/etc/vzloggerCode: Alles auswählen
/Moderator: Ulrich
/Code: Alles auswählen
[Dec 18 21:52:31][mtr0] Got 2 new readings from meter:
[Dec 18 21:52:31][mtr0] Reading: id=1-0:1.8.0*255/ObisIdentifier:1-0:1.8.0*255 value=4991993.00 ts=1639860751074
[Dec 18 21:52:31][mtr0] Reading: id=1-0:16.7.0*255/ObisIdentifier:1-0:16.7.0*255 value=179.80 ts=156921457000
[Dec 18 21:52:31][chn0] Adding reading to queue (value=4991993.00 ts=1639860751074)
[Dec 18 21:52:31][chn1] Adding reading to queue (value=179.80 ts=156921457000)
[Dec 18 21:52:31][AVG] [0] 4991993.000000 @ 1639860751074
[Dec 18 21:52:31][AVG] [1] RESULT 4991992.900000 @ 1639860751074
[Dec 18 21:52:31][chn0] Buffer has 1 items
[Dec 18 21:52:31][chn1] Buffer has 1 items
[Dec 18 21:52:31][chn0] Reading buffer: timestamp 1639860751074 value 4991992.900000
[Dec 18 21:52:31][chn1] Reading buffer: timestamp 156921457000 value 179.800000
[Dec 18 21:52:31][chn0] request body is vzlogger,uuid=86d93a20-28ea-11eb-88b2-a77c66ef7609 value=4991992.900000 1639860751074
[Dec 18 21:52:31][chn1] request body is vzlogger,uuid=567e9a10-28e9-11eb-8207-93162e3c8cf0 value=179.800000 156921457000
[Dec 18 21:52:31][CURL] CURL: Expire in 0 ms for 6 (transfer 0x74b05b00)
[Dec 18 21:52:31][CURL] CURL: Expire in 0 ms for 6 (transfer 0x74105b00)
[Dec 18 21:52:31][CURL] CURL: Expire in 30000 ms for 8 (transfer 0x74b05b00)
[Dec 18 21:52:31][CURL] CURL: Expire in 30000 ms for 8 (transfer 0x74105b00)
[Dec 18 21:52:31][CURL] CURL: Found bundle for host 127.0.0.1: 0x74b10f78 [can pipeline]
[Dec 18 21:52:31][CURL] CURL: Found bundle for host 127.0.0.1: 0x74110f78 [can pipeline]
[Dec 18 21:52:31][CURL] CURL: Could pipeline, but not asked to!
[Dec 18 21:52:31][CURL] CURL: Re-using existing connection! (#0) with host 127.0.0.1
[Dec 18 21:52:31][CURL] CURL: Connected to 127.0.0.1 (127.0.0.1) port 8086 (#0)
[Dec 18 21:52:31][CURL] CURL: Header 'POST /write?db=vzlogger&precision=ms HTTP/1.1
Host: 127.0.0.1:8086
Accept: */*
Content-Length: 81
Content-Type: application/x-www-form-urlencoded
' bytes
Accept: */*
Content-Length: 86
' bytes
[Dec 18 21:52:31][CURL] CURL: Sent 81 bytes..
[Dec 18 21:52:31][CURL] CURL: Sent 86 bytes..
