MQTT Protokoll - Konfigurationsanleitung
MichaelS
- Hat sich bedankt: 31 Mal
Re: MQTT Protokoll - Konfigurationsanleitung
p.s.: Wenn ich den Adapter im IO-Broker starte, genauer gesagt also die Instanz, dann führt er die ganzen Objekte auf:
mqtt-client.0 2020-10-11 09:44:24.228 info (3455) enabled syncing of mqtt-client.0.solaranzeige.box1.adresse (publish/subscribe:false/true)
mqtt-client.0 2020-10-11 09:44:24.226 info (3455) enabled syncing of mqtt-client.0.solaranzeige.box1.laenge (publish/subscribe:false/true)
mqtt-client.0 2020-10-11 09:44:24.225 info (3455) enabled syncing of mqtt-client.0.solaranzeige.box1.protocol (publish/subscribe:false/true)
mqtt-client.0 2020-10-11 09:44:24.223 info (3455) enabled syncing of mqtt-client.0.solaranzeige.box1.transaction (publish/subscribe:false/true)
mqtt-client.0 2020-10-11 09:44:24.221 info (3455) enabled syncing of mqtt-client.0.solaranzeige.box1.wattstundengesamtheute (publish/subscribe:false/true)
mqtt-client.0 2020-10-11 09:44:24.219 info (3455) enabled syncing of mqtt-client.0.Sonoff.tele.LWT (publish/subscribe:false/true)
mqtt-client.0 2020-10-11 09:44:24.217 info (3455) enabled syncing of mqtt-client.0.sonoff.tele.LWT (publish/subscribe:false/true)
mqtt-client.0 2020-10-11 09:44:24.037 warn (3455) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
mqtt-client.0 2020-10-11 09:44:23.956 info (3455) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.mqtt-client, node: v10.21.0, js-controller: 3.1.6
host.raspberrypi 2020-10-11 09:44:20.705 info instance system.adapter.mqtt-client.0 started with pid 3455
host.raspberrypi 2020-10-11 09:44:20.680 info "system.adapter.mqtt-client.0" enabled
Und danach kommt dann dies:
mqtt-client.0 2020-10-11 09:44:24.934 warn (3455) client offline
mqtt-client.0 2020-10-11 09:44:55.005 info (3455) connected to broker
mqtt-client.0 2020-10-11 09:44:54.937 info (3455) trying to reconnect to broker
mqtt-client.0 2020-10-11 09:44:24.907 info (3455) connected to broker
mqtt-client.0 2020-10-11 09:44:24.545 info (3455) Try to connect to mqtt://admin:*******************@192.168.178.195:1883?clientId=1
Ich schau mir die Logs auf solaranzeige nochmal an, ob da was gemeldet wird.
LG
M
LG
M
MichaelS
p.s.: Dies ist bei mir das solaranzeige.log:
11.10. 09:57:02 |---------------- Start solaredge_serie.php ---------------
11.10. 09:57:02 o -Hardware Version: 4B
11.10. 09:57:02 + -40000: 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
11.10. 09:57:02 -MQTT Daten zum [ localhost ] senden.
11.10. 09:57:02 * -Daten zur lokalen InfluxDB [ solaranzeige ] gesendet.
11.10. 09:57:56 -WattstundenGesamtHeute: 1035.57
11.10. 09:57:56 |---------------- Stop solaredge_serie.php ---------------
11.10. 09:57:58 MQT-Ende der Verarbeitung. (MQTT)
11.10. 09:58:02 MQT-0-CONX-OK|
11.10. 09:58:02 |---------------- Start solaredge_serie.php ---------------
11.10. 09:58:02 o -Hardware Version: 4B
11.10. 09:58:02 + -40000: 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
11.10. 09:58:02 -MQTT Daten zum [ localhost ] senden.
11.10. 09:58:02 * -Daten zur lokalen InfluxDB [ solaranzeige ] gesendet.
pi@solaranzeige:~ $
Das sieht ja eigentlich sehr gut aus, oder nicht?
@ Reinald: Hast Du im Log auch diese Meldung "-Daten zur lokalen InfluxDB [ solaranzeige ] gesendet"?
Und Du solltest ja auch die Meldung haben "-MQTT Daten zum [ localhost ] senden." samt Datenstring.
@ Ulrich: Wenn das System doch Daten zum localhost MQTT sendet, warum meint der Client dann, 3455 client offline?
Ist das evtl ein Sync-Problem? Denn irgendwann löscht MQTT doch seine Daten auf der solaranzeige. Und vielleicht löscht er schon, bevor der Client abholen kann?
LG
M
pi@solaranzeige:~ $
LG
M
Der ioBroker versucht sich mit User "admin" und Kennwort "...." anzumelden.MichaelS hat geschrieben: ↑So 11. Okt 2020, 09:55mqtt-client.0 2020-10-11 09:44:24.934 warn (3455) client offline
Der Broker auf dem Raspberry hat aber keine Zugangsbeschränkung. Benötigt also keine UserID und Kennwort. Kann das das Problem sein?
