, /dev/disk/by-id/usb-SanDisk_Ultra_4C530001241022122520-0:0',
'Device Number' => 'block 8:0-8:15 (char 21:0)',
'Geometry (Logical)' => 'CHS 14663/64/32',
'Size' => '30031250 sectors a 512 bytes',
'Capacity' => '14 GB (15376000000 bytes)',
'Module Alias' => '"usb:v0781p5581d0100dc00dsc00dp00ic08isc06ip50in00"',
'Attached to' => '#2 (USB Controller)',
array (
16 => 'None 00.0: 11300 Partition',
'' => '[Created at block.434]',
'Unique ID' => 'bdUI.SE1wIdpsiiC',
'Parent ID' => 'FKGF.AoaB4YF+ZbB',
'SysFS ID' => '/class/block/sda/sda1',
'Model' => '"Partition"',
'Device File' => '/dev/sda1',
'Device Files' => '/dev/sda1, /dev/disk/by-uuid/0C61-73F5, /dev/disk/by-id/usb-SanDisk_Ultra_4C530001241022122520-0:0-part1, /dev/disk/by-label/boot, /dev/disk/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1:1.0-scsi-0:0:0:0-part1, /dev/disk/by-partuuid/8978ce14-01',
'Attached to' => '#15 (Disk)',
array (
17 => 'None 00.0: 11300 Partition',
'Unique ID' => '2pkM.SE1wIdpsiiC',
'SysFS ID' => '/class/block/sda/sda2',
'Device File' => '/dev/sda2',
'Device Files' => '/dev/sda2, /dev/disk/by-partuuid/8978ce14-02, /dev/disk/by-uuid/43f2d0bb-83be-464f-94d0-9a751f376c64, /dev/disk/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1:1.0-scsi-0:0:0:0-part2, /dev/disk/by-id/usb-SanDisk_Ultra_4C530001241022122520-0:0-part2, /dev/disk/by-label/rootfs',
array (
24 => 'USB 00.0: 10a00 Hub',
'' => '[Created at usb.122]',
'Unique ID' => 'k4bc.kNaPe9SZft4',
'SysFS ID' => '/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-0:1.0',
'SysFS BusID' => '1-0:1.0',
'Hardware Class' => 'hub',
'Model' => '"Linux Foundation 2.0 root hub"',
'Hotplug' => 'USB',
'Device' => 'usb 0x0002 "2.0 root hub"',
'Revision' => '"5.10"',
'Serial ID' => '"0000:01:00.0"',
'Driver' => '"hub"',
'Speed' => '480 Mbps',
'Module Alias' => '"usb:v1D6Bp0002d0510dc09dsc00dp01ic09isc00ip00in00"',
array (
25 => 'USB 00.0: 0700 Serial controller',
'Unique ID' => '33sj.zmCNM+AttwD',
'Parent ID' => 'ADDn.mUqILwxEtWB',
'SysFS ID' => '/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0',
'SysFS BusID' => '1-1.4:1.0',
'Hardware Class' => 'unknown',
'Model' => '"Future Technology Devices International FT232 Serial (UART) IC"',
'Hotplug' => 'USB',
'Device' => 'usb 0x6001 "FT232 Serial (UART) IC"',
'Revision' => '"6.00"',
'Serial ID' => '"AB0L4CEE"',
'Driver' => '"ftdi_sio"',
'Driver Modules' => '"usbserial", "ftdi_sio"',
'Device File' => '/dev/ttyUSB0',
'Device Files' => '/dev/ttyUSB0, /dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-port0, /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AB0L4CEE-if00-port0',
'Device Number' => 'char 188:0',
'Tags' => 'mouse, modem',
'Speed' => '12 Mbps',
'Module Alias' => '"usb:v0403p6001d0600dc00dsc00dp00icFFiscFFipFFin00"',
'Driver Info #0' => '',
'Driver Status' => 'ftdi_sio is active',
'Driver Activation Cmd' => '"modprobe ftdi_sio"',
'Attached to' => '#26 (Hub)',
array (
26 => 'USB 00.0: 10a00 Hub',
'Unique ID' => 'ADDn.mUqILwxEtWB',
'Parent ID' => 'k4bc.kNaPe9SZft4',
'SysFS ID' => '/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1:1.0',
'SysFS BusID' => '1-1:1.0',
'Model' => '"VIA Hub"',
'Hotplug' => 'USB',
'Vendor' => 'usb 0x2109 "VIA Labs, Inc."',
'Device' => 'usb 0x3431 "Hub"',
'Revision' => '"4.21"',
'Module Alias' => '"usb:v2109p3431d0421dc09dsc00dp01ic09isc00ip00in00"',
'Attached to' => '#24 (Hub)',
array (
27 => 'USB 00.0: 10a00 Hub',
'Unique ID' => 'pBe4.djic47EFb5E',
'SysFS ID' => '/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb2/2-0:1.0',
'SysFS BusID' => '2-0:1.0',
'Model' => '"Linux Foundation 3.0 root hub"',
'Hotplug' => 'USB',
'Device' => 'usb 0x0003 "3.0 root hub"',
'Module Alias' => '"usb:v1D6Bp0003d0510dc09dsc00dp03ic09isc00ip00in00"',
30.07. 14:15:15 -USB Devices:
array (
1 =>
array (
'Device' => '0x6001',
'File' => '/dev/ttyUSB0',
'Driver' => 'ftdi_sio',
2 =>
array (
'Device' => '0x0003',
30.07. 14:15:15 -Regler: 52
30.07. 14:15:15 -Regler erkannt: /dev/ttyUSB0
30.07. 14:15:15 -Device: /dev/ttyUSB0 wird in die user.config.php geschrieben.
30.07. 14:15:15 -Zeile gefunden. Device kann ausgetauscht werden. Index: 561 $USBRegler = "/dev/ttyUSB0";
30.07. 14:15:15 -Zeile gefunden. Device kann ausgetauscht werden. Index: 562 $USBWechselrichter = "/dev/ttyUSB1";
30.07. 14:15:15 -Zeile gefunden. Platine kann ausgetauscht werden. Index: 581 $Platine = "Raspberry Pi 4 Model B Rev 1.1";
30.07. 14:16:18 |------------------------- Start goodwe_wr.php ---------------------
30.07. 14:16:21 -Auslesen des Gerätes beendet.
30.07. 14:16:21 -Goodwe_wr_math.php durchlaufen.
30.07. 14:16:21 -MQTT Daten zum [ localhost ] senden.
30.07. 14:16:21 * -Daten zur lokalen InfluxDB [ solaranzeige ] gesendet.
30.07. 14:16:23 MQT-MQTT Daten zum Broker gesendet: localhost Port: 1883
30.07. 14:16:32 -Auslesen des Gerätes beendet.
30.07. 14:16:32 -Goodwe_wr_math.php durchlaufen.
30.07. 14:16:32 -MQTT Daten zum [ localhost ] senden.
30.07. 14:16:32 * -Daten zur lokalen InfluxDB [ solaranzeige ] gesendet.
30.07. 14:16:33 MQT-MQTT Daten zum Broker gesendet: localhost Port: 1883
30.07. 14:16:43 -Auslesen des Gerätes beendet.
30.07. 14:16:43 -Goodwe_wr_math.php durchlaufen.
30.07. 14:16:43 -MQTT Daten zum [ localhost ] senden.
30.07. 14:16:43 * -Daten zur lokalen InfluxDB [ solaranzeige ] gesendet.