[Dec 18 21:52:31][CURL] CURL: Sent 'vzlogger,uuid=567e9a10-28e9-11eb-8207-93162e3c8cf0 value=179.800000 156921457000
' bytes
[Dec 18 21:52:31][CURL] CURL: Sent 'vzlogger,uuid=86d93a20-28ea-11eb-88b2-a77c66ef7609 value=4991992.900000 1639860751074
' bytes
[Dec 18 21:52:31][CURL] CURL: upload completely sent off: 81 out of 81 bytes
[Dec 18 21:52:31][CURL] CURL: upload completely sent off: 86 out of 86 bytes
[Dec 18 21:52:31][CURL] CURL: Header 'HTTP/1.1 204 No Content
' bytes
' bytes
[Dec 18 21:52:31][CURL] CURL: Header 'Content-Type: application/json
' bytes
' bytes
[Dec 18 21:52:31][CURL] CURL: Header 'Request-Id: 6afebd75-6044-11ec-ae15-b827eb87f469
' bytes
[Dec 18 21:52:31][CURL] CURL: Header 'Request-Id: 6afebc61-6044-11ec-ae14-b827eb87f469
' bytes
[Dec 18 21:52:31][CURL] CURL: Header 'X-Influxdb-Build: OSS
' bytes
' bytes
[Dec 18 21:52:31][CURL] CURL: Header 'X-Influxdb-Version: 1.8.3
' bytes
' bytes
[Dec 18 21:52:31][CURL] CURL: Header 'X-Request-Id: 6afebd75-6044-11ec-ae15-b827eb87f469
' bytes
[Dec 18 21:52:31][CURL] CURL: Header 'X-Request-Id: 6afebc61-6044-11ec-ae14-b827eb87f469
' bytes
[Dec 18 21:52:31][CURL] CURL: Header 'Date: Sat, 18 Dec 2021 20:52:31 GMT
' bytes
' bytes
' bytes
' bytes
[Dec 18 21:52:31][CURL] CURL: Connection #0 to host 127.0.0.1 left intact
[Dec 18 21:52:31][chn1] Influxdb curl terminated
[Dec 18 21:52:31][chn0] Influxdb curl terminated
[Dec 18 21:52:31][chn1] InfluxDB CURL success
[Dec 18 21:52:31][chn0] InfluxDB CURL success
"retry" : 3,
"daemon": true,
"verbosity" : 15,
"log" : "/var/log/vzlogger.log",
"local" : {
"enabled" : false,
"port" : 80,
"index" : true,
"timeout" : 30,
"buffer" : 600
"meters" : [
"enabled" : true,
"device" : "/dev/ttyUSB0",
"protocol" : "sml",
"parity" : "8N1",
"baudrate" : 9600,
"aggtime" : -1,
"aggfixedinterval" : true,
"channels": [{
"api" : "influxdb",
"uuid" : "86d93a20-28ea-11eb-88b2-a77c66ef7609",
"identifier" : "1-0:1.8.0",
"host" : "127.0.0.1:8086",
"database": "vzlogger", // Optional: make sure this database exists in InfluxDB
"ssl_verifypeer": true, // Optional: Disables the certificate verification for https connections
"aggmode" : "AVG"
"api" : "influxdb",
"uuid" : "567e9a10-28e9-11eb-8207-93162e3c8cf0",
"identifier" : "1-0:16.7.0",
Hi Tipe1965,Tipe1965 hat geschrieben: ↑So 10. Jan 2021, 21:04Da ist einfach Tasmota drauf, muss bisschen angepasst werden ist aber nicht weiter schwer und dann kommt da einfach ein Skript rein gibt es auch eine gute Anleitung für. In meinem Fall schicke ich meine Daten an meinen iobroker weil ich den eh schon hab und von da aus in die influx dB von meiner solaranzeige. Aber wenn ich es richtig verfolgt habe kann die solaranzeige selber ja sogar mqtt und von daher sollte man die Daten auch direkt an die Solaranzeige schicken können.
Ja ok das mit dem Netzteil stimmt schon aber Vorteil ist du bist völlig frei vom Standort der rasp, du muss halt nur wlan an der Stelle haben.
/var/log/vzlogger.log {
rotate 1
size=100k
copytruncate
missingok
notifempty
create 0664 vzlogger root
}Code: Alles auswählen
pi@solaranzeige:~ $ systemctl status vzlogger
● vzlogger.service - vzlogger
Loaded: loaded (/etc/systemd/system/vzlogger.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2022-06-04 11:08:00 CEST; 11min ago
Main PID: 471 (vzlogger)
Tasks: 4 (limit: 4915)
CGroup: /system.slice/vzlogger.service
└─471 /usr/local/bin/vzlogger -c /etc/vzlogger.conf
Jun 04 11:08:00 solaranzeige systemd[1]: Started vzlogger.Code: Alles auswählen
"retry" : 3,
"daemon": true,
"verbosity" : 0,
"local" : {
"enabled" : false,
"port" : 80,
"index" : true,
"timeout" : 30,
"buffer" : 600
"meters" : [
"enabled" : true,
"device" : "/dev/stromzaehler",
"protocol" : "sml",
"parity" : "8N1",
"baudrate" : 9600,
"aggtime" : 60,
"use_local_time": true,
"channels": [{
"api" : "influxdb",
"ssl_verifypeer" : true, // Optional: Disables the certificate verification for https connections
"aggmode" : "MAX",
"duplicates" : 3600
"api" : "influxdb",
"uuid" : "d9c9e31e-25b3-471b-a4f0-9725e195b6e3",
"identifier" : "1-0:2.8.0",
"ssl_verifypeer": true, // Optional: Disables the certificate verification for $
"aggmode" : "MAX",
"duplicates" : 3600
[Jun 04 11:08:00][main] vzlogger v0.8.1 based on heads/master-0-g037ab6b6a6 from Sat, 20 Nov 2021 14:46:15 +0100 started.