Ein Broker funktioniert in diesem Fall so:@ Ulrich: Wenn das System doch Daten zum localhost MQTT sendet, warum meint der Client dann, 3455 client offline?
Wenn ein Client die Nachrichten von der Solaranzeige empfangen soll, [subscribe] dann liest er alle Nachrichten die von der Solaranzeige kommen. Der Client muss also bevor die Daten kommen "online" sein. Die Daten kommemn pro Minute ein mal.
Hat der Client die Nachrichten gelesen, werden sie vom Broker gelöscht.
Ist der Client "offline" und es kommen Daten, werden sie vom Broker gelöscht. So können keine Daten verloren gehen.
MichaelS
Das war mein Versuch, ob es am "fehlenden" User liegen könnte und da hatte ich dann die Credentials von der solaranzeige mitgegeben.
Ohne diese Credentials im Client sieht das Log so aus:
mqtt-client.0 2020-10-11 10:32:05.777 warn (3857) client offline
mqtt-client.0 2020-10-11 10:32:05.766 info (3857) connected to broker
mqtt-client.0 2020-10-11 10:32:05.751 info (3857) trying to reconnect to broker
mqtt-client.0 2020-10-11 10:31:35.748 warn (3857) client offline
mqtt-client.0 2020-10-11 10:31:35.487 info (3857) connected to broker
mqtt-client.0 2020-10-11 10:31:35.151 info (3857) Try to connect to mqtt://192.168.178.195:1883?clientId=1
mqtt-client.0 2020-10-11 10:31:35.150 info (3857) enabled syncing of mqtt-client.0.solaranzeige.box1.objekt (publish/subscribe:false/true)
mqtt-client.0 2020-10-11 10:31:35.148 info (3857) enabled syncing of mqtt-client.0.solaranzeige.box1.regler (publish/subscribe:false/true)
mqtt-client.0 2020-10-11 10:31:35.145 info (3857) enabled syncing of mqtt-client.0.solaranzeige.box1.batterie1status (publish/subscribe:false/true)
(Auszug: Es werden alle Objekte aufgeführt)
Also insofern: Guter Hinweis, aber daran liegt es nicht.
LG
M
LG
M
danke an Ulrich und Michael.
Ich habe einfach mal ein neues Image aufgespielt, und es geht jetzt auf der Solaranzeige-Seite. Hatte mich auch schon gewundert, bisher bin ich immer suuuuper zufrieden mit der Lösung.
Aber auf IOBroker sagt er, das etwas veraltert ist und somit kein Anzeige. Mal sehen, eigentlich ist alles aktuell.
Gruß Reinald
Gruß Reinald
wolkenloser
- Hat sich bedankt: 2 Mal
Hallo, ich bin recht neu hier.
Mein Raspi läuft jetzt seit Mai 2021 ohne Probleme.
Jetzt wollte ich die Daten mal an meine IOBROKER senden. Da kommt aber nichts an. Ich habe den Threat hier gefunden und die MQTT Anmeldedaten eingetragen und auch den Eintag "extension=mosquitto.so" gefunden.
Leider ist es so wie bei dem Kollegen, der 2020 schon das Problem hatte.
Mit "mosquitto_sub -h localhost -v -t solaranzeige/box1/#" kommt keine Anzeige.
"box1" passt auch.
"Software Version 4.7.2a update April 2021"
Hat sich inzwischen hier was neues ergeben ?
Es gibt keine bekannten Probleme mehr. Es sollte alles funktionieren. Hast Du das Dokument "MQTT" durchgelesen?
download/MQTT%20Informationen%20zur%20Solaranzeige.pdf
Hallo Ulrich oder andere MQTT Spezies,
Ich habe einen WR (Effekta AX) und Batterien (US2000B).
Ich bekomme das mit dem Senden für den WR hin - dies ist Gerät "1", also in der 1.user.config.php konfiguriert.
Die Batteriedaten werden jedoch nicht gesendet - dies ist Gerät "2", also in der 2.user.config.php konfiguriert.
Beide user Dateien sind identisch was den Broker angeht. Ich habe die Version solaranzeige_V4.6.7
In der Log-Datei werden keine Fehler angezeigt, die auf ein Problem hindeuten.
Nachtrag:
Es werden alle Daten bei dem Akku versucht zu senden - das sind zu viele! - Habe ich auf einen Wert reduziert bei MQTTAuswahl - nimmt trotzdem alle Werte)
Daten vom WR werden immer noch gesendet.
Nach Dokumentation: Wird bei MQTTAuswahl z.B. nur box1/Solarspannung eingetragen, dann wird auch nur dieser Wert
übertragen. Auch wenn bei einer Multi-Regler-Version config Dateien ohne Einträge dazwischen sind.
Die zwei Sätze verstehe ich noch nicht.
Kann mir jemand helfen?
Danke und viele Grüße
Nachtrag:
WulleOnTour
Moin Leute,
ich bräuchte mal eure Hilfe.
Habe eine Multiregler Version am laufen. 2 Victrons und ein Sonoff, sprich 3 user Config dateien.
Jetzt möchte ein BMS über Mqtt einbinden. Für dieses JKBMS gibt einen Sketch was auf einen ESP drauf kommt.
