bitShake SmartMeterReader mit Tasmota [Regler 23]
westcliff
Beitrag von westcliff »
Hallo Zusammen,
Ich habe Solaranzeige als Multiregler Version auf einem PI Laufen
Regler 1 > Ahoy DTU
Regler 2 > Shelly 3EM
Regler 3 > soll der bitShake SmartMeterReader mit Tasmota werden.
Den bitShake SmartMeterReader mit Tasmota bekomme ich allerdings nicht in die Solaranzeige eingebunden habe jetzt schon mehere Tage getüftelt und komme nicht weiter evtl. hat von euch einer den Richtigen Tip. Die daten werden per mqtt an den Broker gesendet aber irgendwie möchte Solaranzeige mein Tasmota Device nicht erkennen.
MQTT log von Tasmota
21:30:19.192 MQT: Verbindungsversuch…
21:30:19.298 MQT: verbunden
21:30:19.301 MQT: tele/hichi/LWT = Online (beibehalten)
21:30:19.304 MQT: cmnd/hichi/POWER =
21:30:20.925 MQT: tele/hichi/STATE = {"Time":"2024-03-31T21:30:20","Uptime":"0T00:03:49","UptimeSec":229,"Heap":173,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":2,"Berry":{"HeapUsed":4,"Objects":38},"Wifi":{"AP":1,"SSId":"Familie35","BSSId":"04:B4:FE:B6:24:16","Channel":1,"Mode":"11n","RSSI":40,"Signal":-80,"LinkCount":1,"Downtime":"0T00:00:04"}}
21:30:20.932 MQT: tele/hichi/SENSOR = {"Time":"2024-03-31T21:30:20","mMe4":{"E_in":7034.448,"E_out":103.438,"Power":295}}
21:30:30.902 MQT: tele/hichi/STATE = {"Time":"2024-03-31T21:30:30","Uptime":"0T00:03:59","UptimeSec":239,"Heap":172,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":20,"MqttCount":2,"Berry":{"HeapUsed":4,"Objects":38},"Wifi":{"AP":1,"SSId":"Familie35","BSSId":"04:B4:FE:B6:24:16","Channel":1,"Mode":"11n","RSSI":40,"Signal":-80,"LinkCount":1,"Downtime":"0T00:00:04"}}
21:30:30.909 MQT: tele/hichi/SENSOR = {"Time":"2024-03-31T21:30:30","mMe4":{"E_in":7034.449,"E_out":103.438,"Power":296}}
21:30:32.106 MQT: stat/hichi/STATUS = {"Status":{"Module":0,"DeviceName":"bitShake","FriendlyName":["bitShake"],"Topic":"hichi","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0}}
21:30:32.111 MQT: stat/hichi/STATUS1 = {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"KEIN Update machen! sonst ist SML deaktiviert","RestartReason":"Software reset digital core","Uptime":"0T00:04:01","StartupUTC":"2024-03-31T19:26:31","Sleep":50,"CfgHolder":4617,"BootCount":21,"BCResetTime":"2024-03-31T15:06:00","SaveCount":39}}
21:30:32.115 MQT: stat/hichi/STATUS2 = {"StatusFWR":{"Version":"13.3.0(tasmota32)","BuildDateTime":"2024.01.18 10:41:04","Core":"2_0_14","SDK":"4.4.6.231122","CpuFrequency":160,"Hardware":"ESP32-C3 v0.4","CR":"399/699"}}
21:30:32.118 MQT: stat/hichi/STATUS3 = {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["Familie35",""],"TelePeriod":10,"Resolution":"558180C0","SetOption":["00008009","0A05C80001000600003C5A0A192800000000","000000A0","00006000","00004000","00000000"]}}
21:30:32.131 MQT: stat/hichi/STATUS4 = {"StatusMEM":{"ProgramSize":1812,"Free":1067,"Heap":167,"StackLowMark":4,"PsrMax":0,"PsrFree":0,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"164020","FlashFrequency":80,"FlashMode":"DIO","Features":["0407","90DA15DE","0009A001","B7F7BFCD","05DA9B04","20360C4F","080800D2","20200000","84BC4809","810A80B1","00000000"],"Drivers":"1,2,3,4,5,7,8,10,11,12,14,16,17,24,29,34,38,50,52,59,60,62,63,66,67,68,86,87,88","Sensors":"1,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,53,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82"}}
