IR Lesekopf Wifi BitShake
Duck
Re: IR Lesekopf Wifi BitShake
Beitrag von Duck »
TeamO hat geschrieben: ↑
Mo 20. Feb 2023, 13:02
Welchen Fehler im solaranzeige.log meinst Du? Davon hast du bisher nichts geschrieben.
Doch hatte ich im ersten Post als Bild angehangen:
20.02. 14:45:11 |----------------   Start  sonoff_mqtt.php    ---------------------
20.02. 14:45:11    -Zentraler Timestamp: 1676900701
20.02. 14:45:11 +  -Die Daten werden ausgelesen...
20.02. 14:45:11    -Das Sonoff Relais ist nicht aktiv oder es ist kein unterstütztes Sonoff Gerät. Tasmota Modul: 18  Firmware: 12.1.1(tasmota)
20.02. 14:45:11 !! -Keine gültigen Daten empfangen.
20.02. 14:45:11 |----------------   Stop   sonoff_mqtt.php     --------------------
Leider ist der Fehler immernoch da wie man sied :(
16:02:09.609 MQT: stat/sonoff/STATUS = {"Status":{"Module":18,"DeviceName":"Tasmota","FriendlyName":["Tasmota"],"Topic":"sonoff","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0}}
16:02:09.614 MQT: stat/sonoff/STATUS1 = {"StatusPRM":{"Baudrate":9600,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"-","RestartReason":"Software/System restart","Uptime":"0T05:07:41","StartupUTC":"2023-02-20T09:54:28","Sleep":50,"CfgHolder":4617,"BootCount":17,"BCResetTime":"2023-02-01T18:36:32","SaveCount":66,"SaveAddress":"FA000"}}
16:02:09.618 MQT: stat/sonoff/STATUS2 = {"StatusFWR":{"Version":"12.1.1(tasmota)","BuildDateTime":"2023-01-06T10:00:57","Boot":31,"Core":"2_7_4_9","SDK":"2.2.2-dev(38a443e)","CpuFrequency":80,"Hardware":"ESP8266EX","CR":"330/699"}}
16:02:09.622 MQT: stat/sonoff/STATUS3 = {"StatusLOG":{"SerialLog":0,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["Langweilt mich!",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000000"]}}
16:02:09.633 MQT: stat/sonoff/STATUS4 = {"StatusMEM":{"ProgramSize":658,"Free":344,"Heap":16,"ProgramFlashSize":1024,"FlashSize":4096,"FlashChipId":"16405E","FlashFrequency":40,"FlashMode":3,"Features":["00000809","879AC787","043E8001","000000CF","010013C0","C000F989","00004004","00001000","54000020","00000000"],"Drivers":"1,2,3,4,5,6,7,8,9,10,12,16,18,19,20,21,22,24,26,27,29,30,35,37,45,62","Sensors":"1,2,3,4,5,6,53"}}
16:02:09.641 MQT: stat/sonoff/STATUS5 = {"StatusNET":{"Hostname":"sonoff-0603","IPAddress":"192.168.178.57","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.1","DNSServer2":"0.0.0.0","Mac":"50:02:91:D2:82:5B","Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":17.0}}
16:02:09.646 MQT: stat/sonoff/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.178.47","MqttPort":1883,"MqttClientMask":"DVES_%06X","MqttClient":"DVES_D2825B","MqttUser":"DVES_USER","MqttCount":4,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4}}
16:02:09.651 MQT: stat/sonoff/STATUS7 = {"StatusTIM":{"UTC":"2023-02-20T15:02:09","Local":"2023-02-20T16:02:09","StartDST":"2023-03-26T02:00:00","EndDST":"2023-10-29T03:00:00","Timezone":"+01:00","Sunrise":"07:49","Sunset":"18:17"}}
16:02:09.659 MQT: stat/sonoff/STATUS10 = {"StatusSNS":{"Time":"2023-02-20T16:02:09","EHZ541":{"total_in":3483.3461,"total_out":245.1893,"Power":111,"Volt_L1":0.0,"Volt_L2":0.0,"Volt_L3":0.0,"Ampere_L1":0.0,"Ampere_L2":0.0,"Ampere_L3":0.0,"Phasenwinkel_L1":0.0,"Phasenwinkel_L2":0.0,"Phasenwinkel_L3":0.0,"Frequenz":0}}}
16:02:09.664 MQT: stat/sonoff/STATUS11 = {"StatusSTS":{"Time":"2023-02-20T16:02:09","Uptime":"0T05:07:41","UptimeSec":18461,"Heap":16,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":20,"MqttCount":4,"Wifi":{"AP":1,"SSId":"Langweilt mich!","BSSId":"48:5D:35:83:E4:89","Channel":11,"Mode":"11n","RSSI":86,"Signal":-57,"LinkCount":1,"Downtime":"0T00:00:03"}}}
16:02:11.021 MQT: stat/sonoff/STATUS = {"Status":{"Module":18,"DeviceName":"Tasmota","FriendlyName":["Tasmota"],"Topic":"sonoff","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0}}