Mein Plan war es jetzt, eine 4 User config datei zu erstellen.
Nur was Trage ich als Regler ein?
0 funktioniert nicht.
Hier einen Ausschnitt aus dem ESP32 Sketch
Wie man sieht, steht die Gerätenummer drin.
Meine 4.user.config.php sieht so aus:
Es gibt noch einen iobroker im Netz, das hat beiden andern Geräten funktioniert.
Die Große frage, was trage ich als Regler ein???
Weil 0 wird als Ungültig erklärt und alle andern empfangen keine Daten!
cellStr = String(Balance_Curr,3);
client.publish("solaranzeige/anzeige/4/Balance_Current",cellStr.c_str());
cellStr = String(sec);
client.publish("solaranzeige/anzeige/4/Sekunde",cellStr.c_str());
cellStr = String(mi);
client.publish("solaranzeige/anzeige/4/Minuten",cellStr.c_str());
cellStr = String(hr);
client.publish("solaranzeige/anzeige/4/Stunden",cellStr.c_str());
cellStr = String(days);
client.publish("solaranzeige/anzeige/4/Tage",cellStr.c_str());
cellStr = String(charge);
client.publish("solaranzeige/anzeige/4/Charge",cellStr.c_str());
cellStr = String(discharge);
client.publish("solaranzeige/anzeige/4/Discharge",cellStr.c_str());
}Meine 4.user.config.php sieht so aus:
<?php
// Hier werden die Kunden spezifischen Einstellungen (c) U.Kunz 2016
// vorgenommen, damit keine der Daten bei einem Softwareupdate
// überspielt werden. Diese Datei bitte mit Vorsicht
// ändern. Die Form und die Schreibweise darf in keinen Fällen
// geändert werden. Weitere Hilfe finden Sie im FORUM www.solaranzeige.de
// Diese Datei ist hier zu finden: /var/www/html/user.config.php
// REGLER und WECHSELRICHTER REGLER und WECHSELRICHTER REGLER
// Diese Regler knnen derzeit mit der Software benutzt werden:
// Welcher Regler wird benutzt?
// 1 = ivt-Hirschau Regler SCPlus oder SCDPlus
// 2 = Steca Regler Tarom 6000 und Tarom 4545
// 3 = Regler der Tracer Serie z.B. Tracer2210A
// mit RS-485 zu USB Anschlusskabel (MODBUS) (Unbedingt FTDI Chipsatz)
// 4 = BlueSolar oder SmartSolar Regler von Victron-energy mit
// VE.Direkt zu USB Anschlusskabel
// [Im Moment noch nicht in Betrieb]
// Zusätzlich kann ein MultiPlus Wechselrichter mit einem MK3 USB Kabel
// angeschlossen werden.
// 5 = Micro Wechselrichter von AEconversion z.B. INV250-45
// mit RS-485 zu USB Anschlusskabel (Unbedingt FTDI Chipsatz)
// 6 = Victron BMV 7xx Batteriewächter
// mit VE.direct zu USB Kabel
// 7 = Voltronic Geräte der Axpert Serie
// Effekta Geräte der AX und HX Serie,
// Steca Solarix PLI 5000-48,
// InfiniSolar PIP Serie 3k,
// MPPSolar PIP HSP/MSP , MS/MSX und MSD Serien
// EAsun ISolar SPV SMV 1KVA-5KVA Inverter
// EAsun IGrid VE
// mit einfachem USB Kabel (A und B Stecker)
// (Kein Seriell zu USB Wandler!)
// 8 = InfiniSolar V Serie , MPP Solar HSE/MSE Serie und viele Baugleiche.
// mit einfachem USB Kabel (A und B Stecker) (Kein Seriell zu USB Wandler!)
// 9 = MPPSolar MPI Hybrid Serie 3 Phasen Inverter
// Baugleich: FSP 5,5 Hybrid und Panta 10 Hybrid
// 10 = SolarMax S-Serie
// mit Ethernet (LAN) Kabel Anschluss.
// 11 = Phoenix Wechselrichter von Victron mit VE.direct Kabel Anschluss
// 12 = Fronius Symo Wechselrichter inkl. Hybrid Geräte und Fronius Prymo
// MIT Ethernet (LAN) Kabel Anschluss
// 13 = Joulie-16 Batterie-Management-System von AutarcTech (BMS)
// Mit LAN Anschluss
// 14 = Rover Laderegler von Renogy, Toyo von SRNE und baugleiche
// mit USB Kabel Anschluss
// 15 = PYLONTECH US2000B Plus Batteriespeicher Batterie-Management-System (BMS)
// Mit Seriell zu USB Adapter. Den Console Port im Gerät benutzen.
// 16 = SolarEdge 3 Phasen Wechselrichter mit LAN Schnittstelle
// (Für 1 Phasen Geräte muss das Dashboard geändert werden)
// 17 = KOSTAL Plenticore Wechselrichter und Pico der 3. Generation
// mit LAN Schnittstelle
// 18 = S10E und S10 mini von E3/DC mit LAN Schnittstelle (Port 502)
// Nur im Simple-Mode möglich.