[Jun 04 11:08:01][main] log level is 0
[Jun 04 11:58:03][main] vzlogger v0.8.1 based on heads/master-0-g037ab6b6a6 from Sat, 20 Nov 2021 14:46:15 +0100 started.
[Jun 04 11:58:03][mtr0] Creating new meter with protocol sml.
[Jun 04 11:58:03][mtr0] Meter configured, enabled.
[Jun 04 11:58:03] New meter initialized (protocol=sml)
[Jun 04 11:58:03] Configure channel.
[Jun 04 11:58:03][chn0] New channel initialized (uuid=...ef7609 api=influxdb id=1-0:1.8.0)
[Jun 04 11:58:03][chn1] New channel initialized (uuid=...95b6e3 api=influxdb id=1-0:2.8.0)
[Jun 04 11:58:03] Have 1 meters.
[Jun 04 11:58:03][main] log level is 15
[Jun 04 11:58:03][main] local=0
[Jun 04 11:58:03] Daemonize process...
[Jun 04 11:58:03] Opened logfile /var/log/vzlogger.log
[Jun 04 11:58:03][push] No pushDataServer defined.
[Jun 04 11:58:03][] ===> Start meters
[Jun 04 11:58:03][mtr0] Meter connection established
[Jun 04 11:58:03][mtr0] Meter thread started
[Jun 04 11:58:03][mtr0] Meter is opened. Starting channels.
[Jun 04 11:58:03][mtr0] Number of readers: 32
[Jun 04 11:58:03][mtr0] Config.local: 0
[Jun 04 11:58:03][chn0] Logging thread started
[Jun 04 11:58:03][chn0] Start logging thread for influxdb-api.
[Jun 04 11:58:03][chn1] Logging thread started
[Jun 04 11:58:03][chn1] Start logging thread for influxdb-api.
[Jun 04 11:58:03][chn0] InfluxDB API initialize
[Jun 04 11:58:03][] Startup done.
[Jun 04 11:58:03][chn1] InfluxDB API initialize
[Jun 04 11:58:03][chn1] api InfluxDB using host 127.0.0.1:8086
[Jun 04 11:58:03][chn1] api InfluxDB no Token set
[Jun 04 11:58:03][chn1] api InfluxDB no organization set
[Jun 04 11:58:03][chn1] api InfluxDB no username set
[Jun 04 11:58:03][chn1] api InfluxDB no password set
[Jun 04 11:58:03][chn1] api InfluxDB using database vzlogger
[Jun 04 11:58:03][chn1] api InfluxDB will use default measurement name "vzlogger"
[Jun 04 11:58:03][chn1] api InfluxDB will not use any tags
[Jun 04 11:58:03][chn1] api InfluxDB will use default timeout 30
[Jun 04 11:58:03][chn1] api InfluxDB will use default max_batch_inserts 4500
[Jun 04 11:58:03][chn1] api InfluxDB will use default max_buffer_size 450000
[Jun 04 11:58:03][chn1] api InfluxDB will use default send_uuid true
[Jun 04 11:58:03][chn1] api InfluxDB using ssl_verifypeer: true
[Jun 04 11:58:03][chn1] api InfluxDB using url 127.0.0.1:8086/write?db=vzlogger&precision=ms
[Jun 04 11:58:03][chn1] Using InfluxDB api
[Jun 04 11:58:03][chn0] api InfluxDB using host 127.0.0.1:8086
[Jun 04 11:58:03][chn0] api InfluxDB no Token set
[Jun 04 11:58:03][chn0] api InfluxDB no organization set
[Jun 04 11:58:03][chn0] api InfluxDB no username set
[Jun 04 11:58:03][chn0] api InfluxDB no password set
[Jun 04 11:58:03][chn0] api InfluxDB using database vzlogger
[Jun 04 11:58:03][chn0] api InfluxDB will use default measurement name "vzlogger"
[Jun 04 11:58:03][chn0] api InfluxDB will not use any tags
