MQTT-Daten in der influxdb
Die Verbindung zum Smart Home und Internet der Dinge (IoT)
hhackenberger
Beitrag von hhackenberger »
Hello!
Vielleicht bin ich auch zu blöd zum Suchen aber wie bekomme ich die MQTT-Daten meiner WLAN-Steckdose in die Influxdb?
Laufen tut es mal laut Log:
14.09. 09:40:09 -MQTT Daten zum [ localhost ] senden.
14.09. 09:40:09 -Alle 10 Minuten werden die Statistikdaten übertragen.
14.09. 09:40:09 * -Daten zur lokalen InfluxDB [ solaranzeige ] gesendet.
14.09. 09:40:09 MQT-MQTT Daten zum Broker gesendet bzw. vom Broker empfangen. Adresse: localhost Port: 1883
Ich sehe auch so den Status und die Werte:
mosquitto_sub -h localhost -v -t +/#
tele/Refoss-P11/LWT Online
tasmota/discovery/34945491E1F7/config {"ip":"10.0.0.22","dn":"Tasmota","fn":["Tasmota",null,null,null,null,null,null,null],"hn":"Refoss-P11-0503","mac":"34945491E1F7","md":"Refoss-P11","ty":0,"if":0,"ofln":"Offline","onln":"Online","state":["OFF","ON","TOGGLE","HOLD"],"sw":"12.4.0","t":"Refoss-P11","ft":"%prefix%/%topic%/","tp":["cmnd","stat","tele"],"rl":[1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"swc":[-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1],"swn":[null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null],"btn":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"so":{"4":0,"11":0,"13":0,"17":0,"20":0,"30":0,"68":0,"73":0,"82":0,"114":0,"117":0},"lk":0,"lt_st":0,"sho":[0,0,0,0],"sht":[[0,0,0],[0,0,0],[0,0,0],[0,0,0]],"ver":1}
tasmota/discovery/34945491E1F7/sensors {"sn":{"Time":"2023-09-14T08:22:40","ANALOG":{"Temperature":23.9},"ENERGY":{"TotalStartTime":"2023-09-12T10:20:42","Total":0.102,"Yesterday":0.052,"Today":0.050,"Power":143,"ApparentPower":187,"ReactivePower":120,"Factor":0.77,"Voltage":225,"Current":0.829},"TempUnit":"C"},"ver":1}
Aber wo stehen dann diese Werte in der DB, damit ich sie in einem Dashboard dann auch anzeigen kann?
Bei mir fehlt das Measurement MQTT, so wie hier beschrieben:
influx + ENTER
>use 'solaranzeige' + ENTER („anstatt des Datenbanknamens 'solaranzeige' bitte ihr gewählter
Datenbankname eintragen. In der Multi-Regler-Version muss jedes Gerät einen anderen Datenbanknamen
besitzen. Diesen Namen gibt man in der x.user.config.php an.)
>show measurements + ENTER
>select * from MQTT limit 10 + ENTER
Ich habe eine "Refoss-P11"-Steckdose mit Tasmota 12.4.0.
Danke schon mal im Voraus.
tirolerbua
Hat sich bedankt: 4 Mal
Re: MQTT-Daten in der influxdb
Beitrag von tirolerbua »
konntest du inzwischen die Daten weiterverarbeiten?
Hab eigentlich dasselbe Problem - ich bekomme Daten vom Stromzähler die sehe ich dann, gleich wie du beschrieben hast in mosquitto ---nur wie bringe ich das jetzt in die influx?
DANKE
Hat sich bedankt: 166 Mal
Danksagung erhalten: 814 Mal
tirolerbua hat geschrieben:
Di 13. Feb 2024, 14:48
DANKE
Die Solaranzeige kann das nicht. Dazu musst du ein anderes Programm nutzen. Die Solaranzeige kann nur einzelne, wenige MQTT Daten in die Datenbank schreiben. So wie hier beschrieben. Sie ist nicht dafür ausgelegt, alle Daten eines Gerätes zu übernehmen.
tirolerbua
Ulrich hat geschrieben:
Di 13. Feb 2024, 15:37
danke für deine rasche Antwort - ich hab das mit dem von dir verlinkten PDF schon versucht!
Was mir nicht ganz klar ist - muss ich für den "Stromzähler" welcher die mqtt Daten liefert eine eigene x.user.config.php anlegen? Denn da hab ich dann das Problem, welchen "Regler" nehme ich?
Alternativ hätte dieses Schnittstellenmodul auch die Möglichkeit Daten für "Volkszähler" auszugeben - sollte ich eher in die Richtung versuchen?
Leider sind meine Programmierkenntnisse da leider sehr bescheiden.
LG aus Tirol und DANKE!
Die Solaranzeige kann keine MQTT Daten von einem Zähler empfangen. Deshalb gibt es auch keine Reglernummer dafür. Die Daten musst du außerhalb der Solaranzeige in die Influx Datenbank speichern.
Hat sich bedankt: 23 Mal
Danksagung erhalten: 205 Mal
Du kannst Deinen Zähler nur mit der Solaranzeige über den Weg hier auslesen
viewforum.php?f=44
tirolerbua
Ich hab jetzt auf dem Raspi zusätzlich node-red installiert! .... und JUHU solaranzeige läuft noch ohne Fehler - diese Befürchtung hatte ich schon!
Nun habe ich es geschafft dass ich die Daten in die Influx in eine neue DB Smartmeter schreibe!
Die Daten werden auch in Grafana angezeigt .... nur werden die Daten immer "addiert" angezeigt ... ich schaffe es leider noch nicht den Wert z.B. für einen Tag (= Differenz von jetzt zurück auf Mitternacht) anzeigen zu lassen - ich bekomme nur immer den aktuellen Wert!
Zurück zu „MQTT und der Rest der Welt“
