Na, dann lade ich mal die Log-Daten hoch. Den redundanten Teil lasse ich weg. Hoffentlich genügt das.
Funktioniert $InfluxDaylight = true auch als Schalter bei einer lokalen DB? Das würde das Logfile etwas verschlanken
LG,
BastlerVomLech
php.log:
[08-Oct-2021 07:13:11 Europe/Berlin] PHP Warning: fsockopen(): unable to connect to 192.168.1.121:80 (No route to host) in /var/www/html/
[08-Oct-2021 07:14:09 Europe/Berlin] PHP Warning: fsockopen(): unable to connect to 192.168.1.121:80 (Connection refused) in /var/www/htm
[08-Oct-2021 07:15:10 Europe/Berlin] PHP Warning: end() expects parameter 1 to be array, null given in /var/www/html/fronius_symo_serie.p
[08-Oct-2021 07:15:10 Europe/Berlin] PHP Notice: Undefined index: Temperature_Powerstage in /var/www/html/fronius_symo_serie.php on line
[08-Oct-2021 07:15:12 Europe/Berlin] PHP Notice: Undefined index: PAC in /var/www/html/fronius_symo_serie.php on line 208
[08-Oct-2021 07:16:09 Europe/Berlin] PHP Notice: Undefined index: Temperature_Powerstage in /var/www/html/fronius_symo_serie.php on line
[08-Oct-2021 07:16:10 Europe/Berlin] PHP Notice: Undefined index: PAC in /var/www/html/fronius_symo_serie.php on line 208
[08-Oct-2021 07:17:10 Europe/Berlin] PHP Notice: Undefined index: Temperature_Powerstage in /var/www/html/fronius_symo_serie.php on line
[08-Oct-2021 07:17:11 Europe/Berlin] PHP Notice: Undefined index: PAC in /var/www/html/fronius_symo_serie.php on line 208
[08-Oct-2021 07:18:10 Europe/Berlin] PHP Notice: Undefined index: Temperature_Powerstage in /var/www/html/fronius_symo_serie.php on line
[08-Oct-2021 07:18:11 Europe/Berlin] PHP Notice: Undefined index: PAC in /var/www/html/fronius_symo_serie.php on line 208
[08-Oct-2021 07:19:10 Europe/Berlin] PHP Notice: Undefined index: Temperature_Powerstage in /var/www/html/fronius_symo_serie.php on line
[08-Oct-2021 07:19:11 Europe/Berlin] PHP Notice: Undefined index: PAC in /var/www/html/fronius_symo_serie.php on line 208
[08-Oct-2021 07:20:11 Europe/Berlin] PHP Notice: Undefined index: PAC in /var/www/html/fronius_symo_serie.php on line 208[08-Oct-2021 07:
[08-Oct-2021 07:21:11 Europe/Berlin] PHP Notice: Undefined index: PAC in /var/www/html/fronius_symo_serie.php on line 208
[08-Oct-2021 07:22:10 Europe/Berlin] PHP Notice: Undefined index: PAC in /var/www/html/fronius_symo_serie.php on line 208
[08-Oct-2021 07:23:11 Europe/Berlin] PHP Notice: Undefined index: PAC in /var/www/html/fronius_symo_serie.php on line 208
solaranzeige.log:
08.10. 18:52:01 -Multi Regler Auslesen [Start].
08.10. 18:52:01 -Verarbeitung von: '1.user.config.php' Regler: 12
08.10. 18:52:01 |---------------- Start fronius_symo_serie.php ---------------.
08.10. 18:52:01 -API Version: 1 CompatibilityRange: 1.7-3
08.10. 18:52:01 * -Daten zur lokalen InfluxDB [ solaranzeige ] gesendet..
08.10. 18:52:01 -Multi-Regler-Ausgang. 7
08.10. 18:52:08 -OK. Datenübertragung erfolgreich.
08.10. 18:52:08 |---------------- Stop fronius_symo_serie.php ---------------.
08.10. 18:52:08 -Verarbeitung von: '2.user.config.php' Regler: 12
08.10. 18:52:08 |---------------- Start fronius_symo_serie.php ---------------.
08.10. 18:52:08 -API Version: 1 CompatibilityRange: 1.5-18
08.10. 18:52:16 * -Daten zur lokalen InfluxDB [ Solaranzeige_Symo ] gesendet..
08.10. 18:52:16 -Multi-Regler-Ausgang. -1
08.10. 18:52:16 -OK. Datenübertragung erfolgreich.
08.10. 18:52:16 |---------------- Stop fronius_symo_serie.php ---------------.
08.10. 18:52:16 -Multi Regler Auslesen [Stop].
Der Wert nach "-Multi-Regler-Ausgang" wechselt zwischen 0, 1, -4, 7 und 6
Weiter vorne in solaranzeige.log gibt es eine fehlgeschlagene Initialisierung des zweiten WR, der nachts aber schläft:
08.10. 01:45:01 * -Daten zur lokalen InfluxDB [ solaranzeige ] gesendet..
08.10. 01:45:01 -Multi-Regler-Ausgang. 7
08.10. 01:45:08 -OK. Datenübertragung erfolgreich.
08.10. 01:45:08 |---------------- Stop fronius_symo_serie.php ---------------.
08.10. 01:45:08 -Verarbeitung von: '2.user.config.php' Regler: 12
08.10. 01:45:08 |---------------- Start fronius_symo_serie.php ---------------.
08.10. 01:45:09 -API Version: 1 CompatibilityRange: 1.5-18
08.10. 01:45:34 -Datenabfrage falsch! info: array (
'url' => 'http://192.168.1.121/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DataCollection=CommonInverterData&DeviceId=1',
'content_type' => NULL,
'http_code' => 0,
'header_size' => 0,
'request_size' => 150,
'filetime' => -1,
'ssl_verify_result' => 0,
'redirect_count' => 0,
'total_time' => 20.001642,
'namelookup_time' => 0.000119,
'connect_time' => 0.002193,
'pretransfer_time' => 0.002348,
'size_upload' => 0.0,
'size_download' => 0.0,
'speed_download' => 0.0,
'speed_upload' => 0.0,
'download_content_length' => -1.0,
'upload_content_length' => -1.0,
'starttransfer_time' => 0.0,
'redirect_time' => 0.0,
'redirect_url' => '',
'primary_ip' => '192.168.1.121',
'certinfo' =>.
array (
'primary_port' => 80,
'local_ip' => '192.168.1.125',
'local_port' => 37232,
'http_version' => 0,
'protocol' => 1,
'ssl_verifyresult' => 0,
'scheme' => 'HTTP',
'appconnect_time_us' => 0,
'connect_time_us' => 2193,
'namelookup_time_us' => 119,
'pretransfer_time_us' => 2348,
'redirect_time_us' => 0,
'starttransfer_time_us' => 0,
'total_time_us' => 20001642,
08.10. 01:45:34 !! -Keine gültigen Daten empfangen.
08.10. 01:45:34 |---------------- Stop fronius_symo_serie.php ---------------.
08.10. 01:45:34 -Multi Regler Auslesen [Stop].
