ist nicht wichtig, aber es lässt mir keine Ruhe, warum ich die Reihenfolge nicht dahingehend ändern kann, dass "Verbrauch jetzt" an dritter Stelle erscheint?
Hat jemand bitte einen Tipp für mich? Komme allein nicht weiter.
"id": 30,
"gridPos": {
"h": 7,
"w": 6,
"x": 12,
"y": 6
"type": "graph",
"title": "Victron (Wand)",
"datasource": {
"type": "datasource",
"uid": "-- Mixed --"
"thresholds": [],
"pluginVersion": "9.2.3",
"links": [],
"legend": {
"alignAsTable": false,
"avg": false,
"current": false,
"max": false,
"min": false,
"rightSide": false,
"show": false,
"total": false,
"values": false
"aliasColors": {
"Reglertemperatur": "#bf1b00",
"anzeige.PV_Ladeleistung": "#7eb26d",
"anzeige.PV_Leistung": "#7eb26d",
"anzeige.Temperatur": "#bf1b00"
"bars": false,
"dashLength": 10,
"dashes": false,
"fieldConfig": {
"defaults": {
"links": []
"overrides": []
"fill": 0,
"fillGradient": 0,
"hiddenSeries": false,
"interval": "",
"lines": true,
"linewidth": 1,
"nullPointMode": "null",
"options": {
"alertThreshold": true
"percentage": false,
"pointradius": 5,
"points": false,
"renderer": "flot",
"seriesOverrides": [
"$$hashKey": "object:159",
"alias": "Solarspannung",
"yaxis": 2
"$$hashKey": "object:151",
"alias": "Sun altitude",
"color": "#FADE2A",
"dashes": true,
"fill": 0,
"legend": false,
"yaxis": 2
"$$hashKey": "object:220",
"alias": "PV.Spannung",
"color": "#3274D9",
"fill": 0,
"yaxis": 2
"spaceLength": 10,
"stack": false,
"steppedLine": false,
"targets": [
"alias": "Solarleistung",
"datasource": {
"type": "influxdb",
"uid": "3KYaASkgz"
"groupBy": [],
"hide": false,
"measurement": "PV",
"orderByTime": "ASC",
"policy": "default",
"refId": "A",
"resultFormat": "time_series",
"select": [
"params": [
"Leistung"
"type": "field"
"tags": []
"datasource": {
"type": "influxdb",
"uid": "3KYaASkgz"
"groupBy": [],
"measurement": "Batterie",
"queryType": "randomWalk",
"refId": "B",
"select": [
"params": [
"Ladestrom"
"type": "field"
"tags": [],
"target": "sun_altitude"
"datasource": {
"type": "fetzerch-sunandmoon-datasource",
"uid": "Igds7Hkgz"
"refId": "C",
"timeRegions": [],
"tooltip": {
"shared": true,
"sort": 0,
"value_type": "individual"
"transparent": true,
"xaxis": {
"mode": "time",
"show": true,
"values": [],
"name": null,
"buckets": null
"yaxes": [
"$$hashKey": "object:184",
"format": "watt",
"label": "Watt",
"logBase": 1,
"min": "0",
"show": true
"$$hashKey": "object:185",
"decimals": 0,
"format": "short",
"label": "Spannung",
"logBase": 1,
"max": "110",
"min": "0",
"show": true
"yaxis": {
"align": false
"timeFrom": null,
"timeShift": null