// 19 = eSmart3 Laderegler 40A, 50A, 60A
// 20 = SolarEdge 3 Phasen Wechselrichter ohne MODBUS Zähler
// 21 = KOSTAL Piko mit RS485 Anschluss
// (in der user.config.php muss $WR_IP = "0.0.0.0"; stehen!)
// Eine IP Adresse nur eintragen, wenn man den Piko über das LAN auslesen will.
// Beim PIKO MP Plus in der user.config.php zusätzlich
// $SerielleGeschwindigkeit = 38400; eintragen.
// 22 = Smart Energy Meter von KOSTAL oder Anderen
// 23 = Sonoff / Shelly: POW R2 , TH10 oder TH16 R2 oder GOSUND SP1 oder Shelly 2.5,
// alle mit Tasmota Firmware.
// 24 = Infini xx KW Hybrid Wechselrichter. Protokoll 16 1 Phase
// 25 = SonnenBatterie mit LAN Anschluss
// 26 = MPPSolar 5048MK und 5048GK ( PIP MK und GK Serie )
// EAsun ISolar V III Off-Grid lnverter
// sowie Baugleiche mit USB Anschluss
// 27 = SMA Wechselrichter Sunny Island und Sunny Tripower
// Modbus TCP mit LAN Anschluss
// 28 = HRDi marlec Laderegler für PV und Windgenerator
// mit Seriell - USB Adapter
// 29 = go-e Charger (Wallbox)
// 30 = Keba Wallbox P20 + P30
// 31 = Shelly 3EM
// 32 = KACO Wechselrichter der TL3 Serie
// 33 = Labornetzteil JOY-IT JT-DPM8624
// 34 = SDM630 Energy Meter (RS485 Anschluss)
// 35 = Wallbe Wallbox Eco 2.0 und andere.
// 36 = Delta Wechselrichter SI 2500 mit RS485 Anschluss
// 37 = Simple EVSE WiFi Wallbox
// 38 = ALPHA ESS T10 Wechselrichter + Batteriesystem
// 39 = openWB Wallbox
// 40 = Phocos PH1800 Wechselrichter
// 41 = PylonTech US 3000 A mit RS485 Schnittstelle Anz. Batterie-Packs auch angeben!
// 42 = PV18-3KW VHM oder PV1800 VHM oder Baugleiche mit RS485 Schnittstelle
// 43 = Senec Stromspeicher
// 44 = Webasto Wallbox
// 45 = Phocos Any-Grid mit RS232 zu USB Adapter
// 46 = Huawei SUN2000 Wechselrichter ältere Modelle bis Modell ID 100 (siehe Regler 56)
// 47 = Phoenix Contact Wallbox
// 48 = Growatt Wechselrichter
// 49 = Huawei SmartLogger
// 50 = SDM230 Zähler 1 Phase
// 51 = Siemens PAC2200 SmartMeter
// 52 = Goodwe Wechselrichter der Serien ES , EM und SBP (mit Batterie)
// 53 = Solarlog Pro 380 - Mod
// 54 = SMA Energy Meter 2.0
// 55 = Studer Xtender Wechselrichter inkl BSP
// 56 = Huawei SUN2000 Wechselrichter M0 , M1 und M2 Modelle
// 57 = Daly BMS China
// 58 = SolarEdge Ertragszähler WND-3Y400-MB
// 59 = EASUN POWER Solar Inverter 3KVA mit seriellem Anschluss
// 60 = Hardy Barth Wallbox
// 61 = SMARTPI Zähler
// 62 = Huawei Wechselrichter mit SDongle (LAN Anschluss)
// 63 = cFos Wallbox
// 64 = Goodwe Wechselrichter der Serien ET, EH, BH, BT
// 65 = RCT Wechselrichter
// 66 = Kostal Piko CI
// 67 = Goodwe Wechselrichter XS Serie
// 68 = VARTA Pulse Neo
// 69 = Vestel Wallbox
// 70 = Sungrow Wechselrichter
// 71 = EASUN SMG II Wechselrichter
// 72 = HomeMatic Gaszähler (und andere Geräte. Siehe Homematic.pdf Dokument)
// 73 = SofarSolar Wechselrichter x.x KTL-X
$Regler = "0";
$GeraeteNummer = "4";
// Bei einem Micro Wechselrichter von AEconversion ($Regler = "5")
// und anderen Geräten, die für den Zugang eine Seriennummer benötigen.
// Z.B. Typ INV250-45 oder INV500-60
// Bitte alle 10 Stellen hier eintragen:
// Falls ein WLAN HF2211 serial Gateway benutzt wird true eingeben
$HF2211 = false;
// Nur bei PylonTech BMS US3000A ($Regler = "41" )
// und den neuen US2000 aus dem Jahr 2019 und später
// Anzahl der vorhandenen Batteriepacks
$Batteriepacks = "1";// Regler = "41"
$WR_Port = "12345";
$WR_Adresse = "1";
// Bezeichnung des Objektes. Freie Wahl, maximal 15 Buchstaben.
