Zähler efr SGM-C8
canner
Hat sich bedankt: 3 Mal
Zähler efr SGM-C8
Beitrag von canner »
Hi zusammen,
kann ich denn den Zähler efr SGM-C8 ohne weiteres einbinden?
Von github habe ich bereits folgenden Code geladen und in Tasmota eingebunden.
>D
>B
->sensor53 r
>M 1
+1,5,s,16,9600,ENERGY
1,77070100010800ff@1000,Comsumption,kWh,Total,4
;for meters measuring feed-in SGM-Cx-xxx2xx
;1,77070100020800ff@1000,Supply,kWh,Supply,4
;next 4 lines for double-tariff meters SGM-Cx-xxxxTx
;1,77070100010801ff@1000,Comsumption_t1,kWh,Total_t1,4
;1,77070100010802ff@1000,Comsumption_t2,kWh,Total_t2,4
;1,77070100020801ff@1000,Supply_t1,kWh,Supply_t1,4
;1,77070100020802ff@1000,Supply_t2,kWh,Supply_t2,4
;all commented lines from here on for 3-phase meter SGM-C4
1,77070100100700ff@1,Actual Power,W,Power,0
1,77070100200700ff@1,Voltage L1,V,Voltage,1
;1,77070100340700ff@1,Voltage L2,V,Voltage_L2,1
;1,77070100480700ff@1,Voltage L3,V,Voltage_L3,1
1,770701001f0700ff@1,Current L1,A,Current,2
;1,77070100330700ff@1,Current L2,A,Current_L2,2
;1,77070100470700ff@1,Current L3,A,Current_L3,2
;1,77070100510701ff@1,Phaseangle L2-L1,deg,phase_angle_L2_L1,0
;1,77070100510702ff@1,Phaseangle L3-L1,deg,phase_angle_L3_L1,0
1,77070100510704ff@1,Phaseangle I/U L1,deg,phase_angle_L1,1
;1,7707010051070fff@1,Phaseangle I/U L2,deg,phase_angle_L2,1
;1,7707010051071aff@1,Phaseangle I/U L3,deg,phase_angle_L3,1
1,770701000e0700ff@1,Frequency,Hz,Freq,1
;all commented lines from here on just for completeness
;1,7707010000020000@1,Firmware Version,,FwVer,0
;1,77070100605a0201@1,Firmware Checksum,,FwCheck,0
;1,7707010061610000@1,Error Register,,ErrorReg,0
;1,7707010060320101@1,Hardware Version,,HwVer,0
;1,7707010060320104@1,Parameter Version,,ParamVer,0
1,77070100600100ff@#,Server-ID,,ID,0
;You can find your server-id printed on your meter. If you want you can also convert it to your Identifikationsnummer with some ASCII, DEC and HEX encoding. 0A-01-45-46-52-ST-UV-WX-YZ = 1EFR + string(S) + string(T) + hexToDec(UVWXYZ)
VG
Christian
Danksagung erhalten: 205 Mal
Re: Zähler efr SGM-C8
Du könntest es als eigenes Gerät anhand der Anleitung einbinden oder mir etwas Zeit geben, dann binde ich den Zähler ein und Ulrich übernimmt alles ins offizielle Update.
Eventuell komme ich morgen schon dazu dir die ersten Dateien zum Testen zu geben.
canner
Hallo Timo,
danke für die schnelle Antwort.
Ich glaube ich brauche hierfür deine Hilfe.