[Jun 04 11:58:03][chn0] api InfluxDB will use default timeout 30
[Jun 04 11:58:03][chn0] api InfluxDB will use default max_batch_inserts 4500
[Jun 04 11:58:03][chn0] api InfluxDB will use default max_buffer_size 450000
[Jun 04 11:58:03][chn0] api InfluxDB will use default send_uuid true
[Jun 04 11:58:03][chn0] api InfluxDB using ssl_verifypeer: true
[Jun 04 11:58:03][chn0] api InfluxDB using url 127.0.0.1:8086/write?db=vzlogger&precision=ms
[Jun 04 11:58:03][chn0] Using InfluxDB api
[Jun 04 11:58:04][mtr0] Got 2 new readings from meter:
[Jun 04 11:58:04][mtr0] Reading: id=1-0:1.8.0*255/ObisIdentifier:1-0:1.8.0*255 value=1520000.00 ts=1654336684071
[Jun 04 11:58:04][mtr0] Reading: id=1-0:2.8.0*255/ObisIdentifier:1-0:2.8.0*255 value=3465000.00 ts=1654336684071
[Jun 04 11:58:04][chn0] Adding reading to queue (value=1520000.00 ts=1654336684071)
[Jun 04 11:58:04][chn1] Adding reading to queue (value=3465000.00 ts=1654336684071)
[Jun 04 11:58:05][mtr0] Got 2 new readings from meter:
[Jun 04 11:58:05][mtr0] Reading: id=1-0:1.8.0*255/ObisIdentifier:1-0:1.8.0*255 value=1520000.00 ts=1654336685064
[Jun 04 11:58:05][mtr0] Reading: id=1-0:2.8.0*255/ObisIdentifier:1-0:2.8.0*255 value=3465000.00 ts=1654336685064
[Jun 04 11:58:05][chn0] Adding reading to queue (value=1520000.00 ts=1654336685064)
[Jun 04 11:58:05][chn1] Adding reading to queue (value=3465000.00 ts=1654336685064)
[Jun 04 11:58:06][mtr0] Got 2 new readings from meter:
[Jun 04 11:58:06][mtr0] Reading: id=1-0:1.8.0*255/ObisIdentifier:1-0:1.8.0*255 value=1520000.00 ts=1654336686057
[Jun 04 11:58:06][mtr0] Reading: id=1-0:2.8.0*255/ObisIdentifier:1-0:2.8.0*255 value=3465000.00 ts=1654336686057
[Jun 04 11:58:06][chn0] Adding reading to queue (value=1520000.00 ts=1654336686057)
[Jun 04 11:58:06][chn1] Adding reading to queue (value=3465000.00 ts=1654336686057)
[Jun 04 11:58:07][mtr0] Got 2 new readings from meter:
[Jun 04 11:58:07][mtr0] Reading: id=1-0:1.8.0*255/ObisIdentifier:1-0:1.8.0*255 value=1520000.00 ts=1654336687050
[Jun 04 11:58:07][mtr0] Reading: id=1-0:2.8.0*255/ObisIdentifier:1-0:2.8.0*255 value=3465000.00 ts=1654336687050
[Jun 04 11:58:07][chn0] Adding reading to queue (value=1520000.00 ts=1654336687050)
[Jun 04 11:58:07][chn1] Adding reading to queue (value=3465000.00 ts=1654336687050)
[Jun 04 11:58:08][mtr0] Got 2 new readings from meter:
[Jun 04 13:20:03][CURL] CURL: Connection #0 to host 127.0.0.1 left intact
[Jun 04 13:20:03][chn0] Influxdb curl terminated
[Jun 04 13:20:03][chn0] InfluxDB CURL success
[Jun 04 13:20:03][CURL] CURL: Header 'HTTP/1.1 204 No Content
' bytes
[Jun 04 13:20:03][CURL] CURL: Header 'Content-Type: application/json
' bytes
[Jun 04 13:20:03][CURL] CURL: Header 'Request-Id: 477deb63-e3f8-11ec-8df3-e45f01667494
' bytes
[Jun 04 13:20:03][CURL] CURL: Header 'X-Influxdb-Build: OSS
' bytes
[Jun 04 13:20:03][CURL] CURL: Header 'X-Influxdb-Version: 1.8.3
' bytes