$Objekt = "";
// InfluxDB InfluxDB InfluxDB InfluxDB InfluxDB InfluxDB
// Die Daten können jede Minute oder öfter an eine InfluxDB Datenbank
// übertragen werden. Die Datenbank muss nur über das Netzwerk erreichbar
// sein. Sie kann sich im lokalen Netz, im Intenet oder aber auch auf diesem
// Raspberry befinden. Bitte lesen Sie auch das Dokument
// "Solaranzeige + InfluxDB" welches Sie auf unserem Support Server finden.
// Sollen die Daten in die lokale Influx Datenbank geschrieben werden?
// Für die lokale Datenbank sind keine weiteren Angaben nötig.
// true oder false
$InfluxDB_local = true;
// Name der lokalen Datenbank. Bitte nicht ändern, sonst funktionieren die
// Standard Dashboards nicht!
// Bei einer Muti-Regler-Version müssen hier unterschiedliche lokale
// Datenbanknamen eingetragen werden. Mit gleichem Namen müssen die Datenbanken
// in der InfluxDB angelegt werden. Siehe Dokument:
// "Multi-Regler-Version Installation"
$InfluxDBLokal = "BMS";
// Wie oft pro Minute sollen die Daten ausgelesen und zur InfluxDB
// übertragen werden?
// Gültige Werte sind 1 bis 6 (6 = alle 10 Sekunden)
// Bei einer zusätzlichen entfernten Datenbank kann das zu erheblichen
// Traffic führen! Dieses gilt nur für die Single-Geräte-Version!
// Wie es bei der Multi-Regler-Version funktioniert bitte in dem
// entsprechenden Dokument nachlesen.
// Default ist 1 (Ein mal pro Minute)
$Wiederholungen = 1;
// true oder false
$InfluxDB_remote = false;
$InfluxPort = 8086;
$InfluxDBName = "BMS";
// Adresse der Datenbank
// Entweder die IP Adresse "xxx.xxx.xxx.xxx" oder den Hostnamen oder "localhost"
// eintragen.
// Beispiel: "db.solaranzeige.de" oder "34.101.3.20"
$InfluxAdresse = "";
// Wenn man mit UserID und Kennwort die Daten übertragen möchte, sollte man
// auf jeden Fall auch die SSL Verschlüsselung einschalten. Dazu muss die
// Influx Datenbank aber erst auf https eingerichtet werden.
$InfluxSSL = false;
// Wenn nicht, bitte leer lassen.
$InfluxUser = "";
$InfluxPassword ="";
// Sollen die Daten nur bei Tageslicht an eine remote Datenbank gesendet werden?
$InfluxDaylight = false;
// HOMEMATIC ANBINDUNG HOMEMATIC ANBINDUNG HOMEMATIC ANBINDUNG
// Teil 1 Teil 1 Teil 1 Teil 1 Teil 1 Teil 1 Teil 1 Teil 1
// Anbindung an eine vorhandene HomeMatic Zentrale
// Für die genaue Einrichtung bitte das PDF Dokument "Homematic_Anschluss.pdf" lesen.
// Es befindet sich auf unserem Support Server im Bereich "Verschiedene PDF Dokumente"
// Kapitel 1 bis 7 Kapitel 1 bis 7 Kapitel 1 bis 7
// Sollen die Daten an eine vorhandene Homematic Zentrale gesendet werden?
// Diese Werte kann dann die Zentrale dann verarbeiten.
// Folgende Werte werden übertragen:
// * Ladestatus 0 = Keine Ladung, 2 = Fehler, 3 = Ladung (bulk); 4 = Nachladung (absorbtion),
// 5 = Erhaltungsladung (float)
// * Ladestatus als Textzeile (Keine_Ladung, Normale_Ladung, Nachladung, Erhaltungsladung, Fehler)
// * Batteriespannung in Volt
// * Erzeugte Leistung am Tage in kWh
// * Aktuell erzeugte Solar-Leistung
// * Batteriestatus in % (Wie voll ist die Batterie?) Nicht bei allen Geräten!
// true / false
$Homematic = false;
// Welche IP Adresse hat Ihre Homematic Zentrale? Sie muss sich im selben
// Netzwerk wie der Raspberry Pi befinden. Beispiel: 192.168.33.200
// Hier die Variablen eintragen, die zur HomeMatic Zentrale übermittelt werden
// sollen. Siehe Dokument "HomeMatic_Anbindung.pdf"
// Beispiel: "BatterieLadestatus,BatteriestatusText,Batteriespannung,Solarleistung,SolarleistungTag,Solarspannung";
$HomeMaticVar = "";
// Den Status einzelner Geräte aus der HomeMatic Zentrale auslesen und in die
// Influx Datenbank schreiben, damit man den Status im Dashboard anzeigen kann.
// Nähere Einzelheiten stehen im Dokument "HomeMatic Anbindung"
$HM_auslesen = false;
// Für jedes Gerät, dessen Status ausgelesen werden soll, müssen 4 Variablen
// angegeben werden.
// $HM[0]["Variable"] = Kann man nennen wie man will, steht dann so in der Influx Datenbank.