21:30:32.137 MQT: stat/hichi/STATUS5 = {"StatusNET":{"Hostname":"hichi-5200","IPAddress":"192.168.178.146","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.1","DNSServer2":"2003:e8:cf06:6600:6b4:feff:feb6:2413","Mac":"64:E8:33:89:14:50","IP6Global":"2003:e8:cf06:6600:66e8:33ff:fe89:1450","IP6Local":"fe80::66e8:33ff:fe89:1450%st1","Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":19.0}}
21:30:32.144 MQT: stat/hichi/STATUS6 = {"StatusMQT":{"MqttHost":"xxxx.myfritz.net","MqttPort":1883,"MqttClientMask":"DVES_%06X","MqttClient":"DVES_891450","MqttUser":"DVES_USER","MqttCount":2,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4}}
21:30:32.148 MQT: stat/hichi/STATUS7 = {"StatusTIM":{"UTC":"2024-03-31T19:30:32","Local":"2024-03-31T21:30:32","StartDST":"2024-03-31T02:00:00","EndDST":"2024-10-27T03:00:00","Timezone":99}}
21:30:32.155 MQT: stat/hichi/STATUS10 = {"StatusSNS":{"Time":"2024-03-31T21:30:32","mMe4":{"E_in":3630862279857.745,"E_out":103.438,"Power":294}}}
21:30:32.162 MQT: stat/hichi/STATUS11 = {"StatusSTS":{"Time":"2024-03-31T21:30:32","Uptime":"0T00:04:01","UptimeSec":241,"Heap":166,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":2,"Berry":{"HeapUsed":4,"Objects":38},"Wifi":{"AP":1,"SSId":"Familie35","BSSId":"04:B4:FE:B6:24:16","Channel":1,"Mode":"11n","RSSI":40,"Signal":-80,"LinkCount":1,"Downtime":"0T00:00:04"}}}
21:30:40.927 MQT: tele/hichi/STATE = {"Time":"2024-03-31T21:30:40","Uptime":"0T00:04:09","UptimeSec":249,"Heap":171,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":2,"Berry":{"HeapUsed":4,"Objects":38},"Wifi":{"AP":1,"SSId":"Familie35","BSSId":"04:B4:FE:B6:24:16","Channel":1,"Mode":"11n","RSSI":40,"Signal":-80,"LinkCount":1,"Downtime":"0T00:00:04"}}
21:30:40.934 MQT: tele/hichi/SENSOR = {"Time":"2024-03-31T21:30:40","mMe4":{"E_in":7034.450,"E_out":103.438,"Power":295}}
Das Zähler Script
>D
>B
->sensor53 r
>M 1
+1,5,s,0,9600,mMe4
1,77070100010800FF@1000,E_in,kWh,E_in,3
1,77070100020800FF@1000,E_out,kWh,E_out,3
1,77070100100700FF@1,Power,W,Power,0
Tasmota Oberfläche
3.user.config.php
$Regler = "23";
//  Raspberry Gerätenummer   Raspberry Gerätenummer   Raspberry Gerätenummer
//  Falls mehr als ein Gerät pro Raspberry betrieben wird.
//  Es ist die Reihenfolge der Geräte und taucht auch in der Nummerierung
//  der  x.user.config.php Dateien auf
//  GeräteID bzw. GeräteNummer Muss gleich mit der x.user.config.php sein.
//  Bitte nur bei einer Multi-Regler-Version ändern.  [ 1 bis 6 ]
$GeraeteNummer = "3";
//  Bei einem Micro Wechselrichter von AEconversion oder LiCom Box von Effekta
//  und anderen Geräten, die für den Zugang eine Seriennummer benötigen.
//  Z.B. Typ INV250-45 oder INV500-60 oder LiCom Box von Effekta
//  Steht auf dem Gerät! Ist 10 stellig. Serial-No. 0607600...
//  Bitte alle 10 Stellen hier eintragen.
//  Bei der AX LiCom Box von Effekta sind es 14 Stellen.
//  Bei den neuen AEconversion Geräten den Bootcode hier eintragen.
$Seriennummer = "0000000000";                 // Regler = "5"
//  Wird nur in seltenen Fällen gebraucht.