[Jun 04 13:20:03][CURL] CURL: Header 'X-Request-Id: 477deb63-e3f8-11ec-8df3-e45f01667494
' bytes
[Jun 04 13:20:03][CURL] CURL: Header 'Date: Sat, 04 Jun 2022 11:20:03 GMT
' bytes
' bytes
[Jun 04 13:20:03][chn1] Influxdb curl terminated
[Jun 04 13:20:03][chn1] InfluxDB CURL success
[Jun 04 13:20:04][mtr0] Got 15 new readings from meter:
[Jun 04 13:20:04][mtr0] Reading: id=1-0:1.8.0*255/ObisIdentifier:1-0:1.8.0*255 value=1520670.00 ts=1654341604233
[Jun 04 13:20:04][mtr0] Reading: id=1-0:2.8.0*255/ObisIdentifier:1-0:2.8.0*255 value=3474656.80 ts=1654341604233
[Jun 04 13:20:04][mtr0] Reading: id=1-0:16.7.0*255/ObisIdentifier:1-0:16.7.0*255 value=-7358.00 ts=1654341604233
[Jun 04 13:20:04][mtr0] Reading: id=1-0:32.7.0*255/ObisIdentifier:1-0:32.7.0*255 value=233.40 ts=1654341604233
[Jun 04 13:20:04][mtr0] Reading: id=1-0:52.7.0*255/ObisIdentifier:1-0:52.7.0*255 value=238.10 ts=1654341604233
[Jun 04 13:20:04][mtr0] Reading: id=1-0:72.7.0*255/ObisIdentifier:1-0:72.7.0*255 value=234.30 ts=1654341604233
[Jun 04 13:20:04][mtr0] Reading: id=1-0:31.7.0*255/ObisIdentifier:1-0:31.7.0*255 value=11.57 ts=1654341604233
[Jun 04 13:20:04][mtr0] Reading: id=1-0:51.7.0*255/ObisIdentifier:1-0:51.7.0*255 value=11.58 ts=1654341604233
[Jun 04 13:20:04][mtr0] Reading: id=1-0:71.7.0*255/ObisIdentifier:1-0:71.7.0*255 value=11.69 ts=1654341604233
[Jun 04 13:20:04][mtr0] Reading: id=1-0:81.7.1*255/ObisIdentifier:1-0:81.7.1*255 value=118.00 ts=1654341604233
[Jun 04 13:20:04][mtr0] Reading: id=1-0:81.7.2*255/ObisIdentifier:1-0:81.7.2*255 value=238.00 ts=1654341604233
[Jun 04 13:20:04][mtr0] Reading: id=1-0:81.7.4*255/ObisIdentifier:1-0:81.7.4*255 value=150.00 ts=1654341604233
[Jun 04 13:20:04][mtr0] Reading: id=1-0:81.7.15*255/ObisIdentifier:1-0:81.7.15*255 value=156.00 ts=1654341604233
[Jun 04 13:20:04][mtr0] Reading: id=1-0:81.7.26*255/ObisIdentifier:1-0:81.7.26*255 value=156.00 ts=1654341604233
[Jun 04 13:20:04][mtr0] Reading: id=1-0:14.7.0*255/ObisIdentifier:1-0:14.7.0*255 value=49.90 ts=1654341604233
[Jun 04 13:20:04][chn0] Adding reading to queue (value=1520670.00 ts=1654341604233)
[Jun 04 13:20:04][chn1] Adding reading to queue (value=3474656.80 ts=1654341604233)
[Jun 04 13:20:05][mtr0] Got 15 new readings from meter:
[Jun 04 13:20:05][mtr0] Reading: id=1-0:1.8.0*255/ObisIdentifier:1-0:1.8.0*255 value=1520670.00 ts=1654341605226
[Jun 04 13:20:05][mtr0] Reading: id=1-0:2.8.0*255/ObisIdentifier:1-0:2.8.0*255 value=3474658.40 ts=1654341605226
[Jun 04 13:20:05][mtr0] Reading: id=1-0:16.7.0*255/ObisIdentifier:1-0:16.7.0*255 value=-7359.00 ts=1654341605226
[Jun 04 13:20:05][mtr0] Reading: id=1-0:32.7.0*255/ObisIdentifier:1-0:32.7.0*255 value=233.40 ts=1654341605226
[Jun 04 13:20:05][mtr0] Reading: id=1-0:52.7.0*255/ObisIdentifier:1-0:52.7.0*255 value=238.00 ts=1654341605226
[Jun 04 13:20:05][mtr0] Reading: id=1-0:72.7.0*255/ObisIdentifier:1-0:72.7.0*255 value=234.30 ts=1654341605226
