Huawei Sun2000 mit SDongleA
woni
Beitrag von woni »
ich habe einen WR SUN2000-8KTL-M1 mit einem SDongleA-05.
Auf den Dongle kann ich zugreifen und Port 502 ist offen. Ich bekomme aber keine Daten.
Ich habe wie folgt konfiguriert:
$Regler = "62";
$WR_IP = "192.168.180.235"; // IP des SDongle
$WR_Port = "502";
$WR_Adresse = "01";
php.log
[02-Jun-2022 11:20:24 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 134
[02-Jun-2022 11:20:24 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 135
[02-Jun-2022 11:20:24 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 136
[02-Jun-2022 11:20:24 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 137
[02-Jun-2022 11:20:24 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 138
[02-Jun-2022 11:20:24 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 140
[02-Jun-2022 11:20:24 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 141
[02-Jun-2022 11:20:26 Europe/Berlin] PHP Notice:  fwrite(): send of 12 bytes failed with errno=32 Broken pipe in /var/www/html/phpinc/funktionen.inc.php on line 7344
[02-Jun-2022 11:20:29 Europe/Berlin] PHP Notice:  fwrite(): send of 12 bytes failed with errno=32 Broken pipe in /var/www/html/phpinc/funktionen.inc.php on line 7344
[02-Jun-2022 11:20:31 Europe/Berlin] PHP Notice:  fwrite(): send of 12 bytes failed with errno=32 Broken pipe in /var/www/html/phpinc/funktionen.inc.php on line 7344
[02-Jun-2022 11:20:33 Europe/Berlin] PHP Notice:  fwrite(): send of 12 bytes failed with errno=32 Broken pipe in /var/www/html/phpinc/funktionen.inc.php on line 7344
[02-Jun-2022 11:20:35 Europe/Berlin] PHP Notice:  fwrite(): send of 12 bytes failed with errno=32 Broken pipe in /var/www/html/phpinc/funktionen.inc.php on line 7344
[02-Jun-2022 11:20:37 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 151
[02-Jun-2022 11:20:37 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 152
[02-Jun-2022 11:20:37 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 153
[02-Jun-2022 11:20:37 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 154
[02-Jun-2022 11:20:37 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 172
[02-Jun-2022 11:20:37 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 173
[02-Jun-2022 11:20:37 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 174
[02-Jun-2022 11:20:37 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 175
[02-Jun-2022 11:20:37 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 176
[02-Jun-2022 11:20:37 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 177
[02-Jun-2022 11:20:37 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 178
[02-Jun-2022 11:20:37 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 179
[02-Jun-2022 11:20:37 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 180
[02-Jun-2022 11:20:37 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 181
[02-Jun-2022 11:20:37 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 182
[02-Jun-2022 11:20:37 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 183
[02-Jun-2022 11:20:39 Europe/Berlin] PHP Notice:  fwrite(): send of 12 bytes failed with errno=32 Broken pipe in /var/www/html/phpinc/funktionen.inc.php on line 7344
[02-Jun-2022 11:20:42 Europe/Berlin] PHP Notice:  fwrite(): send of 12 bytes failed with errno=32 Broken pipe in /var/www/html/phpinc/funktionen.inc.php on line 7344
[02-Jun-2022 11:20:44 Europe/Berlin] PHP Notice:  fwrite(): send of 12 bytes failed with errno=32 Broken pipe in /var/www/html/phpinc/funktionen.inc.php on line 7344
[02-Jun-2022 11:20:46 Europe/Berlin] PHP Notice:  fwrite(): send of 12 bytes failed with errno=32 Broken pipe in /var/www/html/phpinc/funktionen.inc.php on line 7344
[02-Jun-2022 11:20:48 Europe/Berlin] PHP Notice:  fwrite(): send of 12 bytes failed with errno=32 Broken pipe in /var/www/html/phpinc/funktionen.inc.php on line 7344
[02-Jun-2022 11:20:50 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 193
[02-Jun-2022 11:20:50 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 200
[02-Jun-2022 11:20:50 Europe/Berlin] PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/huawei_LAN.php on line 201
[02-Jun-2022 11:20:50 Europe/Berlin] PHP Warning:  Division by zero in /var/www/html/huawei_LAN.php on line 334
[02-Jun-2022 11:21:05 Europe/Berlin] PHP Notice:  fwrite(): send of 12 bytes failed with errno=32 Broken pipe in /var/www/html/phpinc/funktionen.inc.php on line 7344
solaranzeige.log
02.06. 10:54:37    -Regler: 62
02.06. 10:54:37    -Device: Ethernet wird in die user.config.php eingetragen.