//  Falls ein WLAN HF2211 serial   Gateway benutzt wird true eingeben
$HF2211 = false;
//  Nur bei PylonTech BMS US3000..       ($Regler = "41" )
//  und den neuen US2000C aus dem Jahr 2019 und später
//  Anzahl der vorhandenen Batteriepacks und Modell 2000 / 3000
$Batteriepacks = "1"; //                                Regler = "41"
$PylonTech = "2000";  //                                Regler = "41"
$WR_IP = "localhost";  //  Keine führenden Nullen!  67.xx Ja!, 067.xx Nein!
$WR_Port = "1883";
$WR_Adresse = "1";   //  Achtung Adresse als Dezimalzahl eingeben / 1 bis 256
//                       Maximal "256" = Hex FF
//  Bezeichnung des Objektes. Freie Wahl, maximal 15 Buchstaben.
$Objekt = "bitShake";
//  SONOFF Geräte mit Tasmota Firmware       SONOFF Geräte mit Tasmota Firmware
//  POW R2 / TH10 R2 oder TH16 R2  oder GOSUND SP1xx
//  Bitte den Topic-Namen, der in der TASMOTA Firmware angegeben ist, hier
//  eintragen. Unbedingt auf Groß- und Keinschreibung achten! Der Name kann
//  frei gewählt werden, er muss nur im Gerät und hier gleich sein. Werden
//  mehrere Sonoff Geräte mit der Solaranzeige betrieben, muss jedes einzelne
//  Gerät einen anderen Topic-Namen benutzen!
$Topic = "hichi";
Vielen Dank und Frohe Ostern
Matthias
Hat sich bedankt: 23 Mal
Danksagung erhalten: 205 Mal
Re: bitShake SmartMeterReader mit Tasmota [Regler 23]
Bei Dir ist es dasselbe Problem wie hier viewtopic.php?t=4771
Die Solaranzeige ist auf die Leseköpfe von Hichi ausgelegt. Bei der Verwendung von anderen Leseköpfen muss meistens die Programmierung angepasst werden.
westcliff
Danke für die Schnelle Antwort,
Wenn das alles zu viel Bastellei wird werde ich einen neuen Hichi IR Lesekopf Bestellen.
Tasmota habe ich umgestellt bekommen das er als Basic erkannt wird
status 0 gibt bei mir folgendes aus
12:11:47.095 CMD: status 0
12:11:47.100 MQT: stat/hichi/STATUS = {"Status":{"Module":1,"DeviceName":"bitShake","FriendlyName":["bitShake"],"Topic":"hichi","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0}}
12:11:47.105 MQT: stat/hichi/STATUS1 = {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"KEIN Update machen! sonst ist SML deaktiviert","RestartReason":"Software reset digital core","Uptime":"0T00:42:50","StartupUTC":"2024-04-01T09:28:57","Sleep":50,"CfgHolder":4617,"BootCount":24,"BCResetTime":"2024-03-31T15:06:00","SaveCount":45}}
12:11:47.110 MQT: stat/hichi/STATUS2 = {"StatusFWR":{"Version":"13.3.0(tasmota32)","BuildDateTime":"2024.01.18 10:41:04","Core":"2_0_14","SDK":"4.4.6.231122","CpuFrequency":160,"Hardware":"ESP32-C3 v0.4","CR":"399/699"}}
12:11:47.113 MQT: stat/hichi/STATUS3 = {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["Familie35",""],"TelePeriod":10,"Resolution":"558180C0","SetOption":["00008009","0A05C80001000600003C5A0A192800000000","000000A0","00006000","00004000","00000000"]}}
12:11:47.125 MQT: stat/hichi/STATUS4 = {"StatusMEM":{"ProgramSize":1812,"Free":1067,"Heap":164,"StackLowMark":4,"PsrMax":0,"PsrFree":0,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"164020","FlashFrequency":80,"FlashMode":"DIO","Features":["0407","90DA15DE","0009A001","B7F7BFCD","05DA9B04","20360C4F","080800D2","20200000","84BC4809","810A80B1","00000000"],"Drivers":"1,2,3,4,5,7,8,10,11,12,14,16,17,24,29,34,38,50,52,59,60,62,63,66,67,68,86,87,88","Sensors":"1,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,53,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82"}}
12:11:47.131 MQT: stat/hichi/STATUS5 = {"StatusNET":{"Hostname":"hichi-5200","IPAddress":"192.168.178.146","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.1","DNSServer2":"2003:e8:cf06:6600:6b4:feff:feb6:2413","Mac":"64:E8:33:89:14:50","IP6Global":"2003:e8:cf06:6600:66e8:33ff:fe89:1450","IP6Local":"fe80::66e8:33ff:fe89:1450%st1","Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":19.0}}
12:11:47.135 MQT: stat/hichi/STATUS6 = {"StatusMQT":{"MqttHost":"xxxxxxxxxx.myfritz.net","MqttPort":1883,"MqttClientMask":"DVES_%06X","MqttClient":"DVES_891450","MqttUser":"DVES_USER","MqttCount":3,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4}}
12:11:47.139 MQT: stat/hichi/STATUS7 = {"StatusTIM":{"UTC":"2024-04-01T10:11:47","Local":"2024-04-01T12:11:47","StartDST":"2024-03-31T02:00:00","EndDST":"2024-10-27T03:00:00","Timezone":99}}
Danke Matthias
Dann scheint es bei Dir ja jetzt zu gehen.