16:02:11.028 MQT: stat/sonoff/STATUS1 = {"StatusPRM":{"Baudrate":9600,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"-","RestartReason":"Software/System restart","Uptime":"0T05:07:43","StartupUTC":"2023-02-20T09:54:28","Sleep":50,"CfgHolder":4617,"BootCount":17,"BCResetTime":"2023-02-01T18:36:32","SaveCount":66,"SaveAddress":"FA000"}}
16:02:11.034 MQT: stat/sonoff/STATUS2 = {"StatusFWR":{"Version":"12.1.1(tasmota)","BuildDateTime":"2023-01-06T10:00:57","Boot":31,"Core":"2_7_4_9","SDK":"2.2.2-dev(38a443e)","CpuFrequency":80,"Hardware":"ESP8266EX","CR":"330/699"}}
16:02:11.040 MQT: stat/sonoff/STATUS3 = {"StatusLOG":{"SerialLog":0,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["Langweilt mich!",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000000"]}}
16:02:11.053 MQT: stat/sonoff/STATUS4 = {"StatusMEM":{"ProgramSize":658,"Free":344,"Heap":18,"ProgramFlashSize":1024,"FlashSize":4096,"FlashChipId":"16405E","FlashFrequency":40,"FlashMode":3,"Features":["00000809","879AC787","043E8001","000000CF","010013C0","C000F989","00004004","00001000","54000020","00000000"],"Drivers":"1,2,3,4,5,6,7,8,9,10,12,16,18,19,20,21,22,24,26,27,29,30,35,37,45,62","Sensors":"1,2,3,4,5,6,53"}}
16:02:11.060 MQT: stat/sonoff/STATUS5 = {"StatusNET":{"Hostname":"sonoff-0603","IPAddress":"192.168.178.57","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.1","DNSServer2":"0.0.0.0","Mac":"50:02:91:D2:82:5B","Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":17.0}}
16:02:11.066 MQT: stat/sonoff/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.178.47","MqttPort":1883,"MqttClientMask":"DVES_%06X","MqttClient":"DVES_D2825B","MqttUser":"DVES_USER","MqttCount":4,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4}}
16:02:11.073 MQT: stat/sonoff/STATUS7 = {"StatusTIM":{"UTC":"2023-02-20T15:02:11","Local":"2023-02-20T16:02:11","StartDST":"2023-03-26T02:00:00","EndDST":"2023-10-29T03:00:00","Timezone":"+01:00","Sunrise":"07:49","Sunset":"18:17"}}
16:02:11.084 MQT: stat/sonoff/STATUS10 = {"StatusSNS":{"Time":"2023-02-20T16:02:11","EHZ541":{"total_in":3483.3461,"total_out":245.1893,"Power":83,"Volt_L1":0.0,"Volt_L2":0.0,"Volt_L3":0.0,"Ampere_L1":0.0,"Ampere_L2":0.0,"Ampere_L3":0.0,"Phasenwinkel_L1":0.0,"Phasenwinkel_L2":0.0,"Phasenwinkel_L3":0.0,"Frequenz":0}}}
16:02:11.092 MQT: stat/sonoff/STATUS11 = {"StatusSTS":{"Time":"2023-02-20T16:02:11","Uptime":"0T05:07:43","UptimeSec":18463,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":20,"MqttCount":4,"Wifi":{"AP":1,"SSId":"Langweilt mich!","BSSId":"48:5D:35:83:E4:89","Channel":11,"Mode":"11n","RSSI":84,"Signal":-58,"LinkCount":1,"Downtime":"0T00:00:03"}}}
Hat sich bedankt: 23 Mal
Danksagung erhalten: 204 Mal
Was hast Du in Tasmota als topic eingetragen?
Mach da mal zB "hichi" und in der config ebenfalls.
Duck
Beitrag von Duck »
Habe ich abgeändert.
Meldung bleibt bestehen troz neustart.
Hättest du mal Zeit, das ich mir das über Teamviewer anschaue?
Duck
Beitrag von Duck »
Mo 20. Feb 2023, 19:11
Sehr gerne :)
WhySoSyrius
Beitrag von WhySoSyrius »
Was war denn hier die Lösung am Ende?
Siehe Deinen anderen Post.
Du musst unter Configuration - Configure Module - Sonoff Basic (1) auswählen.
Michael01
Beitrag von Michael01 »
erstmal vielen Dank an TeamO für die Anleitungen und den unermüdlichen Einsatz,
Nachdem ich aber mit dem bitShake Wifi Lesekopf fast schon aufgeben habe war das hier die Lösung.
Allerdings gab es die Option "Sonoff Basic (1)" bei mir nicht, aber mit "ESP32C3 (1)" hat es bei mir geklappt (DE Oberfläche >Einstellugen>Gerät konfigurieren)
Also für andere User mit bitShake diese Hauptanleitung (Konfiguration zum Auslesen von Zählern des MSB - Regler 23):
viewtopic.php?t=3230
Auf Lesekopf dann passendes Skript für Zähler
viewforum.php?f=44
In entsprechender Zeile 3 auf 5 ändern
Beispiel EBZ Leser
Statt +1,3,s,0,9600,DD32R06,1
das hier +1,5,s,0,9600,DD32R06,1
Und dann noch ">Einstellugen>Gerät konfigurieren" auf "ESP32C3 (1)"
Michael