// $HM[0]["Interface"] = Steht in der HomeMatic, bitte übernehmen
// $HM[0]["Seriennummer"] = Steht auch in der HomeMatic
// $HM[0]["Datenpunkt"] = STATE, POWER, ACTUAL_TEMPERATURE usw. Siehe HomeMatic
// Für jede Systemvariable müssen 2 Variablen angegeben werden:
// $HM[0]["Variable"] = Kann man nennen wie man will. Steht dann so in der Influx Datenbank
// $HM[0]["Systemvariable"] = Name der Systemvariable in der HomeMatic
// Beispiele: ( Die zwei Schrägstich bei Aktivierung bitte entfernen. )
// $HM[0]["Variable"] = "Wasserboiler";
// $HM[0]["Interface"] = "BidCos-RF";
// $HM[0]["Seriennummer"] = "OEQ1150699:1";
// $HM[0]["Datenpunkt"] = "STATE";
// $HM[1]["Variable"] = "Heizluefter";
// $HM[1]["Interface"] = "BidCos-RF";
// $HM[1]["Seriennummer"] = "OEQ1399311:1";
// $HM[1]["Datenpunkt"] = "STATE";
// $HM[2]["Variable"] = "...";
// $HM[2]["Interface"] = "...";
// $HM[2]["Seriennummer"] = "...";
// $HM[2]["Datenpunkt"] = "POWER";
// $HM[3]["Variable"] = "Anwesenheit";
// $HM[3]["Systemvariable"] = "Anwesenheit";
// usw.
// Teil 2 Teil 2 Teil 2 Teil 2 Teil 2 Teil 2 Teil 2 Teil 2
// Ab Kapitel 7 AB Kapitel 7 AB Kapitel 7
// Möchte man die variablen daten eines an die Homematic angeschlossenen
// Gerätes auslesen, wie z.B. ein Heizkörperventil, dann müssen hier die Daten
// der angeschlossenen Geräte angegeben werden. Nähere Einzelheiten bitte im
// Dokument Homematic_Anbindung.pdf ab Kapitel 7 lesen.
// Beispiel:
// HM_Geraet 1
// $HM_Geraetetyp[1] = "HM-CC-RT-DN"; // Heizungsthermostat
// $HM_Seriennummer[1] = "OEQ2419985"; // Wohnzimmer
// HM_Geraet 2
// $HM_Geraetetyp[2] = "HmIP-eTRV-B"; // Heizungsthermostat
// $HM_Seriennummer[2] = "00201D89A8A446";// Badezimmer
// HM_Geraet 3
// $HM_Geraetetyp[3] = "HmIP-STHD"; // Wandthermostat
// $HM_Seriennummer[3] = "000E9BE9967967";// Badezimmer
// HM_Geraet 4
// $HM_Geraetetyp[4] = "HM-CC-RT-DN"; // Heizungsthermostat
// $HM_Seriennummer[4] = "OEQ2421488"; // Küche
// HM_Geraet 1
$HM_Geraetetyp[1] = ""; // Typenbezeichnung
$HM_Seriennummer[1] = ""; // Seriennummer
// MQTT Protokoll MQTT Protokoll MQTT Protokoll MQTT Protokoll
// Wenn Daten mit dem MQTT Protokoll versendet werden sollen. Hat nichts
// direkt mit den Sonoff Geräten zu tun.
// Sollen alle ausgelesenen Daten mit dem MQTT Protokoll an einen
// MQTT-Broker gesendet werden? Bitte das Solaranzeige-MQTT PDF Dokument lesen
$MQTT = true;
// Wo ist der MQTT-Broker zu finden?
// Entweder "localhost", eine Domain oder IP Adresse "xxx.xxx.xxx.xxx" eintragen.
// broker.hivemq.com ist ein Test Broker Siehe http://www.mqtt-dashboard.com/
$MQTTBroker = "192.168.200.10";
// Benutzter Port des Brokers. Normal ist 1883 mit SSL 8883
$MQTTPort = 1886;
// Falls der Broker gesichert ist. Sonst bitte leer lassen.
$MQTTBenutzer = "mqtt";
$MQTTKennwort = "mqtt1234";
// Wenn man die Daten mit SSL Verschlüsselung versenden möchte.
// Wenn hier true steht, muss im Verzeichnis "/var/www/html/" die "cerfile"
// 'ca.crt' vorhanden sein. Nähere Einzelheiten über diese Datei findet
// man im Internet in der Mosquitto Dokumentation.
$MQTTSSL = false;
// Timeout der Übertragung zum Broker. Normal = 10 bis 60 Sekunden
$MQTTKeepAlive = 60;
// Topic Name oder Nummer des Gerätes solaranzeige/1
// oder solaranzeige/box1 (solaranzeige ist fest vorgegeben.)
// Man kann das Gerät nennen wie man will, nur jedes Gerät, welches Daten
// senden soll unterschiedlich. Entwerder 1 bis 6 oder Namen Ihrer Wahl vergeben.