[Jun 04 13:20:05][mtr0] Reading: id=1-0:31.7.0*255/ObisIdentifier:1-0:31.7.0*255 value=11.59 ts=1654341605226
[Jun 04 13:20:05][mtr0] Reading: id=1-0:51.7.0*255/ObisIdentifier:1-0:51.7.0*255 value=11.57 ts=1654341605226
[Jun 04 13:20:05][mtr0] Reading: id=1-0:71.7.0*255/ObisIdentifier:1-0:71.7.0*255 value=11.65 ts=1654341605226
[Jun 04 13:20:05][mtr0] Reading: id=1-0:81.7.1*255/ObisIdentifier:1-0:81.7.1*255 value=118.00 ts=1654341605226
[Jun 04 13:20:05][mtr0] Reading: id=1-0:81.7.2*255/ObisIdentifier:1-0:81.7.2*255 value=238.00 ts=1654341605226
[Jun 04 13:20:05][mtr0] Reading: id=1-0:81.7.4*255/ObisIdentifier:1-0:81.7.4*255 value=149.00 ts=1654341605226
[Jun 04 13:20:05][mtr0] Reading: id=1-0:81.7.15*255/ObisIdentifier:1-0:81.7.15*255 value=156.00 ts=1654341605226
[Jun 04 13:20:05][mtr0] Reading: id=1-0:81.7.26*255/ObisIdentifier:1-0:81.7.26*255 value=156.00 ts=1654341605226
[Jun 04 13:20:05][mtr0] Reading: id=1-0:14.7.0*255/ObisIdentifier:1-0:14.7.0*255 value=49.90 ts=1654341605226
[Jun 04 13:20:05][chn0] Adding reading to queue (value=1520670.00 ts=1654341605226)
[Jun 04 13:20:05][chn1] Adding reading to queue (value=3474658.40 ts=1654341605226)
[Jun 04 13:20:06][mtr0] Got 15 new readings from meter:
[Jun 04 13:20:06][mtr0] Reading: id=1-0:1.8.0*255/ObisIdentifier:1-0:1.8.0*255 value=1520670.00 ts=1654341606236
[Jun 04 13:20:06][mtr0] Reading: id=1-0:2.8.0*255/ObisIdentifier:1-0:2.8.0*255 value=3474660.00 ts=1654341606236
[Jun 04 13:20:06][mtr0] Reading: id=1-0:16.7.0*255/ObisIdentifier:1-0:16.7.0*255 value=-7357.00 ts=1654341606236
[Jun 04 13:20:06][mtr0] Reading: id=1-0:32.7.0*255/ObisIdentifier:1-0:32.7.0*255 value=233.30 ts=1654341606236
[Jun 04 13:20:06][mtr0] Reading: id=1-0:52.7.0*255/ObisIdentifier:1-0:52.7.0*255 value=238.10 ts=1654341606236
[Jun 04 13:20:06][mtr0] Reading: id=1-0:72.7.0*255/ObisIdentifier:1-0:72.7.0*255 value=234.20 ts=1654341606236
[Jun 04 13:20:06][mtr0] Reading: id=1-0:31.7.0*255/ObisIdentifier:1-0:31.7.0*255 value=11.65 ts=1654341606236
[Jun 04 13:20:06][mtr0] Reading: id=1-0:51.7.0*255/ObisIdentifier:1-0:51.7.0*255 value=11.59 ts=1654341606236
[Jun 04 13:20:06][mtr0] Reading: id=1-0:71.7.0*255/ObisIdentifier:1-0:71.7.0*255 value=11.70 ts=1654341606236
[Jun 04 13:20:06][mtr0] Reading: id=1-0:81.7.1*255/ObisIdentifier:1-0:81.7.1*255 value=118.00 ts=1654341606236
[Jun 04 13:20:06][mtr0] Reading: id=1-0:81.7.2*255/ObisIdentifier:1-0:81.7.2*255 value=238.00 ts=1654341606236
[Jun 04 13:20:06][mtr0] Reading: id=1-0:81.7.4*255/ObisIdentifier:1-0:81.7.4*255 value=150.00 ts=1654341606236
[Jun 04 13:20:06][mtr0] Reading: id=1-0:81.7.15*255/ObisIdentifier:1-0:81.7.15*255 value=156.00 ts=1654341606236
[Jun 04 13:20:06][mtr0] Reading: id=1-0:81.7.26*255/ObisIdentifier:1-0:81.7.26*255 value=157.00 ts=1654341606236
[Jun 04 13:20:06][mtr0] Reading: id=1-0:14.7.0*255/ObisIdentifier:1-0:14.7.0*255 value=49.90 ts=1654341606236
