hier mal meine conf.
  "retry": 0,
  "daemon": true,
  "verbosity": 0,
  "log": "/var/log/vzlogger.log",
  "local": {
    "enabled": false,
    "port": 8080,
    "index": false,
    "timeout": 0,
    "buffer": 0
  "mqtt": {
        "enabled": true,  // enable mqtt client. needs host and port as well
        "host": "192.168.1.2", // mqtt server addr
        "port": 1883, // 1883 for unencrypted, 8883 enc, 8884 enc cert needed,
        "topic": "vzlogger/data",
        "user": "mosquitto", // optional user name for the mqtt server
        "pass": "*****", // optional password for the mqtt server
        "timestamp": true
  "meters": [
      "enabled": true,
      "allowskip": false,
      "aggtime": 10,
      "aggfixedinterval": true,
      "protocol": "sml",
      "device": "/dev/ttyUSB0",
      "baudrate": 9600,
      "parity": "8n1",
      "read_timeout": 10,
      "use_local_time": true,
      "channels": [{
        "api": "influxdb",
        "host": "192.168.1.2:8086",
        "database": "vzlogger",
        "measurement_name": "vz_measurement",
        "username": "vzlogger",
        "password": "*****",
        "uuid" : "a459ce20-f9fb-11ec-9325-370205639ef0",
        "identifier" : "1-0:16.7.0",
        "aggmode": "avg"
        "api": "influxdb",
        "uuid" : "4bbe4d30-2609-11ec-964c-9b38916f31b2",
        "identifier" : "1-0:1.8.0",
        "aggmode": "max"
        "api": "influxdb",
        "uuid" : "6afec810-2609-11ec-a2e3-d1cbc17562af",
        "identifier" : "1-0:2.8.0",
        "aggmode": "max"