$MQTTGeraet = "BMS";
// Welche Daten sollen als MQTT Message übertragen werden? Wenn hier nichts
// aufgeführt ist, werden alle ausgelesenen Daten übertragen.
// Bitte darauf achten, dass keine Leerstellen zwischen den Variablen sind.
// Die einzelnen Variablen müssen mit einem Komma getrennt und klein geschrieben
// werden. Zusätzlich müssen sie den Eintrag vom $MQTTGeraet und ein Schrägstrich
// enthalten. Das ist nötig, da mehrere Geräte an dem Raspberry hängen können.
// Beispiel mit obigen MQTTGeraet:
// $MQTTAuswahl = "1/ladestatus,1/solarspannung,1/solarstrom"
// Werden hier Variablen eingetragen, dann werden auch nur diese Topics
// übertragen.
$MQTTAuswahl = "";
// MQTT Empfang MQTT Empfang MQTT Empfang MQTT Empfang
// Subscribing Subscribing Subscribing Subscribing Subscribing
// Welche Daten sollen empfangen werden. Hier können die Topics, die
// empfangen werden sollen aufgeführt werden. Dabei gibt es 2 Möglichkeiten
// Entweder ein einzelner Wert oder eine Reihe von Werten.
// Wichtig! Das basis Topics ist immer solaranzeige. Dann muss entweder befehl
// oder anzeige kommen, dann die Gerätenummer und dann die Bezeichnung des
// Wertes. Die Gerätenummer ist immer 1, außer bei Multi-Regler-Versionen.
// Beispiel: solaranzeige/anzeige/1/PV-Spannung
// In diesem Beispiel wird der Wert der PV-Spannung in die Influx Datenbank
// geschrieben unter dem Measurement MQTT
// oder
// Beispiel: solaranzeige/befehl/1/POP mit Wert 00
// Der Befehl POP00 wird zum Wechselrichter geschickt. Er wird jedoch nur
// ausgeführt wenn es sich um einen erlaubten Befehl handelt, der in der
// Datei "befehle.ini.php" enthalten ist.
// Beispiele:
// $MQTTTopic[1] = "solaranzeige/befehl/1/POP";
// $MQTTTopic[2] = "solaranzeige/befehl/1/PCP";
// $MQTTTopic[3] = "solaranzeige/anzeige/1/Wasserboiler";
// Oder auch
// $MQTTTopic[1] = "solaranzeige/befehl/1/#";
// Es können so viele Topics wie benötigt aufgeführt werden. Sie müssen nur
// durch nummeriert werden [1] bis [n]
// Bei Multi-Regler-Versionen muss zusätzlich noch die Gerätenummer angegeben
// werden. Weitere Informationen finden Sie auf dem Support Forum.
$MQTTTopic[1] = "solaranzeige/anzeige/4/#";
// SONOFF Geräte mit Tasmota Firmware SONOFF Geräte mit Tasmota Firmware
// POW R2 / TH10 R2 oder TH16 R2 oder GOSUND SP1xx
// Bitte den Topic-Namen, der in der TASMOTA Firmware angegeben ist, hier
// eintragen. Unbedingt auf Groß- und Keinschreibung achten! Der Name kann
// frei gewählt werden, er muss nur im Gerät und hier gleich sein. Werden
// mehrere Sonoff Geräte mit der Solaranzeige betrieben, muss jedes einzelne
// Gerät einen anderen Topic-Namen benutzen!
$Topic = "sonoff";
// WETTERDATEN WETTERDATEN WETTERDATEN WETTERDATEN WETTERDATEN
// Die Wetterdaten werden vom Server openweathermap.org geholt, da von dort
// die Informationen kostenlos sind.
// Man muss sich jedoch auf dem Server anmelden, um eine APP ID zu bekommen.
// Bei einer Multi-Regler-Version nur in der 1.user.config.php aktivieren!
// Sollen die aktuellen Wetterdaten geholt und abgespeichert werden?
// Dadurch wird mehr Traffic generiert. Die Daten stehen dann in der Influx
// Datenbank "aktuellesWetter" unter dem Measurement "Wetter" zur Verfügung.
// Sie werden alle 30 Minuten aktualisiert
// true oder false
$Wetterdaten = false;
// Die Application ID bekommt man, wenn man sich auf dem Server
// www.openweathermap.org registriert. Sie hat 32 Stellen und muss hier
// eingetragen werden. Beispiel: "57b78415a343540e3a4e4f72751c90f9"
$APPID = "";
// Der Standort wird mit einer StandortID angegeben. Wie die StandortID
// ermittelt wird, bitte im Support Forum nachlesen. Man kann eine Liste
// aller Standort ID's Weltweit hier herunterladen:
// http://bulk.openweathermap.org/sample/city.list.json.gz
// Default = "2925533" Frankfurt am Main oder die ID Ihres Standortes.
$StandortID = "2925533";
// PROGNOSEDATEN PROGNOSEDATEN PROGNOSEDATEN PROGNOSEDATEN
// Die Wetterprognosedaten werden vom Server www.solarprognose.de geholt.