02.06. 10:54:37    -Zeile gefunden. USB Device kann ausgetauscht werden. Index: 660   $USBRegler         = "/dev/ttyUSB0";
02.06. 10:54:37    -Zeile gefunden. Raspberry Modell kann eingetragen werden. Index: 679   $Platine = "Raspberry unbekannt";
02.06. 10:54:37    -Es handelt sich um ein 64 Bit System.
02.06. 10:55:18 |----------------   Start  huawei_LAN.php  -----------------------------
02.06. 10:55:30    -Fehler! Keine gültigen Daten empfangen.
02.06. 10:55:41 >  -Gerätetyp:   Modell ID: 0
02.06. 10:55:54 >  -Alarm 1 Bits: 0000000000000000
02.06. 10:56:07 *  -Daten zur lokalen InfluxDB [ solaranzeige ] gesendet.
02.06. 10:56:07    -OK. Datenübertragung erfolgreich.
02.06. 10:56:07 |----------------   Stop   huawei_LAN.php    ---------------------------
02.06. 10:57:01 |----------------   Start  huawei_LAN.php  -----------------------------
Ich komme einfach nicht mehr weiter. Bitte dringend um Hilfe.
Danke Wolfgang
Re: Huawei Sun2000 mit SDongleA
Der sDonlge muss mindestens SW-Version V100R001C00SPC124 installiert haben. Hat er das? Ist die Wechselrichtzer ID (Geräte ID) richtig angegeben? Das ist die Geräteadresse, wenn mehrere Geräte zusammengeschaltet sind.
woni
Beitrag von woni »
wo bringe ich denn diese Version her? Bei Huawei war ich erfolglos.
Danke Wolfgang
Snoopy
Danksagung erhalten: 5 Mal
Beitrag von Snoopy »
ich habe fast den gleichen WR. Wenn du die SUN2000 App auf machst und dich mit dem Installateur Login anmeldest kannst du die FW Nummer sehen.
Oder auf der Page von FusionSolar..Plant Name-->(Grafik) Inverter--->(Oben)Device Management--> Dongel Software Version
woni
Beitrag von woni »
das weis ich schon. Ich habe die ...119 am Ende. Nur wo bekomme ich die benötigte Version her.
Vielleicht kannst Du mir die als PN oder eMail an info@woni.de senden.
Das ist scheinbar mein einziger Knackpunkt.
Danke und Gruß
Wolfgang
woni
Beitrag von woni »
Danke Euch. Jetzt bekomme ich schon mal Daten.
Kämpfe noch mit Wetter und Prognose.
Kann man eigentlich Vorlagen/Templates wie z.B. Finca einspielen?
Danke und Gruß
Wolfgang
Für das Wetter gibt es hier ein fertiges Panel:
viewtopic.php?t=188
Ungefähr in der Mitte.
woni
Beitrag von woni »
ich bin wohl nervig.
Wenn ich über http://<IP>:8086 auf die InfluxDB zugreifen möchte erhalte ich nur "404 page not found".
Eigentlich sollte doch ein Login erscheinen, oder?
Danke und Gruß
Wolfgang
Es kommt darauf an, was du machen möchtest. Wenn du nur einmal auf die Daten sehen möchtest, dann muss du auf der Konsole folgendes eingeben:
influx
use solaranzeige
precision rfc3339
select * from AC order by time desc limit 10
quit
Die Daten per HTTP Aufruf zu sehen, ist sehr viel komplizierter.
Das alles steht aber auch hier im Forum.
woni
Beitrag von woni »
Ok, danke.
Ich hätte etwas wie z.B. phpMyAdmin erwartet.