Christian
Versuche es mal bitte mit folgendem Tasmota-Script und den angehängten Dateien
>D
>B
->sensor53 r
>M 1
+1,3,s,16,9600,SGMC248
1,77070100010800ff@1000,Bezug,kWh,total_in,4
1,77070100020800ff@1000,Einspeisung,kWh,total_out,4
1,77070100010801ff@1000,Verbrauch T1_t1,kWh,Verbrauch_T1,4
1,77070100010802ff@1000,Verbrauch T2,kWh,Verbrauch_T2,4
1,77070100100700ff@1,Leistung,W,Power,0
1,77070100200700ff@1,Spannung L1,V,Volt_L1,1
1,77070100340700ff@1,Spannung L2,V,Volt_L2,1
1,77070100480700ff@1,Spannung L3,V,Volt_L3,1
1,770701001f0700ff@1,Ampere L1,A,Ampere_L1,2
1,77070100330700ff@1,Ampere L2,A,Ampere_L2,2
1,77070100470700ff@1,Ampere L3,A,Ampere_L3,2
1,77070100510704ff@1,Phasenwinkel L1,deg,Phasenwinkel_L1,1
1,7707010051070fff@1,Phasenwinkel L2,deg,Phasenwinkel_L2,1
1,7707010051071aff@1,Phasenwinkel L3,deg,Phasenwinkel_L3,1
1,770701000e0700ff@1,Frequenz,Hz,Frequenz,1
1,77070100600100ff@#,Server-ID,,Server-ID,0
sonoff_mqtt.php
(33.6 KiB) 230-mal heruntergeladen
funktionen.inc.php
(373.28 KiB) 227-mal heruntergeladen
canner
Hi Timo,
vielen Dank. Irgendwie bin ich zu dämlich.
Ich habe Tasmota angepasst (das hat geklappt) und deine Files auf das System kopiert.
Ausserdem habe ich eine 1.user.config.php angelegt, sowie eine neue Datenbank mit dem Name "zaehler". Oder ist das überflüssig?
mosquitto_sub  -h localhost  -v -t zaehler/#
bringt folgenden output:
zaehler/LWT Online
zaehler/STATE {"Time":"2023-03-11T13:58:18","Uptime":"0T00:20:11","UptimeSec":1211,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":22,"MqttCount":1,"Wifi":{"AP":1,"SSId":"WLAN-X","BSSId":"2C:3A:FD:83:B0:B3","Channel":1,"Mode":"11n","RSSI":54,"Signal":-73,"LinkCount":1,"Downtime":"0T00:00:05"}}
zaehler/SENSOR {"Time":"2023-03-11T13:58:18","SGMC248":{"total_in":248.4589,"total_out":255.7655,"Power":-956,"Volt_L1":227.7,"Volt_L2":230.9,"Volt_L3":229.8,"Ampere_L1":1.17,"Ampere_L2":1.40,"Ampere_L3":1.70,"Phasenwinkel_L1":172.0,"Phasenwinkel_L2":191.0,"Phasenwinkel_L3":182.0,"Frequenz":49.9,"Server-ID":"X"}}
Meine DB "zaehler" bleibt aber ohne Eintrag.
Du musst natürlich komplett auf die Multi-Regler-Version umstellen.
Sprich Deine "alte" user.config.php (vom Wechselrichter oder so) nach 1.user.config.php kopieren und eine 2.user.config.php mit Regler 23 etc, wie hier beschrieben, anlegen.
Dann natürlich auch noch die crontab entsprechend anpassen.
Danach sollte alles passen
canner
danke für deine Geduld. Ich bastle schon seit gestern wieder an meinem Projekt.
Bekomme jedoch keine Daten vom Tasmota ins System.
14.03. 14:58:11    -Verarbeitung von: '2.user.config.php'   Regler: 23
14.03. 14:58:11 |----------------   Start  sonoff_mqtt.php    ---------------------
14.03. 14:58:11    -Zentraler Timestamp: 1678802280
14.03. 14:58:11 +  -Die Daten werden ausgelesen...
14.03. 14:58:11 MQT-MQTT Daten zum Broker gesendet bzw. vom Broker empfangen. Adresse: localhost Port: 1883
14.03. 14:58:17    -Keine Daten vom Sonoff Modul empfangen.
14.03. 14:58:17 !! -Keine gültigen Daten empfangen.
14.03. 14:58:17 |----------------   Stop   sonoff_mqtt.php     --------------------
14.03. 14:58:17    -Multi Regler Auslesen [Stop].
Vielleicht sollte ich es einfach lassen :roll:
VG Christian
Sollen wir uns das mal über TeamViewer zusammen anschauen?
Denke es ist hier ein Konfigurations-Problem bei Dir.
canner
Das wäre natürlich Mega!
Meld Dich mal per PN bei mir, wann Du Zeit hättest.