// Teilweise sind die Daten dort kostenlos. [ www.solarprognose.de ]
// Man muss sich jedoch auf dem Server anmelden, um eine Prognose ID zu bekommen.
// Sollen die aktuellen Prognosedaten geholt und abgespeichert werden?
// Die Daten stehen dann in der Influx Datenbank "solaranzeige" unter dem
// Measurement "Wetterprognose" zur Verfügung. Sie werden pro Stunde einmal
// aktualisiert.
// Möchte man seinen eigenen Prognose Script nutzen, dann bitte hier User eingeben.
// In diesem Fall wird alle 30 Minuten der Script "prognose.php" aufgerufen.
// Dort müssen die Funktionen hinterlegt sein.
// keine, API, User, beide
$Prognosedaten = "keine"; // "keine" , "API" , "User" , "beide"
// Wenn API eingetragen wird, dann folgende 3 Variablen füllen:
$AccessToken = ""; // Bekommt man bei www.solarprognose.de
$PrognoseItem = "inverter"; // plant, inverter
$PrognoseID = "0"; // Anlagen ID oder Wechselrichter ID
$Algorithmus = ""; // kann leer bleiben oder
// // mosmix | own-v1 | clearsky
// MESSENGER MELDUNGEN MESSENGER MELDUNGEN MESSENGER
// Es können Fehlermeldungen, Ereignisse oder Statistiken mit einem
// Messenger übertragen werden. Dazu bitte Messenger = true eintragen
// Genaue Informationen stehen im Dokument "Messenger_Nachrichten.pdf"
// true / false
$Messenger = false;
// Welcher Messengerdienst soll benutzt werden?
// Pushover / Signal / WhatsApp
$Messengerdienst[1] = "Pushover"; // Pushover, Signal oder WhatsApp
// Die Solaranzeige müssen Sie bei Pushover / Signal oder WhatsApp
// registrieren und einen API Token holen.
// Wie das geht, steht in dem Dokument "Messenger_Nachrichten" auf dem
// Support Server
// Pushover Beispiel $API_Token = "amk4be851bcegnirhu1b71u6ou7uoh";
// Signal Beispiel $API_Token = "999999";
$API_Token[1] = "";
// Der User_Key ist die Messeger Empfänger Adresse. Bei Pushover können bis zu
// 9 Empfänger angegeben werden. $User_Key[1] bis $User_Key[9]
// Am Ende jeder Zeile das Semikolon nicht vergessen!
// Pushover Beispiel: $User_Key[1] = "ub6c3wmw4a3idwk9b5ajgfs5a7aypt";
// Siehe Dokument "Nachrichten_senden.pdf"
// Bei WhatsApp und Signal kann nur ein Empfänger angegeben werden, da der Token
// zur Rufnummer passen muss.
// Signal Beispiel: $User_Key[1] = "+491769000000";
$User_Key[1] = "";
// Und jetzt eventuell für weitere Personen:
// $Messengerdienst[2] = ""; // Pushover, WhatsApp oder Signal
// $API_Token[2] = "";
// $User_Key[2] = "";
// $Messengerdienst[3] = ""; / Pushover, WhatsApp oder Signal
// $API_Token[3] = "";
// $User_Key[3] = "";
// Sonnen Auf und Untergang:
// Standort für Frankfurt. Wer es etwas genauer haben möchte, hier den eigenen
// Standort eintragen. Bitte als Dezimalzahl wie hier vorgegeben!
$Breitengrad = 50.1143999;
$Laengengrad = 8.6585178;
// aWATTar Börsenpreise aWATTar Börsenpreise aWATTar Börsenpreise.
// Sollen die aktuellen Strom Börsenpreise in die oben angegebene locale.
// Datenbank in das Measurement "awattarPreise" geschrieben werden?
$aWATTar = false;
$Aufschlag = "0"; // Z.B. "20,6" Preis des Aufschlages in Cent
$aWATTarLand = "DE"; // "DE" = Deutschland "AT" = Österreich
// ACHTUNG! ACHTUNG! ACHTUNG! ACHTUNG! ACHTUNG! ACHTUNG! ACHTUNG!
// Alles ab hier nicht ändern! Nur auf Anweisung. Änderungen hier können
// das System zum Absturz bringen.
// USB Device USB Device USB Device USB Device USB Device
// USB Device, die automatisch erkannt wurde... bitte nicht ändern
$USBRegler = "Ethernet";
$USBDevice = "Ethernet";
// $SerielleGeschwindigkeit = "9600";
// Raspberry Pi Hardware Raspberry Pi Hardware Raspberry Pi Hardware
$Platine = "Raspberry Pi 4 Model B Rev 1.5";
// PHP Error Reporting PHP Error Reporting PHP Error Reporting
// Bei ungeklärten Problemen hier einschalten. Normal = ausgeschaltet
// Ist für die neue Datenbankstruktur des Alpha ESS Wechselrichters
// Mit 0 kann die alte Struktur eingeschaltet werden.
$Alpha_ESS = 0;
Das geht so nicht. Du musst eine eigene Datenbank für den BMS anlegen und dann die Daten über die API in die Datenbank schreiben.
Alles andere ist Murks...