Die Daten werden in die Datenbank solaranzeige3 gespeichert.
Bei Deiner Abfrage mit status 0 fehlt noch der Rest ;)
westcliff
Danke TeamO,
die Lösung war unter Tasmota den bitShake in den Einstellungen auf den ESP32C3 Einzustellen.
Matthias
Schwarzermann
Hat sich bedankt: 11 Mal
Danksagung erhalten: 19 Mal
Beitrag von Schwarzermann »
Wie hast du es umgestellt bekommen das er den Tasmota erkennt?? leider entzieht es sich hier meiner Kentnisse wo man da sgenau macht etwas Hilfe wäre schön Danke
So es hat soweit geklappt das er Ihn erkennt nur liest er wohl keine Werte Aus hm , Ich kontrolliere das al noch ob was ankommt
viewtopic.php?p=32232#p32232
Schwarzermann
So also ich hab Ihn soweit da er zumindest mir mal Info,Service,Statistik ausliest aber keinerlei werte Verbrauchswerte,
was mach ich nun Falsch? Falsches Zählerskript? im Bitshake Tasmota zeig er mir Verbrauch Einspeisung und aktuelle Leistug an,
als Zähler habe ich einen EMH00 eHZ IW8E.
Ist dieser schon eingebunden? oder welces Skript müsste ich da nehmen.
Dsnn hätte ich noch eine Frage D ich mit dem lesekopf ein meanwell ladegerät steuere mit eiem Trucki2Meanwell Gateway das vermutlich auch mit Tasmota läuft könnte man das auch Auslesen , denke ja nur wie stell ich das an oder hat jemand ambitionen mir da behilfich zusein?
Schwarzermann
Nochmals nach geschaut er liest keinerlei Leistungsdaten aus, er liest den Tag den Status ect aus also komuniziert er schon mal ich bräuchte also Hilfe Danke
Was für ein Script nutzt Du überhaupt?
Solange der Zähler nicht direkt hier angegeben ist, muss ich prüfen, welches Script Du alternativ nutzen kannst.
Es funktioniert hier nicht immer alles Plug'n'Play. Vorallen nicht bei Geräten die bisher keiner Verwendet.
Du kannst es mal mit diesen hier versuchen oder mit einem von diesen
>D
>B
=>sensor53 r
>M 1
+1,3,o,0,9600,LK13BE
1,1-0:1.8.0*255(@1,Bezug,KWh,total_in,4
1,1-0:2.8.0*255(@1,Einspeisung,KWh,total_out,4
1,1-0:16.7.0*255(@1,Verbrauch aktuell,W,Power,16
>D
>B
->sensor53 r
>M 1
+1,3,s,0,9600,LK13SML,1,10,2F3F210D0A,063035310D0A
1,77070100010800ff@1000,Gesamt kWh bezogen,kWh,total_in,1
1,77070100020800ff@1000,Gesamt kWh geliefert,kWh,total_out,1
1,77070100100700ff@1,Verbrauch aktuell,W,Power,0
Schwarzermann
vielen Dank ich werde es Versuchen ich weis das hier nicht alles Plug und Play funktioniert aber man entwickelt sich ja selbst auch weiter undlernt dazu , Danke schon mal
