Felhler im php.log
Snoopy
Danksagung erhalten: 5 Mal
Felhler im php.log
Beitrag von Snoopy »
ich habe folgenden Fehler nach einer Neuinstallation in dem php.log gefunden.
[06-Jul-2022 17:47:46 Europe/Berlin] PHP Warning:  sleep() expects parameter 1 to be int, float given in /var/www/html/huawei_LAN.php on line 336
[06-Jul-2022 17:48:46 Europe/Berlin] PHP Warning:  Division by zero in /var/www/html/huawei_LAN.php on line 334
[06-Jul-2022 17:48:46 Europe/Berlin] PHP Warning:  Division by zero in /var/www/html/huawei_LAN.php on line 335
[06-Jul-2022 17:48:46 Europe/Berlin] PHP Warning:  Division by zero in /var/www/html/huawei_LAN.php on line 336
[06-Jul-2022 17:48:46 Europe/Berlin] PHP Warning:  sleep() expects parameter 1 to be int, float given in /var/www/html/huawei_LAN.php on line 336
[06-Jul-2022 17:49:47 Europe/Berlin] PHP Warning:  Division by zero in /var/www/html/huawei_LAN.php on line 334
[06-Jul-2022 17:49:47 Europe/Berlin] PHP Warning:  Division by zero in /var/www/html/huawei_LAN.php on line 335
[06-Jul-2022 17:49:47 Europe/Berlin] PHP Warning:  Division by zero in /var/www/html/huawei_LAN.php on line 336
[06-Jul-2022 17:49:47 Europe/Berlin] PHP Warning:  sleep() expects parameter 1 to be int, float given in /var/www/html/huawei_LAN.php on line 336
[06-Jul-2022 17:50:47 Europe/Berlin] PHP Warning:  Division by zero in /var/www/html/huawei_LAN.php on line 334
[06-Jul-2022 17:50:47 Europe/Berlin] PHP Warning:  Division by zero in /var/www/html/huawei_LAN.php on line 335
[06-Jul-2022 17:50:47 Europe/Berlin] PHP Warning:  Division by zero in /var/www/html/huawei_LAN.php on line 336
[06-Jul-2022 17:50:47 Europe/Berlin] PHP Warning:  sleep() expects parameter 1 to be int, float given in /var/www/html/huawei_LAN.php on line 336
Das ist der Auszug aus dem huawei_LAN.php script wo der Fehler sein sollte.
if (floor(((9*$i) - (time() - $Startzeit)) / ($Wiederholungen - $i+1)) > 0) {
      $funktionen->log_schreiben("Schleife: ".($i)." Zeitspanne: ".(floor(((9*$i) - (time() - $Startzeit))/($Wiederholungen-$i+1))),"   ",3);
      sleep(floor(((9*$i) - (time() - $Startzeit)) / ($Wiederholungen - $i+1)));
Ich hoffe jemand kann mir helfen.
Hat sich bedankt: 162 Mal
Danksagung erhalten: 923 Mal
Re: Felhler im php.log
Was steht in der user.config.php hinter der Variable "$Wiederholungen = "?
Dort muss stehen:
$Wiederholungen = "1";
Snoopy
dort habe ich eine 6 stehen für 6 abfragen pro Minute wie es beschrieben ist.
Huawei LAN ist so langsam, dass in einer Minute nur eine Abfrage möglich ist. Bitte 1 eintragen.
Snoopy
ich habe noch eine Anlage wo die Solaranzeige läuft und da habe ich das Problem nicht. Aber ich werde trotzdem das mal auf 1 setzen.
Jetzt habe ich in der Anlage gesehen das noch ein Fehler da ist.
