Growatt SPF Modelle
Growatt SPF Modelle
Alle die ein Growatt SPF.... Modell haben, bitte ein Update auf die Solaranzeige machen. Der Script kann jetzt wesentlich mehr Daten auslesen und läuft stabiler. Und hier gibt es ein Standard Dashboard dazu. Bitte herunterladen und in Grafana importieren:
viewtopic.php?t=188
capoccio1
Re: Growatt SPF Modelle
Beitrag von capoccio1 »
pi@solaranzeige:~ $ hwinfo --usb
18: USB 00.0: 0000 Unclassified device
[Created at usb.122]
Unique ID: BobO.GPdhqcWAsQC
Parent ID: ADDn.IKhPgutgmvF
SysFS ID: /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0
SysFS BusID: 1-1.2:1.0
Hardware Class: unknown
Model: "Exar XR21V1410 USB-UART IC"
Hotplug: USB
Vendor: usb 0x04e2 "Exar Corp."
Device: usb 0x1410 "XR21V1410 USB-UART IC"
Revision: "0.03"
Driver: "cdc_acm"
Driver Modules: "cdc_acm"
Speed: 12 Mbps
Module Alias: "usb:v04E2p1410d0003dcEFdsc02dp01ic02isc02ip01in00"
Driver Info #0:
Driver Status: cdc_acm is active
Driver Activation Cmd: "modprobe cdc_acm"
Attached to: #22 (Hub)
pi@solaranzeige:~ $ lsusb
Bus 001 Device 004: ID 04e2:1410 Exar Corp. XR21V1410 USB-UART IC
Bus 001 Device 003: ID 0424:ec00 Microchip Technology, Inc. (formerly SMSC) SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Microchip Technology, Inc. (formerly SMSC) SMC9514 Hub
capoccio1
hello, my inverter (SPF3500ES) fails to provide data can anyone help me understand why?
capoccio1
this is the user.config.php file:
$Regler = "48";
$GeraeteNummer = "1";
$Seriennummer = "0000000000";
$Zugang_Kennwort = "";
$HF2211 = false;
$Batteriepacks = "1";
$PylonTech = "2000";
$WR_IP = "0.0.0.0";
$WR_Port = "12345";
$WR_Adresse = "1";
$Objekt = "Casetta";
$InfluxDB_local = true;
$InfluxDBLokal = "solaranzeige";
$Wiederholungen = 1;
$InfluxDB_remote = false;
$InfluxPort = 8086;
$InfluxAdresse = "localhost";
$InfluxSSL = false;
$InfluxUser = "";
$InfluxPassword ="";
$InfluxDaylight = false;
$Homematic = false;
$HomeMaticVar = "";
$HM_auslesen = false;
$HM_Geraetetyp[1] = "";
$HM_Seriennummer[1] = "";
$MQTT = true;
$MQTTBroker = "localhost";
$MQTTPort = 1883;
$MQTTBenutzer = "";
$MQTTKennwort = "";
$MQTTSSL = false;
$MQTTKeepAlive = 60;
$MQTTGeraet = "box1";
$MQTTAuswahl = "";
$Topic = "sonoff";
$Wetterdaten = false;
$APPID = "";
$StandortID = "2925533";
$Prognosedaten = "keine";
$AccessToken = "";
$PrognoseItem = "inverter";
$PrognoseID = "0";
$Algorithmus = "";
$Messenger = false;
$Messengerdienst[1] = "Pushover";
$API_Token[1] = " ";
$User_Key[1] = "";
$Breitengrad = 41.689829;
$Laengengrad = 13.581483;
$aWATTar = false;
$Aufschlag = "0";
$aWATTarLand = "DE";
$USBRegler = "/dev/ttyACM0";
$USBDevice = "004";
$Platine = "Raspberry Pi 2 Model B Rev 1.1";
$Alpha_ESS = 0;
