Grafana: einen Wert pro Tag als Tabelle darstellen?
Seb01
Hat sich bedankt: 6 Mal
Danksagung erhalten: 6 Mal
Beitrag von Seb01 »
ich möchte in Grafana einen Wert pro Tag (Measurement "Info", Wert "Firmware") von 00:00:xx in einer Tabelle darstellen lassen, die z.B. 356 Tage zurückreicht.
Mit PV-Werten habe ich es schon gemacht, jedoch mit dem größten Wert pro Tag und nicht mit dem Wert von 00:00:xx:
  "datasource": {
    "type": "datasource",
    "uid": "-- Mixed --"
  "fieldConfig": {
    "defaults": {
      "custom": {
        "align": "auto",
        "cellOptions": {
          "type": "auto"
        "inspect": false,
        "filterable": false,
        "minWidth": 15
      "mappings": [],
      "thresholds": {
        "mode": "absolute",
        "steps": [
            "color": "green",
            "value": null
      "color": {
        "mode": "fixed"
    "overrides": [
        "matcher": {
          "id": "byName",
          "options": "Time"
        "properties": [
            "id": "displayName",
            "value": "Time"
            "id": "unit",
            "value": "time: YYYY-MM-DD"
            "id": "custom.width",
            "value": 100
        "matcher": {
          "id": "byName",
          "options": "Leistung"
        "properties": [
            "id": "unit",
            "value": "watt"
            "id": "decimals",
            "value": 2
            "value": 100
        "matcher": {
          "id": "byName",
          "options": "Spannung"
        "properties": [
            "id": "unit",
            "value": "volt"
            "id": "decimals",
            "value": 2
            "value": 100
        "matcher": {
          "id": "byName",
          "options": "Strom"
        "properties": [
            "id": "unit",
            "value": "amp"
            "id": "decimals",
            "value": 2
            "value": 100
  "gridPos": {
    "h": 10,
    "w": 5,
    "x": 0,
    "y": 96
  "id": 128,
  "links": [],
  "options": {
    "showHeader": true,
    "cellHeight": "sm",
    "footer": {
      "show": true,
      "reducer": [
        "mean"
      "countRows": false,
      "fields": []
    "sortBy": [
        "desc": true,
        "displayName": "Time"
  "pluginVersion": "10.0.2",
  "targets": [
      "alias": "Leistung",
      "datasource": {
        "type": "influxdb",
        "uid": "ozSPx5Rgk"
      "groupBy": [
          "params": [
            "1d"
          "type": "time"
          "params": [
            "null"
          "type": "fill"
      "hide": false,
      "measurement": "PV",
      "orderByTime": "ASC",
      "policy": "default",
      "query": "SELECT (max(\"Leistung\")) FROM \"PV\" WHERE $timeFilter GROUP BY time(1d) fill(null) tz('Europe/Berlin')",
      "rawQuery": true,
      "refId": "K",
      "resultFormat": "time_series",
      "select": [
            "params": [
              "Leistung"
            "type": "field"
            "params": [],
            "type": "sum"
      "tags": []
      "alias": "Spannung",
      "datasource": {
        "type": "influxdb",
        "uid": "ozSPx5Rgk"
      "hide": false,
      "query": "SELECT (max(\"Spannung1\")) FROM \"PV\" WHERE $timeFilter GROUP BY time(1d) fill(null) tz('Europe/Berlin')",
      "rawQuery": true,
      "refId": "A",
      "alias": "Strom",
      "datasource": {
        "type": "influxdb",
        "uid": "ozSPx5Rgk"
      "hide": false,
      "query": "SELECT (max(\"Strom1\")) FROM \"PV\" WHERE $timeFilter GROUP BY time(1d) fill(null) tz('Europe/Berlin')",
      "rawQuery": true,
      "refId": "B",
  "timeFrom": "365d",
  "title": "PV Tag /  Maximale Peaks",
  "transformations": [
      "id": "seriesToColumns",
      "options": {
        "reducers": []
      "id": "organize",
      "options": {
        "excludeByName": {
          "Time": false
        "indexByName": {
          "Autark": 9,
          "Bezug": 4,
          "Eigenverbr.": 3,
          "Einspeisung": 5,
          "Erspart": 8,
          "Gesamtverbr.": 6,
          "Tagesprod.": 1,
          "Time": 0,
          "Verbrauch": 2,
          "Vergütung": 7
        "renameByName": {
          "Verbrauch": ""
  "type": "table",
  "description": ""
Jetzt wollte ich aus dem Measurement "Info" die "Firmware" ein mal am Tag in die Tabelle schreiben lassen. Geht das überhaupt?
Gruss Sebastian