[07-Jul-2022 16:01:03 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type null in /var/www/html/automation.php on line 1987
[07-Jul-2022 16:02:04 Europe/Berlin] PHP Notice:  Undefined variable: Ergebnis in /var/www/html/automation.php on line 809
[07-Jul-2022 16:02:04 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type null in /var/www/html/automation.php on line 1987
[07-Jul-2022 16:03:03 Europe/Berlin] PHP Notice:  Undefined variable: Ergebnis in /var/www/html/automation.php on line 809
[07-Jul-2022 16:03:03 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type null in /var/www/html/automation.php on line 1987
[07-Jul-2022 16:04:04 Europe/Berlin] PHP Notice:  Undefined variable: Ergebnis in /var/www/html/automation.php on line 809
[07-Jul-2022 16:04:04 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type null in /var/www/html/automation.php on line 1987
[07-Jul-2022 16:05:03 Europe/Berlin] PHP Notice:  Undefined variable: Ergebnis in /var/www/html/automation.php on line 809
[07-Jul-2022 16:05:03 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type null in /var/www/html/automation.php on line 1987
[07-Jul-2022 16:06:04 Europe/Berlin] PHP Notice:  Undefined variable: Ergebnis in /var/www/html/automation.php on line 809
[07-Jul-2022 16:06:04 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type null in /var/www/html/automation.php on line 1987
[07-Jul-2022 16:07:03 Europe/Berlin] PHP Notice:  Undefined variable: Ergebnis in /var/www/html/automation.php on line 809
[07-Jul-2022 16:07:03 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type null in /var/www/html/automation.php on line 1987
[07-Jul-2022 16:08:04 Europe/Berlin] PHP Notice:  Undefined variable: Ergebnis in /var/www/html/automation.php on line 809
[07-Jul-2022 16:08:04 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type null in /var/www/html/automation.php on line 1987
[07-Jul-2022 16:09:02 Europe/Berlin] PHP Notice:  Undefined variable: Ergebnis in /var/www/html/automation.php on line 809
[07-Jul-2022 16:09:02 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type null in /var/www/html/automation.php on line 1987
Läuft aber einwandfrei
Der Fehler kommt von der Automation. Die scheint nicht ganz richtig konfiguriert zu sein.
JoWi
Beitrag von JoWi »
Ulrich hat geschrieben:
Mi 6. Jul 2022, 22:21
Leider habe ich das selbe Problem. Auch wenn ich die Abfrage auf 1 stelle habe ich im php.log folgende Fehlermeldung:
"[08-Sep-2022 17:23:50 Europe/Berlin] PHP Warning: Division by zero in /var/www/html/huawei_LAN.php on line 334"
Dort steht in der huawei_LAN.php:
"if (floor(((9*$i) - (time() - $Startzeit)) / ($Wiederholungen - $i+1)) > 0) {"
Die Solaranzeige.log zeigt folgendes:
"08.09. 17:39:01 |---------------- Start huawei_LAN.php -----------------------------
08.09. 17:39:13 -Fehler! Keine gültigen Daten empfangen.
08.09. 17:39:24 > -Gerätetyp: Modell ID: 0
08.09. 17:39:37 > -Alarm 1 Bits: 0000000000000000
08.09. 17:39:50 * -Daten zur lokalen InfluxDB [ solaranzeige ] gesendet.
08.09. 17:39:50 -OK. Datenübertragung erfolgreich.
08.09. 17:39:50 |---------------- Stop huawei_LAN.php --------------------------- "
Habt ihr eine Lösungsidee? Vielen Dank auf jeden Fall!
LG
Die Fehlermeldung besagt, dass dein Gerät nicht ausgelesen werden kann. Da scheint mit der Verbindung zum Wechselrichter etwas nicht zu stimmen.
JoWi
Beitrag von JoWi »
Vielen Dank. Welche Möglichkeiten gibt es, die Fehlerquelle genauer einzugrenzen? Der Dongle hat die Version PC129, Port 502 ist offen und ein ping funktioniert auch
Gebe einmal auf der Konsole folgendes ein:
nmap -p 502 <IP Adresse des Wechselrichters>
meldet sich der Port 502 mit OPEN
Mitglieder in diesem Forum: Stefan14 und 0 Gäste