[Jun 04 13:20:06][chn0] Adding reading to queue (value=1520670.00 ts=1654341606236)
[Jun 04 13:20:06][chn1] Adding reading to queue (value=3474660.00 ts=1654341606236)
[Jun 04 13:20:07][mtr0] Got 15 new readings from meter:
[Jun 04 13:20:07][mtr0] Reading: id=1-0:1.8.0*255/ObisIdentifier:1-0:1.8.0*255 value=1520670.00 ts=1654341607229
[Jun 04 13:20:07][mtr0] Reading: id=1-0:2.8.0*255/ObisIdentifier:1-0:2.8.0*255 value=3474663.50 ts=1654341607229
[Jun 04 13:20:07][mtr0] Reading: id=1-0:16.7.0*255/ObisIdentifier:1-0:16.7.0*255 value=-7361.00 ts=1654341607229
[Jun 04 13:20:07][mtr0] Reading: id=1-0:32.7.0*255/ObisIdentifier:1-0:32.7.0*255 value=233.30 ts=1654341607229
[Jun 04 13:20:07][mtr0] Reading: id=1-0:52.7.0*255/ObisIdentifier:1-0:52.7.0*255 value=238.10 ts=1654341607229
[Jun 04 13:20:07][mtr0] Reading: id=1-0:72.7.0*255/ObisIdentifier:1-0:72.7.0*255 value=234.40 ts=1654341607229
[Jun 04 13:20:07][mtr0] Reading: id=1-0:31.7.0*255/ObisIdentifier:1-0:31.7.0*255 value=11.70 ts=1654341607230
[Jun 04 13:20:07][mtr0] Reading: id=1-0:51.7.0*255/ObisIdentifier:1-0:51.7.0*255 value=11.57 ts=1654341607230
[Jun 04 13:20:07][mtr0] Reading: id=1-0:71.7.0*255/ObisIdentifier:1-0:71.7.0*255 value=11.64 ts=1654341607230
[Jun 04 13:20:07][mtr0] Reading: id=1-0:81.7.1*255/ObisIdentifier:1-0:81.7.1*255 value=118.00 ts=1654341607230
[Jun 04 13:20:07][mtr0] Reading: id=1-0:81.7.2*255/ObisIdentifier:1-0:81.7.2*255 value=239.00 ts=1654341607230
[Jun 04 13:20:07][mtr0] Reading: id=1-0:81.7.4*255/ObisIdentifier:1-0:81.7.4*255 value=150.00 ts=1654341607230
[Jun 04 13:20:07][mtr0] Reading: id=1-0:81.7.15*255/ObisIdentifier:1-0:81.7.15*255 value=156.00 ts=1654341607230
[Jun 04 13:20:07][mtr0] Reading: id=1-0:81.7.26*255/ObisIdentifier:1-0:81.7.26*255 value=156.00 ts=1654341607230
[Jun 04 13:20:07][mtr0] Reading: id=1-0:14.7.0*255/ObisIdentifier:1-0:14.7.0*255 value=49.90 ts=1654341607230
[Jun 04 13:20:07][chn0] Adding reading to queue (value=1520670.00 ts=1654341607229)
[Jun 04 13:20:07][chn1] Adding reading to queue (value=3474663.50 ts=1654341607229)
[Jun 04 13:20:08][mtr0] Got 15 new readings from meter:
[Jun 04 13:20:08][mtr0] Reading: id=1-0:1.8.0*255/ObisIdentifier:1-0:1.8.0*255 value=1520670.00 ts=1654341608239
[Jun 04 13:20:08][mtr0] Reading: id=1-0:2.8.0*255/ObisIdentifier:1-0:2.8.0*255 value=3474664.60 ts=1654341608239
[Jun 04 13:20:08][mtr0] Reading: id=1-0:16.7.0*255/ObisIdentifier:1-0:16.7.0*255 value=-7358.00 ts=1654341608239
[Jun 04 13:20:08][mtr0] Reading: id=1-0:32.7.0*255/ObisIdentifier:1-0:32.7.0*255 value=233.30 ts=1654341608239
[Jun 04 13:20:08][mtr0] Reading: id=1-0:52.7.0*255/ObisIdentifier:1-0:52.7.0*255 value=238.00 ts=1654341608239
[Jun 04 13:20:08][mtr0] Reading: id=1-0:72.7.0*255/ObisIdentifier:1-0:72.7.0*255 value=234.40 ts=1654341608239
[Jun 04 13:20:08][mtr0] Reading: id=1-0:31.7.0*255/ObisIdentifier:1-0:31.7.0*255 value=11.60 ts=1654341608239
