USB RS485 To Epever Tracer 30 To Raspberry Pi 3b+
Loganxwolverine
Beitrag von Loganxwolverine »
Hello there,
I am pretty new, and very happy of your work.
I am using an Epever Tracer 30.
and A Raspberry Pi 3b+
Since several days, I try to translate all the golden information I found here.
I still need an answer to make it work.
Witch RS485 to USB do I need to be sure ?
All the prices are different, and all of them has different specifications... So ...in order to be sure to spend money wisely, if you have an advise ?
Many thanks for your help...
tuxflo
Hat sich bedankt: 15 Mal
Danksagung erhalten: 22 Mal
Re: USB RS485 To Epever Tracer 30 To Raspberry Pi 3b+
Beitrag von tuxflo »
I think they should all work fine. I'm using the second one, because it was the only one available at the time I wanted to get startet and didn't have any issues so far.
Kostal Pico Wechselrichter
SMA Tripower Wechselrichter
go-E Wallbox
Here are some listed.
viewtopic.php?f=21&t=344&sid=8289798b14 ... 8807bab330
All must have a FTDI chip. And very importand: You do not change the A + B line. A must be connected to A and B to B. If you change this, it does'nt work!
Loganxwolverine
Thank You for your answerrs.
Indeed, I have seen the topic about the adaptaters ... But, unfortunately, Amazon.fr doesn't have these model...
I was just searching for the most similar in Belgium, France, or Wathever...
Many thanks
Loganxwolverine
Dear All ,
A Great Thanks to all !!
I finally decide to buy this one :
Already Plugged, and tested ... Works like a charm ...
As you can see, I have translated some title in Grafana in French ... Easier for me I have to admit.
Next Step, adding some me Panel suche as Weather, etc...
Thanks again