[Jun 04 13:20:08][mtr0] Reading: id=1-0:51.7.0*255/ObisIdentifier:1-0:51.7.0*255 value=11.47 ts=1654341608239
[Jun 04 13:20:08][mtr0] Reading: id=1-0:71.7.0*255/ObisIdentifier:1-0:71.7.0*255 value=11.58 ts=1654341608239
[Jun 04 13:20:08][mtr0] Reading: id=1-0:81.7.1*255/ObisIdentifier:1-0:81.7.1*255 value=119.00 ts=1654341608239
[Jun 04 13:20:08][mtr0] Reading: id=1-0:81.7.2*255/ObisIdentifier:1-0:81.7.2*255 value=239.00 ts=1654341608239
[Jun 04 13:20:08][mtr0] Reading: id=1-0:81.7.4*255/ObisIdentifier:1-0:81.7.4*255 value=149.00 ts=1654341608239
[Jun 04 13:20:08][mtr0] Reading: id=1-0:81.7.15*255/ObisIdentifier:1-0:81.7.15*255 value=156.00 ts=1654341608239
[Jun 04 13:20:08][mtr0] Reading: id=1-0:81.7.26*255/ObisIdentifier:1-0:81.7.26*255 value=157.00 ts=1654341608239
[Jun 04 13:20:08][mtr0] Reading: id=1-0:14.7.0*255/ObisIdentifier:1-0:14.7.0*255 value=49.90 ts=1654341608239
[Jun 04 13:20:08][chn0] Adding reading to queue (value=1520670.00 ts=1654341608239)
[Jun 04 13:20:08][chn1] Adding reading to queue (value=3474664.60 ts=1654341608239)
time meter uuid value
04.06.2022 16:20 ZStand_Bezug 86d93a20-28ea-11eb-88b2-a77c66ef7609 1520670
04.06.2022 16:20 ZStand_Einsp d9c9e31e-25b3-471b-a4f0-9725e195b6e3 3502575.4
04.06.2022 16:21 Bez/Einsp b6d3b4b7-93bc-4ddf-b360-910909db8d1c -3578.6469
04.06.2022 16:21 ZStand_Bezug 86d93a20-28ea-11eb-88b2-a77c66ef7609 1520670
04.06.2022 16:21 ZStand_Einsp d9c9e31e-25b3-471b-a4f0-9725e195b6e3 3502635.5
04.06.2022 16:22 Bez/Einsp b6d3b4b7-93bc-4ddf-b360-910909db8d1c -3691.447878
04.06.2022 16:22 ZStand_Bezug 86d93a20-28ea-11eb-88b2-a77c66ef7609 1520670
04.06.2022 16:22 ZStand_Einsp d9c9e31e-25b3-471b-a4f0-9725e195b6e3 3502696 7
04.06.2022 16:23 Bez/Einsp b6d3b4b7-93bc-4ddf-b360-910909db8d1c -3786.521511
04.06.2022 16:23 ZStand_Bezug 86d93a20-28ea-11eb-88b2-a77c66ef7609 1520670
04.06.2022 16:23 ZStand_Einsp d9c9e31e-25b3-471b-a4f0-9725e195b6e3 3502760
"retry" : 3,
"daemon": true,
"verbosity" : 3,
"local" : {
"enabled" : false,
"port" : 80,
"index" : true,
"timeout" : 30,
"buffer" : 600
"meters" : [
"enabled" : true,
"protocol" : "sml",
"parity" : "8N1",
"baudrate" : 9600,
"aggtime" : 60,
"channels": [{
"api" : "influxdb",
"aggmode" : "MAX",
"tags": "meter=ZStand_Bezug", // Optional:Hier kann für den Wert ein oder mehr entsprechende Tags vergeben
"duplicates" : 3600
"api" : "influxdb",
"aggmode" : "MAX",
"tags": "meter=ZStand_Einsp", // Optional:kann für den Wert ein oder mehr entsprechende Tags vergeben werden
"duplicates" : 3600
"api" : "influxdb",
"uuid" : "b6d3b4b7-93bc-4ddf-b360-910909db8d1c", /* uuid neu generiert */
"identifier" : "1-0:16.7.0", /* Leistung */
"aggmode" : "avg",
"tags": "meter=Bez/Einsp", // Optional:kann für den Wert ein oder mehr entsprechende Tags vergeben werden
"duplicates" : 3600
Mitglieder in diesem Forum: MeisterKnut und 2 Gäste
